Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
12-09-2019, 05:03 AM | #1 |
Drives: Asphalt '16 FRS
Help with Installing Component Speakers
So I've had a terribly hard time installing a simple set of 2 way component speakers, mainly running the tweeter from the door into the cabin. If anyone has tips on how to do so more easily do so please let me know, but what I want to ask is:
Is there be negative effect in simply wiring these 2 way speakers to the factory harnesses instead? As in, woofer to door connector, tweeter to dash plug. When comparing how the tweeter sounded connected to the woofer as intended vs connecting the tweeter to the dash harness, it sounded not as bright and with a bit of lower frequencies filtered out, or just slightly less great - I think at least, unsure of placebo, but that is why I decided to go with the door route. My skepticism comes from not understanding how the dash speakers wiring works, I just plugged +/- into the 4 pin plug. If true, would there be a reason to why this is, such as built in capacitors in the stock wiring or the impedance of 2 separate speakers on the same channel? Don't actually understand how that works, just looking for a "Yes it would be perfectly fine", or a "No, you wouldn't be getting the full potential of the components in doing so." For anyone that's installed a component set, how did go about it? |
12-09-2019, 01:59 PM | #2 |
Drives: 2019 Toyota 86 TRD SE
I have components on mine. I wouldn't connect the aftermarket tweeters to your stock harness. You spent the money on components so you should get the best performance. I replaced the OEM tweeters with my components tweeters. To run the wires, I used 3 long zip ties zipped together like a long line and fed it through the hole that's right next to the OEM tweeters harness. It should lead down to the kick panel area.
12-09-2019, 03:29 PM | #3 | |
12-09-2019, 03:36 PM | #4 | |
JDM Vaping Stance Nation
Drives: 2013 White
Those door grommets are a PITA. I put turn signals in my side mirrors and did it the lazy way and just shoved them to the side. Well, enough closing and opening the doors it cut the wire. So I did it the right way finally. Need to remove the black tape on the grommet (between the door and fender). Slide the top grommet into the door itself (I think I used some grease here but not a whole lot). Compress the grommet, then slide wire through. Once you get the wire through, slide a coat hanger into the bottom of the grommet near the kick panel and then pull it into the car. Slide top part back to meet the bottom part and tape back up.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post: | Pizzachicken (12-09-2019) |
12-09-2019, 04:13 PM | #5 |
I had an extremely hard time with the grommet part...I just made two holes on the outside of the boot, one on the door side and one on the car side and just ran the wires on the alongside of the boot. Not ideal. I know. But I was at my wits end with it. But I did comment on a post about another person that was able to get it done. I included the thread. I hope it helps. Don't give up. It's doable!
http://www.ft86club.com/forums/showt...60#post3274260 |
The Following User Says Thank You to Drifter X For This Useful Post: | Pizzachicken (12-09-2019) |
12-11-2019, 07:52 PM | #6 |
You mentioned "best performance" Would tapping the crossover into the factory wiring that leads to the door speakers, so that the wire output is delivering to two speakers not yield the same result? Would I be robbing power of the woofers or something?
12-11-2019, 07:59 PM | #7 | |
Wait. Do you have an aftermarket amp powering the components? If you don't then I guess tapping the the wire to the woofers with the crossovers should work. Sent from my iPhone using Tapatalk Last edited by Drifter X; 12-12-2019 at 12:42 AM. |
12-12-2019, 05:02 AM | #8 |
I have an aftermarket head unit with a built in amp of 50x4 RMS. I will try that tomorrow if you say so. In the trunk of the car I've bypassed the factory amp by routing input/output pins together, which is where I plan to tap the crossover. Any objections?
12-13-2019, 09:40 PM | #9 |
ProCrastinationConsultant
no objections
Similar Threads | ||||
3 Way component speakers, amp and DDX916WS | Recoil6 | Electronics | Audio | NAV | Infotainment | 20 | 03-15-2017 09:12 PM |
Anyone have Focal Access 165 A3 3-Way Component Speakers? | Project86 | Electronics | Audio | NAV | Infotainment | 1 | 07-24-2014 07:32 PM |
Thoughts on component speakers? | Griever423 | Electronics | Audio | NAV | Infotainment | 10 | 06-30-2014 08:52 PM |
Lets Talk Component Speakers | Skippman | Electronics | Audio | NAV | Infotainment | 34 | 01-09-2014 01:29 PM |
Replaced front speakers with component set - sound is worse | AlexTheGreek | Electronics | Audio | NAV | Infotainment | 37 | 04-15-2013 09:58 PM |
