03-16-2022, 08:07 AM | #365 |
Drives: 1996 Turbo Miata
Has anyone tried the Greddy Supreme SP axle back on the 2022 cars?
03-16-2022, 08:18 AM | #366 |
Drives: '13 WRB BRZ '22 ISM BRZ Ordered
03-16-2022, 08:23 AM | #367 | |
Drives: X5 35d, D90, CX-5 Turbo
https://www.ft86club.com/forums/show...&postcount=304 |
03-16-2022, 10:01 AM | #368 | |
Drives: '22 BRZ
03-16-2022, 11:09 AM | #369 |
Drives: 22 brz
Did you use headphones? At first I listened to this clip on my phone and was surprised at how quiet it sounded. I listened to it later with an over the ear headset and the deep sound came through much better.
I'm sure it's not as loud as alot of the setups, but it's definitely not what I consider quiet. |
03-16-2022, 11:11 AM | #370 |
Drives: '22 BRZ
Yes I did use the headphones
03-16-2022, 11:36 AM | #371 | |
Drives: '22 BRZ Limited 6MT
03-16-2022, 01:22 PM | #373 | |
03-16-2022, 01:26 PM | #374 |
Drives: 22 brz
Funny you mention this, I accidentally sheared the bolt that mated the exhaust up to my stock front pipe. I went to Subaru and got a replacement bolt but they would not put it on so I drove over to a Mieneke car care and they threw it on for me( no charge!). When it was up on their lift he showed me that the muffler was rubbing the drive shaft just a little bit so he was able to loosen the connections and twist it slightly to give it more clearance but yes it is very close.
03-16-2022, 01:28 PM | #375 |
Drives: 22 brz
Axlebacks from 1st Gen don't fit, only newly designed specifically for 22 work. I'm unfamiliar with the greddy lineup so they may have some 22 stuff out to already
03-16-2022, 01:31 PM | #376 | |
But if you end up wheel hopping, accelerating hard, or anything that would cause the differential (and driveshaft) to shift, you might contact again. |
03-17-2022, 02:57 PM | #377 |
Drives: 2015 Tacoma
i hope the hks legamax will come out with a non-burnt tip option...i'm thinking the size of the tips are perfect compared to the greddy....if only the jdm sti exhaust was a little bit cheaper
hks legamax 124mm tips oem jdm STI exhaust 120mm tips greddy supreme 114mm tips
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S Current: 2015 Tacoma/2020 Sequoia Pro Future: 2022 CWP Limited Est Delivery 06/22 |
03-17-2022, 05:11 PM | #378 |
Drives: BRZ 2nd gen
I am also seriously considering the Sard axle-back from Japan.
Lighter by 3kg, real titanium tips and not too loud. https://www.sard.co.jp/parts/products/exhaust/suzt2/ The video has fairly ordinary sound quality, however the note in the upper range of the rpm is nice and clean. |
The Following User Says Thank You to Grif For This Useful Post: | AK2112 (03-18-2022) |
Similar Threads | ||||
FR-S and BRZ Exhaust Compilation Thread | Spd229 | Engine, Exhaust, Transmission | 660 | 01-03-2024 10:10 AM |
2022+ Exhaust compilation thread | Yoshoobaroo | Engine, Exhaust, Transmission | 22 | 04-22-2022 06:17 AM |
The Boosted Exhaust Thread | The Racers Line | Forced Induction | 49 | 06-05-2014 01:13 AM |
The Exhaust Weights thread | qoncept | Engine, Exhaust, Transmission | 5 | 06-12-2013 02:34 PM |
Agency Power Exhaust Thread PT II | vividracing | Engine, Exhaust, Transmission | 222 | 07-28-2012 12:52 AM |
