Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-18-2016, 04:45 PM | #29 | |
But the length of the runners on the JUN manifold appear to be around 4 inches shorter than the OEM manifold. And the "powerblocks" are only about an inch tall, so the net change isn't a wash, it is still a substantially shortened runner which may explain some of the top end gains. Chase Engineering |
The Following User Says Thank You to GrimmSpeed For This Useful Post: | Captain Snooze (11-18-2016) |
11-18-2016, 05:43 PM | #30 | |
Because compromise ®
Drives: Red Herring
11-18-2016, 06:33 PM | #31 |
Anti stance.
The intake with spacers makes more power in the same rev range.
11-18-2016, 11:03 PM | #32 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Some pics I forgot
JUN Instruction Manual
Closeup of the goodies HKS Racing Single exit Picked up the car this morning. Car definitely loves being in the higher RPM range. Power doesn't taper off as it used to in the higher revs.
[CENTER]
Build thread |
The Following User Says Thank You to stevo_12v For This Useful Post: | Hyper4mance2k (12-13-2016) |
11-19-2016, 06:11 AM | #33 |
Drives: '15 BRZ RA
This intake manifold is designed for a high revving NA engine. You'll need to build now the engine with their forged aluminum piston kit and their rods. The pistons are build in Capricorn Germany and they increase the compression ratio to 13.0:1. I am sure that after the engine build, you'll have the strongest NA build running on pump gas. Forget all these guys trying to build such a car the last 3-4 years. They're just promising all these years and still have nothing.
Btw., I don't agree to install a turbo. Your changes are focused more for a NA setup . |
The Following User Says Thank You to nikitopo For This Useful Post: | stevo_12v (11-19-2016) |
11-19-2016, 12:12 PM | #34 | |||
...Just add nauseum
Drives: 2003 (AP1) S2000
The powerband didn't change at all, the shape is identical. It just moved up in the rev range. That is all. Peak torque didn't appreciably change, I don't have to see the graph to know that. Again, it shifted it higher in the rev range, and the power gains are proportional, because power = torque x speed / constant. JUN runners are very short. Add blocks, they are still shorter, just not super short. I'd bet money, if you pulled the blocks, peak torque would move up another 300-400 RPM, and peak power would follow it on up.. Shorten the runners, the powerband will move up again, unless the plenum volume or throttle diameter becomes insufficient. That will eventually kill torque. You can't push it up forever. They didn't show the torque curve, but here's the relevant point: OLD peak power: 190 @ 6400 RPM OLD peak torque, calculated: 155.9 ft/lbs NEW peak power: 201.9 @ 6700 RPM NEW peak torque, calculated: Drumroll please.... The very same 155.9 ft/lbs The car will be faster, reflected in the peak power increasing, but torque didn't change. I'm thrilled with the outcome of this experiment. Thanks OP, enjoy your money well spent. Yes, the HP/$ ratio isn't stellar, but there's something special about NA power, especially since nobody else has been successful in making much of it. Quote:
I will disclaim that this is ballpark math from looking at the graph, and there may be small variations if it's done more precisely, nothing is perfect in the real world, but It's close enough to make the point.
Inline 4 is best 4
There are many ways to displace. -Spartarus Last edited by Spartarus; 11-19-2016 at 01:45 PM. |
The Following 3 Users Say Thank You to Spartarus For This Useful Post: |
11-19-2016, 02:56 PM | #35 | |
[CENTER]
Build thread |
11-19-2016, 03:28 PM | #36 |
...Just add nauseum
For somebody who likes to run right up to the rev limiter, that is some fat area under the curve at the top.
Peak is off less that 2 n/m from the looks of it... less than 1 foot pound difference, so the math holds up. The jungle below 5000 rpms is always interesting in these cars... This is a funny little engine. If you get it to 8k eventually, hanging on to a lower gear for an extra several hundred RPM is transformative, especially if the powerband holds up.
Inline 4 is best 4
There are many ways to displace. -Spartarus |
11-19-2016, 05:07 PM | #37 |
Drives: Red Herring
Thank you for the detailed explanation.
11-19-2016, 05:11 PM | #38 |
Drives: frs
11-19-2016, 05:51 PM | #39 | |
[CENTER]
Build thread |
The Following User Says Thank You to stevo_12v For This Useful Post: | Teseo (11-19-2016) |
11-19-2016, 09:15 PM | #40 |
Drives: Late 2014 Subaru BRZ
JE has 13.5:1 pistons you might want to think about for your built NA car. Ive used them in my turbo busa and nothing but fantastic results.
http://www.jepistons.com/Catalogs/Sp...baru/fa20.aspx I hope to see you qt 230bhp or ill be sad
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
11-19-2016, 09:57 PM | #41 |
Drives: 2016 Hyperblue Brz
Hi Stevo, what kind of reverse light is that? Could you post a link to that light? I like it quite a lot. TIA
11-20-2016, 01:23 AM | #42 |
Drives: '15 BRZ RA
Similar Threads | ||||
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion | Xero-Limit | Engine, Exhaust, Transmission | 42 | 04-27-2017 09:16 PM |
Automatic Transmission Surge | N1rve | Issues | Warranty | Recalls / TSB | 25 | 03-16-2016 10:58 PM |
Fuel surge issue??? | owenxguo | Tracking / Autocross / HPDE / Drifting | 1 | 12-22-2014 09:58 PM |
SBD turbo surge?? | shif7i7down | Forced Induction | 72 | 11-20-2014 09:49 AM |
Automatic FRS Surge in Manual Mode | N1rve | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 12:28 PM |
