Old 12-17-2015, 07:34 PM   #1
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Thumbs up Drakiv's FBM Stage 2 Turbo project Shadow Build
Welcome to my Shadow build.....
Here are the current mods on the car as it sits:
Huge thanks to LJ and his team @FullBlownMotorsports and Matt and his team over @JacksTransmissions
Both companies were very helpful and extremely professional and I cannot say enough good things about both of them.
Engine:
9.5:1 Arias Pistons
FBM Connecting Rods
FBM Stage 2 Block
FBM Stage 2 heads
FBM Stage 2 Turbo kit with GTX3582r
Tial 44mm Wastegate
Tial 50mm Q BOV
FBM 4 bar map sensor
FBM 19 row oil cooler kit
FBM Radiator with shroud and slim fans
FBM Silicone Radiator hoses
FBM Dual Oil catch can
FBM Oil Pan
FBM Walbro 485 fuel pump kit
FBM Fuel Rails
ID 1700cc injectors
FBM Surge tank with triple Walbro 485 pumps
FBM Fuel return system with FBM 1:1 FPR
Cusco Motor Mounts
RaceSeng cam plate
ReXpeed Carbon Fiber strut Mounts
JDL 3" Overpipe-Frontpipe combo
Perrin 3" Resonated cat back
ECUTeK tuned by FBM on E85/91
Drivetrain:
Clutch Masters twin plate clutch
MTEC shift springs
MTEC stainless steel clutch hose
KARTboy Short Shifter with bushing
PAR Engineering straight cut synchromesh 1st-6th gear set
Velox Motorsports Billet Clutch Fork and Pivot
Megan Racing Reinforced Transmission Mount
Velox Motorsports Carbon Fiber driveshaft
3.73 Final drive upgrade w/ supra bearing and solid spacer
Harrop Diff Cover
Neo Synthetic 75W-90 RHD gear oil (Diff and Trans)
Driveshaft shop 1000HP Pro-level axle & hub kit
Exterior:
Seibon TS Carbon Fiber hood
Aerocatch hood pins
Valenti Black edition sequential taillights
Wheel/Tires:
Forgestar F14 Wheels - 18x8.5 +35 Front and 18x9.5 +40 Rear
Hankook Ventus V12 evo2 - 245/35/18 Front and 265/35/18 Rear
Suspension:
Feal 441 Coilovers
Velox Rear LCA
SPL PRO Rear End Links
Adjustable Toe Arms by Velox
SPL Bumpsteer Adjustable Front Tie Rod Ends
SPL Trailing Arms
Hotchkis Front End Links
ST Suspensions Sway Bar Kit Front and Rear
Interior:
NRG 315mm Carbon Fiber Steering Wheel Red Stitching
NRG Hub Adapter with resistors
NRG Quick Release Ver. 3
Raceseng Ashiko Shift knob
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following 3 Users Say Thank You to Drakiv For This Useful Post:
austinbrz (04-26-2016), Lonewolf (12-18-2015), MisterSheep (01-15-2016)
Old 12-17-2015, 07:57 PM   #2
Drakiv
Project Shadow
Drakiv's Avatar
So here is my list of what I have planned and I will update this page later as I start to get things completed. It will be a somewhat slow start this first couple months because I am also planning my wedding, but once that is finished in March I will have some fairly hefty upgrades on the way. So please bare with me as I start my journey into this project. None of this is in order of what gets done first, it is just a rough list.
1. Seibon Carbon Fiber TS hood *Installed
2. Forgestar F14 wheels 18x8.5 +35 - 18x9.5 +40 *Installed
3. Feal 441 Coilovers *Installed
4. SPL PRO Rear End Links *Installed
5. FT-86 SpeedFactory Adjustable Toe Arms by Velox *Installed
6. SPL Bumpsteer Adjustable Front Tie Rod Ends *Installed
7. SPL Trailing Arms *Installed
8. Hotchkis Front End Links *Installed
9. ST Suspensions Sway Bar Kit Front and Rear *Installed
10. FT-86 SpeedFactory / Velox Rear LCA *Installed
11. MTEC shift springs *Installed
12. Megan Racing Transmission Mount *Installed
13. Velox Motorsports Billet Clutch Fork and Pivot *Installed
14. MTEC Stainless Steel Clutch Line *Installed
15. PAR Engineering straight cut synchromesh gear set *Installed
16. Velox Motorsports Carbon Fiber driveshaft *Installed
17. 3.73 Final drive upgrade w/ supra bearing and solid spacer *Installed
18. NRG 315mm Carbon Fiber Steering Wheel Red Stitching *Installed
19. NRG Hub Adapter with resistors *Installed
20. NRG Quick Release Ver. 3 *Installed
21. GCS Smoked 4th F1 Style Brake Light V2 *Installed
22. FBM stage 2 short block *Installed
23. FBM stage 2 heads *Installed
24. FBM head studs *Installed
25. FBM head gasket *Installed
26. FBM Stage 2 turbo kit *Installed
27. Clutchmasters Twin Disc *Installed
28. Driveshaft shop Pro-level axle & hub kit *Installed
29. Raceseng Cam plate *Installed
30. Cusco Reinforced Engine Mounts *Installed
Still to come:
Engine:
Motec ECU
Dry Sump kit
Exterior:
Wide Body Fenders
Street Faction Engineering Chassis Mount Wing
Charvonia Design V1 Rear Diffuser
6 Piston Front BBK and 4 Piston Rear BBK
Dry Carbon Fiber Hood
Dry Carbon Fiber Doors
Dry Carbon Fiber Roof replacement
Dry Carbon Fiber Trunk
Wheels:
HRE C105 or C100 18 x 12 -40 squared with 10mm spacers in rear
Hoosier A7 315/30/18 squared
Interior:
Interior removal
Full Roll Cage
Racing seat with harness
I have some of it ordered already, and my goal is to get this car finished by May of 2017. I will post pictures as I get equipment in and/or installed. Cheers!
