Old 06-06-2020, 11:36 PM   #57
Jdmjunkie
Drives: Scion FR-S 10 Series
Are you planning on putting up a DIY or selling tuning to do this on other cars?
Jdmjunkie is offline   Reply With Quote
Old 06-08-2020, 01:05 PM   #58
tomm.brz
Drives: brz 2017 hksv2
didn't you try the pedal dance , or the traction control disable from ecutek app? it should remove the throttle closing at least
tomm.brz is online now   Reply With Quote
The Following User Says Thank You to tomm.brz For This Useful Post:
solidsnake11 (06-08-2020)
Old 06-10-2020, 08:22 PM   #59
GrabTheWheel
Drives: 16' BRZ
1/8 mile huh? I hope you got to do a lot of passes. One night of drag racing was enough for me. 33 seconds of seat time for 3 hours spent waiting at the track was even worse than autoX. Had more fun driving to and from the dragstrip!
Like anything else I'm sure a purpose built drag car would make it a lot more fun. To me 1/8th mile seems to make more sense in a car that's so fast it's terrifying to run in the 1/4.
GrabTheWheel is offline   Reply With Quote
The Following User Says Thank You to GrabTheWheel For This Useful Post:
solidsnake11 (06-10-2020)
Old 06-11-2020, 07:13 AM   #60
tomm.brz
it could be launch control ramp that s limiting you in the launch, but i don t understand that table and i never asked ecutek
i raised it a bit though and it seems quicker at launching
solidsnake11 (06-11-2020)
Old 06-11-2020, 03:17 PM   #61
Kodename47
Kodename47's Avatar
Drives: UK GT86
"During the launch, the rev limit increases according to the 'Launch Control Rev Limit Delta, This 2D map, indexed by elapsed time, has multiple columns to allow you to set up a multi-stage system for best results"
So 500 will be launch RPM+500
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
solidsnake11 (06-11-2020), tomm.brz (06-11-2020)
Old 06-12-2020, 05:01 AM   #62
tomm.brz
thanks
then don t know if it caused by that
what are you getting precisely, bogging?
solidsnake11 (06-12-2020)
Old 06-13-2020, 11:41 AM   #63
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by solidsnake11 View Post
Some guy in a new Porsche 911 picked on the wrong BRZ today. I mashed on it too much to start with , It scared him, so I didn't really get to see how bad he would get beat.
Must have been pretty bad because he changed from f1 driver to wagon driver pretty quickly.
One more thing, I know most have heard the Honda engines when they sound like they have a 5 inch throttle body well that is actually the vtec running on the large cam that makes that sound. I never knew that before my swap.
It is that and the 4” straight pipe made from eBay’s finest “titanium wrapped in carbon fiber vinyl” 22 gauge sheet metal.
Old 06-17-2020, 08:36 PM   #64
toast
Drives: 14 BSP Edelbrock BRZ
I also turned the fake direct injectors on past 6000rpms because I was at 80% on the 1050s.
I don't understand what that does. The BRZ ECU won't let you go past 80% port without some DI?
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
solidsnake11 (06-17-2020)
Old 06-18-2020, 10:24 AM   #65
toast
Ah, I didn't realize you had multiple sets of injectors.
solidsnake11 (06-18-2020)
Old 07-19-2020, 11:47 PM   #66
Jdmjunkie
How easy would it be to do this ecu setup if I were to keep the motor n/a? Also I am assuming with some fab work you could get the A/C to work?
The Following User Says Thank You to Jdmjunkie For This Useful Post:
solidsnake11 (07-20-2020)
Old 07-19-2020, 11:52 PM   #67
Irace86.2.0
Axles next?
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 07-20-2020, 06:26 AM   #68
radroach
Drives: car
wha? You know ALL THIS OTHER STUFF but didn't realize this before?
The Following User Says Thank You to radroach For This Useful Post:
Old 07-20-2020, 08:16 AM   #69
Ashikabi
Ashikabi's Avatar
I already installed IS350 axles.
Stock diff and hubs? Direct swap in?
Old 07-20-2020, 08:59 AM   #70
Ashikabi
Ashikabi's Avatar
They slide into the stock diff.
I had to use the is350 hub(bearing) splines are larger. Two holes need to be relocated to bolt in.
Used a long axle from is350 and moved snap ring that locates the star to gain 3/4" extra clearance.
Can you elaborate on "moved snap ring for extra clearance"?
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-20-2014 11:16 PM
Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) TM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 04-30-2014 03:31 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-11-2012 11:29 PM
