Old 10-08-2021, 10:13 AM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Beehive valve springs
Has anyone used the beehive springs on their valve train. I'd like to know how well they work
Thanks
Rabrooks is offline   Reply With Quote
Old 10-08-2021, 10:19 AM   #2
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
I have them i don’t really feel a difference its more a security thing for the people that enjoys banging redline all day but if you “accidentally” end up redlining you’ll be okay from valve float issues but keep in mind the oil system will freak out i got them because its a must have since the engine was already apart.
IsaiahW is offline   Reply With Quote
Old 10-08-2021, 11:33 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Beehives allow you to run more lift then a standard spring without getting coil bind. That is it.
Old 10-09-2021, 04:34 AM   #4
makinen
makinen's Avatar
Drives: Toyota 86
Doing 8k rpm is easier than before.
Hesitation from 7.5k has gone.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
HKS GT EL header, 17MY intake manifold */
makinen is offline   Reply With Quote
Old 10-09-2021, 10:23 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
makinen: IIRC main issue that kept off higher redline from twins engines was limitations of oiling system.
x808drifter (10-09-2021)
Old 10-09-2021, 04:30 PM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Yep.
Just because you can doesn't mean you should.
Old 10-11-2021, 06:20 PM   #7
Rabrooks
Rabrooks's Avatar
This is for my track car. Redline will be 8500. This is a built engine with alot of oiling updates.
There is alot more to beehives than just higher lift. They have much better harmonic control allowing a softer spring to do the same job as heavier springs. Just wondered how well they worked in the fa20
Old 10-11-2021, 06:24 PM   #8
Rabrooks
Rabrooks's Avatar
For those using the beehive springs. Does anyone have the PAC springs. If so. Do you have a part number
Old 10-12-2021, 10:37 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Good luck with engine to last any meaningful mileage. AFAIK competent shops had problems getting FA20 reliably past 7800-7900, due mentioned oiling system limitations.
Turdinator (10-18-2021)
Valve Springs advice SwiTchY86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-06-2021 09:26 PM
J02 recall valve springs question fitcious Issues | Warranty | Recalls / TSB 9 06-17-2020 02:22 AM
What does the J02 recall come with besides valve springs? aznchris Issues | Warranty | Recalls / TSB 17 02-14-2020 09:22 AM
Valve springs: GSC vs Supertech glorydays Engine, Exhaust, Transmission 15 01-27-2020 04:24 PM
Valve springs Gunman Off-Topic Lounge [WARNING: NO POLITICS] 8 11-21-2018 02:49 PM
