12-22-2013, 07:59 AM | #29 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Insanity. Bravo.
The Following User Says Thank You to slicktop For This Useful Post: | FullBlown (12-22-2013) |
12-22-2013, 08:26 AM | #30 |
Drives: Scion FRS
12-22-2013, 08:36 AM | #31 | ||
Drives: Scion FRS
The upper pan holds a decent amount of oil. There are many functions of the upper pan, it acts as a girdle, windage tray and oil pan. |
The Following User Says Thank You to FullBlown For This Useful Post: | Calum (12-22-2013) |
12-22-2013, 08:40 AM | #32 |
Thanks
So much nice parts, make me want to buy them and make my car not a DD ^_^
12-22-2013, 08:53 AM | #33 |
Hopefully not too off topic. This upper pan, does it just hold oil while the car is running but drains down to the lower pan? It doesn't behave like a torque converter and holds it? Are there any pictures of this upper pan around, cutaway shots or something of the sort?
.o0+Eric+0o.
2016 Chrysler 200S 3.6 2013 FRS 6MT |
12-22-2013, 09:43 AM | #34 | |
Drives: Scion FR-S
#FullBlown Who is doing your SLS work... or was that Stratasys? I cant tell in your picture. |
The Following User Says Thank You to ciro For This Useful Post: | ftc~brz (03-31-2014) |
12-22-2013, 09:55 AM | #35 |
CHECK ENGINE
Drives: 2004 STi
Awesome piece, can't wait to see the final version.
Had the upgraded oil pan on my STi and will do the same for the BRZ
i don't cry about crickets
The Following User Says Thank You to CARNZ For This Useful Post: | FullBlown (12-22-2013) |
12-22-2013, 10:27 AM | #36 |
We considered the same - glad to see you guys are on it. This will streamline turbo installs, especially for those doing it at home without a welder.
The Following User Says Thank You to Hal@Dynosty For This Useful Post: | FullBlown (12-22-2013) |
12-22-2013, 10:43 AM | #37 |
Drives: 2013 AT Firestorm FRS
So the pre oil pan that you guys currently offer on your turbo kit holds the same amount of oil as OEM, but this new pan holds 1 quart more of oil?
12-22-2013, 10:46 AM | #38 |
Grip>Slip
Is it too early to know what (if any) effects the pan has on oil temps?
12-22-2013, 11:53 AM | #39 | |
That Guy
Drives: 2013 asphalt FRS MT
Crawford posted a pic before. http://www.ft86club.com/forums/showp...3&postcount=17 |
The Following User Says Thank You to Calum For This Useful Post: | FullBlown (12-22-2013) |
12-22-2013, 11:59 AM | #40 |
Ah ok, I did see that pic before but didn't realize there was more there than just some bracing and the oil pickup. Thanks!
.o0+Eric+0o.
12-22-2013, 12:11 PM | #41 | |
Drives: Scion FRS
Yes it is, but we expect it to lower the temp slightly. It won't be anything significant but some. |
12-22-2013, 12:23 PM | #42 |
With these engines every little bit helps, I know after a good run my oil cooler lines will burn you in a hurry.
Similar Threads | ||||
FRS Die-cast model | encity5 | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 02-24-2019 12:15 PM |
Expensive, but cool Die Cast GT-86 | Kimsey47 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 11-26-2013 05:12 AM |
FS: Die-cast EBBRO 1/43 frs 86 | blanco | Miscellaneous | 4 | 09-25-2013 10:42 PM |
Durability of cast wheels | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-06-2012 05:10 PM |
Any Disney Cast Members here? | MF_DEUCE | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-18-2011 01:48 AM |
