Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
07-06-2021, 01:33 AM | #1 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Low Profile Jack Handle Set Screw Help
I purchased a Performance Tool 2 ton low profile jack that came without a handle set screw. There was a hole in the box and apparently they just throw the screw in the box or I was sold a used product. Neither the vendor nor the manufacturer would assist and the manual does not have a part number or dimension for the screw. I was willing to buy the screw from them if they had them and return shipping was over $100 - not worth sending it back.
Reaching out to see if anyone has this or similar model jack and could confirm if either of these screws would fit. Performance Tool W1642 on Amazon eBay Set Screw Listing #1 eBay Set Screw Listing #2 |
The Following User Says Thank You to 2020BRZtS For This Useful Post: | humfrz (07-06-2021) |
07-06-2021, 02:34 AM | #2 |
The Following User Says Thank You to humfrz For This Useful Post: | 2020BRZtS (07-06-2021) |
07-06-2021, 05:18 PM | #3 | |
07-06-2021, 05:39 PM | #4 | |
Bubba suggests you pack up your jack, go to the hardware store, buy a few bolts that look to be the proper thread and diameter (the length won't much matter), try them till you find the proper one. Keep that one, take the others back into the store for a refund. |
07-06-2021, 06:44 PM | #5 |
Drives: Crapcan
Screw some bolts into it till you find the right diameter and pitch. Chuck bolt in drill and turn against belt sander until desired shape is roughly reached. Finish with file.
Done
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | pope (07-06-2021), soundman98 (07-07-2021) |
07-06-2021, 06:58 PM | #6 | |
I looked at the two listings closer and I believe the first one a safer bet. My thought is if the machined out pin is too long... add the washer. If not leave it out. |
07-06-2021, 07:02 PM | #7 |
Drives: Crapcan
If you know the dimensions I can turn one in the lathe and send it to you.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | 2020BRZtS (07-06-2021), soundman98 (07-07-2021) |
07-06-2021, 07:08 PM | #8 |
The Following User Says Thank You to 2020BRZtS For This Useful Post: | NoHaveMSG (07-06-2021) |
07-06-2021, 07:13 PM | #9 |
I appreciate the offer. I have seen others in the forum with the same jack in 3.5 ton in their pictures except it is black. I'll go back through the what did you do thread and see if I can find an example.
07-06-2021, 07:46 PM | #10 |
has a funny hat
Drives: 2014 BRZ Limited
you could always use the hardware bolt method to identify the size and then buy the corresponding set screw from ebay, amazon, etc.
If you lug the jack into a small independent hardware store there is a fair chance the owner/staff will help identify the size and thread just to build a positive relationship in hopes of future sales. Alternatively, lug the jack into a big box store, identify the size and then leave without purchasing since they don't have the screw design you require. |
The Following User Says Thank You to pope For This Useful Post: | 2020BRZtS (07-06-2021) |
07-06-2021, 08:49 PM | #11 | |
07-07-2021, 06:44 PM | #12 | |
ProCrastinationConsultant
i had some audio equipment racks with acrylic panel covers that preferred to swing open naturally. i made the same style bolt/nipple with a thumbscrew so that there was essentially a mechanical detent point to allow for access and still keep them closed before fully securing the covers over the equipment faces.
The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (07-07-2021) |
11-12-2021, 04:06 PM | #13 |
I finally got the screw I needed for a reasonable price. It's an M12 x 1.75mm x 20mm. Now I can install my axle back.
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post: | bcj (11-12-2021), soundman98 (11-13-2021) |
Similar Threads | ||||
Low profile jack | Elliotw | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 05-20-2021 06:14 PM |
FS: 3TON LOW PROFILE JACK | briang0901 | Mechanical Maintenance and Tools | 9 | 11-09-2020 07:41 AM |
Harbor Freight - 3 Ton Low Profile Jack | SmartedPanda | DIY (Do-It-Yourself) Guides | 41 | 01-16-2018 11:15 PM |
WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
Low Profile Jack? | PMPB | CANADA | 20 | 03-19-2015 09:56 PM |
