BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
03-15-2021, 08:59 PM | #43 |
Drives: Red 2019 Subaru BRZ
The car has little left to gain from anything near stock. Its already pretty well maxxed for what it is. You can pull a bit here and there but outside of boost there's not much there.
I have never felt the torque dip. If I'm in a hurry its usually down two, and 5 grand gets the job done. |
The Following 2 Users Say Thank You to PenGun For This Useful Post: | AnalogMan (03-16-2021), The Red One (03-16-2021) |
03-15-2021, 10:08 PM | #44 | |
Howdy
Drives: 2020 BRZ PP
Just curious as I do not agree at all and this is the internet, so I can object. Bolt-ons will never equal FI, but FI is not everyone's goal and there is a lot between fully stock and FI, imo.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post: | Arthur-A (03-16-2021), PulsarBeeerz (03-16-2021) |
03-15-2021, 11:16 PM | #45 | |
What's FI? I'm very old. The motor at 12.5/1 and happily doing 7 grand and does not have much left. You could do a few things but most of what needs to be done, is done. Its a 2 litre motor and adding slightly better flow and exploiting your computer, variable valves, etc will not give you much back. Adding boost will, but you should rebuild the motor to do that well. Now its a 'sports car' and is built to be one so well, that there's not much left, again. If you want a muscle car you are in the wrong one. I built a 69 Cutlass with a 502 from the General and it would do stupid power stuff all day, but even with about 8 grand in the suspension, and Gatorbacks, its was scary in the twisties. The BRZ is just fun, till it slides, then its more fun. The Cutlass nearly killed me a couple of times. |
The Following User Says Thank You to PenGun For This Useful Post: | BrahmaBull1990 (03-15-2021) |
03-15-2021, 11:23 PM | #46 | |
Howdy
Drives: 2020 BRZ PP
03-16-2021, 02:53 AM | #47 | |
Drives: JRSC BRZ SOLD
There are many NA dyno results that refute those statements. haha E85 in particular loves that 12.5:1 compression. Also people have been running conservative boost setups on this engine for the better part of 7-8 years. I take it you are new to the platform?? |
03-16-2021, 03:23 AM | #48 | |
Drives: Crapcan
I think you are misinterpreting him a bit. I think his point is just that modern engines are far more optimized out of the box then what was considered a sports car 30+ years ago. Sent from my iPhone using Tapatalk
03-16-2021, 07:48 AM | #49 |
Drives: 2015 BRZ WRB
After the warranty was over I put a UEL & tune. I rarely felt the dip in those 5 yrs & I drive speed limit/normal. UEL/tune adds a little more fun but I did it more for sound. Not very cost effective if your doing for power.
The Following User Says Thank You to CB750F For This Useful Post: | AnalogMan (03-16-2021) |
03-16-2021, 08:19 AM | #50 | |
Drives: 2018 Subaru BRZ Limited with PP
The Following 2 Users Say Thank You to Dzmitry For This Useful Post: | AnalogMan (03-16-2021), BrahmaBull1990 (03-16-2021) |
03-16-2021, 11:11 AM | #51 | |
Master Collaborator
Yes, think about this: My '68 Torino with a 302 (that's approximately 5.0 liters) made a whopping 205 HP stock. The 3.0 engine in my '00 Solara makes about 198 HP stock. This little 2.0 liter in these cars makes 2.5 times the HP per cubic centimeter than the engine in my Torino did. However, which of these three engines do you think will last the longest? There's a trade off when it comes to high output and reliability. For those who are wondering, the Torino is still in the road with it's original engine. The Solara as well. My point is, without some form of radical design change, the N/A internal combustion engines being produced today are just about at their power limits if you want that engine to last any length of time. Which brings me to that redesigned rotary engine with the seals in the stator section. Although the seals will still have to be replaced eventually, they will most likely be easier to change with this design, which makes it an important step forward for the internal combustion engine. If someone can make an engine that weighs ten times less than the engine it replaced for the same amount of power output, THAT says something and this should be looked into further. https://www.liquidpiston.com/xmini I may even invest in this at some point. |
03-16-2021, 11:32 AM | #52 | |
Barred
Drives: My18 wrxsti My19 brzts
Wait until my Flex capacitor hits 88
The Following 2 Users Say Thank You to gen3v8 For This Useful Post: | Arthur-A (03-16-2021), Lantanafrs2 (03-16-2021) |
03-16-2021, 01:07 PM | #53 | |
https://www.ft86club.com/forums/showthread.php?t=70155 https://www.ft86club.com/forums/showthread.php?t=41525 https://blog.modbargains.com/fix-tor...r-ssubaru-brz/ https://www.ft86club.com/forums/showthread.php?p=938787 The above are just random links of examples, and even half of these are manufacturers posting their BEST results likely, and not an accurate representative of what most people that get a tune with a header actually get. E85 is where the greatest gains come from, and as I said earlier, I am keeping that out of the equation. This engine was designed with some of the highest power they could come up with, including some cost savings and heavy emission guidelines. If they didn't need to stick a cat in the header, plenty of people that do some minor tune-ups now would be happy leaving the car as is. |
The Following 2 Users Say Thank You to Dzmitry For This Useful Post: | BrahmaBull1990 (03-16-2021), Ohio Enthusiast (03-16-2021) |
03-16-2021, 01:22 PM | #54 | |
I have had the car for over a year. I built cars when I was young, I do know how this works. I have possibly the best gas in NA for my car, Chevron Good Old Premium. No alcohol 94 octane goodness, so my computer pulls time, the biggest source of power loss in these cars, less often than some lesser fuels. I do understand E85 takes this a little further, but as many have said there really is not a lot left. Certainly boost changes everything, but boosting a 12.5/1 motor is not the best way to do that. Rebuilding it would be a useful way to add boost. It all comes down to what the computer will let you do. Now I had trick stuff, a QuarterHorse for my Mark VIII, and could tell the computer all kinds of things. You cannot do that with this car, you need to get someone who has payed for the privilege to make you a tune. As always YMMV. |
The Following User Says Thank You to PenGun For This Useful Post: | BrahmaBull1990 (03-16-2021) |
03-18-2021, 06:19 AM | #55 |
Barred
I said 15-20% My glass is half full @ 15% your glass is unfortunately half empty @15%. 15% of 205 would only make it 230
03-18-2021, 09:20 AM | #56 | |
I'm not here to pick a fight with ya, just saying that you shouldn't expect or give others expectations of those kind of gains. I bought what is known as one of the best headers on the market for this platform along with a cat-back. I also got Ecutek and a few revisions from one of the best tuners for this platform on the east coast. I even went to his dyno later on for the hell of it to get the experience and wring out a few extra ponies. End result was 178whp. Though I never got a baseline, I certainly don't believe I ever gained anything close to 30HP. It feels stronger up top, but not by much.. Keep in mind, too, that I went above and beyond what the majority of people here would do. |
The Following User Says Thank You to Dzmitry For This Useful Post: | Ohio Enthusiast (03-18-2021) |
Tags |
torque, torque solution, tune |
Similar Threads | ||||
Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
Torque Pro | sav | AFRICA | 33 | 08-27-2013 07:31 AM |
What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 06:56 PM |
Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