614whp/421tq on E85
Instagram: Drakiv
The Following 2 Users Say Thank You to Drakiv For This Useful Post:
MisterSheep (01-15-2016), ~el~jefe~ (12-11-2016)
Old 12-17-2015, 07:58 PM   #3
Drakiv
Project Shadow
Drakiv's Avatar
I purchased a 2015 BRZ Limited in Crystal Black Silica. So far the car has been a lot of fun, and I have done a few mods to it since I picked it up. Nothing major, just headers, an overpipe, and a catback with the support of an OFT stage 2 UEL tune on 91 octane (boooo California). But even with all of this, the power to me is lacking. And man, do I miss having a turbo. So I have been really racking my brain for a while now on what I wanted to do, buy a different car? Or upgrade the hell our of the BRZ. I really like the BRZ, the platform is amazing and really reminds me of my '93 RX7 sometimes....minus the power. So I finally decided that I want to go into the turbo realm with the BRZ. I will post some picture of how the car sits now, and will try to post updates as much as possible in the coming months. I am currently in talks with FullBlown Motorsports, and am looking into a stage 2 motor, stage 2 heads, and their stage 2 turbo kit. My goal is around 600 WHP, and before you ask why or what I plan to do with that type of power.....well, because I can first and foremost. I have plans for after the car is done, but that will be released much later.
614whp/421tq on E85
Instagram: Drakiv
Old 12-17-2015, 09:19 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I do say, good sir, this exquisite car will be quite pricey. I bid you adieu.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Drakiv (12-18-2015), MisterSheep (01-15-2016)
Old 01-14-2016, 09:10 PM   #5
Drakiv
Project Shadow
Drakiv's Avatar
Got my Intec hi mount brake light and Valenti taillights installed that I got for Christmas. I just recently got around to installing them.
614whp/421tq on E85
Instagram: Drakiv
austinbrz (04-26-2016), MisterSheep (01-15-2016)
Old 01-15-2016, 11:36 AM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I've been in the same exact boat as you lately.. Been considering selling the FRS for a new EVO but the more and more I think about it the more I love my FRS. So in the future I plan to go down the same route as you, turbo with built engine. I really miss having the power of my old 94 twin turbo Z. But this car definately has the better feel to it and might be as tail happy as my old Z. Nonetheless I hope you have fun building your BRZ!
Instagram: trevor.parque
Drakiv (01-15-2016)
Old 01-27-2016, 09:39 PM   #7
Drakiv
Project Shadow
Drakiv's Avatar
Ordered up my Forgestar F14 rims, got my Velox LCA's. Looking to get a set of Feal coilovers, and am in talks with PAR to get a new straight cut gear set. Will post pictures as everything starts to come in, for now here are the LCA's.
614whp/421tq on E85
Instagram: Drakiv
Old 02-26-2016, 10:54 AM   #8
Drakiv
Project Shadow
Drakiv's Avatar
Installed red RallyArmor mud flaps yesterday, they came out pretty good. I also got my Seibon Carbon Fiber TS hood the other day, I am just waiting on my Aerocatch hood pins to come in so I can install it.
614whp/421tq on E85
Instagram: Drakiv
The Following User Says Thank You to Drakiv For This Useful Post:
MisterSheep (02-26-2016)
Old 02-26-2016, 11:41 AM   #9
MisterSheep
Killed Scion
I see you changed the title.
go_a_way1 (02-26-2016)
Old 02-26-2016, 02:37 PM   #10
Drakiv
Project Shadow
Drakiv's Avatar
I did, what do you think?
614whp/421tq on E85
Instagram: Drakiv
Old 02-26-2016, 02:43 PM   #11
Cop
Cop's Avatar
Drives: 2013 FRS
Wouldn't black snow be disgusting
Cop is offline   Reply With Quote
The Following 2 Users Say Thank You to Cop For This Useful Post:
go_a_way1 (02-26-2016), MisterSheep (02-26-2016)
Old 02-26-2016, 02:43 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Honestly I dont get it?
Old 02-26-2016, 02:44 PM   #13
MisterSheep
Killed Scion
How about?
gozen reiji 午前零時 - midnight
or
Mayonaka  真夜中 - midnight,deep night
Old 02-26-2016, 02:48 PM   #14
Cop
Cop's Avatar
Drives: 2013 FRS
How about?
or
I'm partial to
川側の雪の中で黒鬼 - black demon in the snow by the river side
Looking to join the FRS community soon humdizzle Scion FR-S / Toyota 86 GT86 General Forum 18 05-11-2015 11:21 AM
Never Miss Out Again - Join Us On #Twitter Jason@DSG Announcements, Contests, Giveaways 3 01-18-2014 06:08 PM
**VALENTINE ONE GIVEAWAY** JOIN HERE Massdrop Audio/Visual, Electronics, Infotainment, NAV 0 08-15-2013 02:08 AM
About to join the elite SubaSteve BRZ First-Gen (2012+) -- General Topics 22 07-02-2013 09:05 PM
Join us on Instagram DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 05-08-2013 09:31 PM
