DIY (Do-It-Yourself) Guides For all DIYs. |
07-22-2014, 11:40 AM | #43 | |
Drives: Asphalt FR-S
12-16-2014, 01:21 PM | #44 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I recently got this retrofit kit for my Winjets, and was curious if I needed the add a circuit if I wanted the DRLs to work like they normally do? I.e. not always on I guess you'd say?
12-18-2014, 12:26 PM | #45 |
Troll Hunter
Drives: fr-s, tundra
I am sure you can probably just tap into the DRL wire, but I don't have any instructions on how to do that. I know there is a DRL module under one of the head lamps, I would just T tap into the red wire.
09-22-2015, 04:13 PM | #46 |
much slow
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Just an FYI for anyone doing the constant DRL mod, the add a ciruit that OP linked is the wrong one. You need the one for newer cars which uses a much smaller fuse.
I had to run to the auto store to pick up a new one cause the one from amazon didn't fit |
06-17-2016, 04:44 AM | #47 |
Drives: FRS
Has anyone upgraded bar LED bulbs or made them switchbacks?
any input appreciated, or at least whats the bulb size on leds. thanks! |
The Following User Says Thank You to Binary_fission For This Useful Post: | MisterSheep (06-09-2017) |
08-01-2016, 10:35 PM | #48 | |
Drives: 2013 Raven FR-S
http://www.ft86club.com/forums/showp...&postcount=218 Winjet LED bar use 6 5050 LED each side. it should be easy to swap them out with switchback LED and add extra wire route for the amber turn signal. |
The Following User Says Thank You to 6spd For This Useful Post: | Binary_fission (08-01-2016) |
08-01-2016, 10:38 PM | #49 | |
Drives: FRS
Sent from my SM-N910T using Tapatalk |
Similar Threads | ||||
DIY Retrofit Winjet headlights | post_break | DIY (Do-It-Yourself) Guides | 6 | 07-15-2014 12:13 AM |
WTT: Winjet Black Headlight for Winjet chrome | dezmoondo | Exterior Parts (Aero, Lighting, Etc.) | 0 | 04-13-2014 03:02 AM |
Install Morimoto Retrofit kit into Winjet lights? | Khyron686 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2014 05:55 PM |
Custom Purple Winjet and Black Winjet Headlights | xclusive_brett | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 12-17-2013 08:28 AM |
