Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-20-2018, 12:52 PM | #1 |
What to replace...
My BRZ just hit 90,000 miles and it's feeling pretty beat.
I can hear the axles clicking in the rear, so I'll have to replace those..but in the front, this is what's driving me crazy...thoughts? (I have BC BR Coilovers). I haven't searched and haven't checked if anything is loose. Am hoping to get some input before throwing her up on the lift. |
06-20-2018, 12:56 PM | #2 | |
Country Boy 4 Life
How many of the 90,000 miles have you had the BC's installed?
I LIKE TIRES! |
06-20-2018, 12:59 PM | #3 | |
humfrz |
06-20-2018, 01:20 PM | #4 |
06-20-2018, 01:21 PM | #5 |
Yeah, my assumption is that i'll need new sway bar endlinks or something off the sort..just wanted to see if people have experienced anything like it before.
The Following User Says Thank You to Skeneypoo For This Useful Post: | humfrz (06-20-2018) |
06-20-2018, 01:25 PM | #6 |
Country Boy 4 Life
Unless you have your car as low as possible, the coils should last a bunch more miles. I agree with @humfrz Check everything out to see if anything is loose.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | humfrz (06-20-2018) |
06-20-2018, 02:19 PM | #7 | |
humfrz |
06-21-2018, 11:25 AM | #8 |
The Following User Says Thank You to Skeneypoo For This Useful Post: | humfrz (06-21-2018) |
06-21-2018, 11:27 AM | #9 |
You are the only one on the road in your area?
06-21-2018, 11:34 AM | #10 |
06-21-2018, 11:59 AM | #11 |
The Following User Says Thank You to Skeneypoo For This Useful Post: | Tcoat (06-21-2018) |
06-21-2018, 12:02 PM | #12 | |
Can't see your pics since they appear to be blocked so what did you find?
06-21-2018, 12:40 PM | #13 |
Endlinks are shot on both sides, sway bar bushings look a little wet, but not torn or cracking. No play in the wheels and everything is tight. Wheel bearings COULD be starting to go...doesn't seem likely though.
Also my axles are clicking a bunch, time for replacement i presume. |
06-21-2018, 01:20 PM | #14 |
Drives: '13 FRS - STX
Replace the axle nuts before you assume you need new axles, they go soft and allow a bit of slop (that can't be felt by hand). The other cheap thing is the parking/e-brake needing to be lubricated, noticeable if there's clicking getting in and out of the car with the e-brake engaged.
The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (06-21-2018) |
Similar Threads | ||||
Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
When do you replace your tires? | housecat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-29-2016 07:02 PM |
To replace rims or not replace? | unlimited86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 09-21-2015 12:12 PM |
Better Mic to replace OEM Mic in BRZ / FRS ??? | Zgrinch | Electronics | Audio | NAV | Infotainment | 42 | 02-06-2015 01:19 AM |
Looking to replace my sedan | carbonBLUE | Other Vehicles & General Automotive Discussions | 5 | 01-11-2013 08:41 PM |
