Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-03-2022, 01:49 AM | #1 |
Drives: brz
Carbon build up
Anyone having issues with carbon build up on the bottom of engine block?
I have a ton caked on... I never really noticed before. This normal? |
02-03-2022, 09:04 AM | #2 |
Drives: 2013 frs base
Looks like a small oil leak. Clean it off and recheck. Front crankshaft seal or bottom of timing cover are likely sources.
02-03-2022, 10:36 AM | #3 |
Drives: 2016 BRZ
02-03-2022, 10:40 AM | #4 | |
Drives: Subaru BRZ
- O Ring for the dipstick area or... - Timing Chain Cover / Valve Cover (I forgot which one). If you're under warranty, they'll fix it. If its minor, just clean it and enjoy the car. |
02-03-2022, 11:24 AM | #5 |
Drives: brz
Thanks yall for the suggestions.
It looks like its all over the bottom of the engine case. Tbh i have had more than my fair share of track days . Engine is stock. But i have headers and stuff. I never got a recall letter. So maybe im on my own. Ill try out the dipstick gasket first. See if it works. |
The Following User Says Thank You to mamamiaellis For This Useful Post: | blsfrs (02-05-2022) |
02-03-2022, 02:50 PM | #6 | |
Drives: Subaru BRZ
Good luck! Tracking down these issues can be a huge PITA on FA20. |
02-03-2022, 03:52 PM | #7 |
Drives: brz
appreciate the help!
more i think about it, i dont think the dipstick can spread carbon out that far. Ill probably take some time to jack up the car and clean it up. sigh........ hoping to find the area of issue and just try and externally seal that part. and hopefully the build up is not inbetween the headers. |
Similar Threads | ||||
Percentage of port injection and carbon build up | JIM THEO | Engine, Exhaust, Transmission | 9 | 01-08-2021 03:59 AM |
My Greddy Rocket Bunny V2 Build | Carbon Signal | Paul_GT86_dxb | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-02-2016 10:41 PM |
Carbon build up around intake valves? | csaba | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 57 | 01-13-2015 09:39 AM |
eguerin's SSM/Carbon BRZ Build | eguerin | Member's Car Journals | 9 | 07-08-2014 03:53 AM |
dual injection is just a long overdue solution to carbon build up? | Hasjwandje | Engine, Exhaust, Transmission | 19 | 11-08-2011 05:53 PM |
