Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Engine Swaps
Old 05-27-2020, 04:51 PM   #127
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by solidsnake11 View Post
Vtec is now working!
Vtec is amazing!!!! I would say its a 130rwhp kick
Reminds me of an old quadrajet on a healthy V8.
logs show this
Vtec off 7000rpm 293gs at 15lbs
Vtec on 7000rpm 432gs at 14.5lbs
The new K20 turbo doesn’t have traditional VTEC on the intake. I guess the idea is that the turbo does enough work. The heads have less flow too. VTEC on the exhaust helps with spool I guess.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
solidsnake11 (05-27-2020)
Old 05-28-2020, 09:02 PM   #128
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've never understood this. If there's that much of a power increase that only means you should have been on that cam sooner. If you're after the max area under the curve the transition should be smooth as the power of one cam drops off and the other comes on.
The Following User Says Thank You to Calum For This Useful Post:
solidsnake11 (05-30-2020)
Old 05-28-2020, 10:25 PM   #129
solidsnake11
Drives: brz
Well 130rwhp at 7000rpm. Boost is hitting about the same time the vtec comes in, it spool faster when vtec hits.
Without vtec it does not spin in 2nd gear.
With vtec it cuts loose when vtec turns on and the boost ramps in.
130gs more at 7000rpm
It pulls harder at 15 lbs than fa20 did with 22lbs.
I drove around a week without vtec and their is a huge difference without it and with it.
Cam goes from a 256 duration to 308 duration with more lift and a stage 3 cam will give another 40rwhp.
solidsnake11 is offline   Reply With Quote
Old 05-31-2020, 10:10 PM   #130
solidsnake11
Drives: brz
10lb boost Launch and flat foot shifts. let off at 95mph
What a blast!
Just a little hard to pedal and use flat foot shift in 1st and 2nd.
So what is closing the throttle is it the vsc still active even with it off or is ecutek closing it. This is in first gear Traction control was held down to disable.
The Following User Says Thank You to solidsnake11 For This Useful Post:
tomm.brz (06-01-2020)
Old 06-01-2020, 04:00 AM   #131
tomm.brz
Drives: brz 2017
you have to push trc off for 4 seconds to completely disable and allow spinning
vsc is not enough
if you see accel100 and throrrle closing normally is because of wheel spin
if you press trc only quickly it wont disable it totally and it will deacticate after 50km/h
tomm.brz is online now   Reply With Quote
solidsnake11 (06-01-2020)
Old 06-01-2020, 07:11 AM   #132
solidsnake11
Drives: brz
I held it down till both lights came on. You can see them in the video lit up.
Old 06-01-2020, 07:58 AM   #133
tomm.brz
Drives: brz 2017
then no idea at the mom, it looks like a traction control cut but i can't help you
Try pedal dance
or even the pedal dance that ecutek offers in the app, it s at the end of the list under DTCs, called Traction Control i think
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-20-2014 11:16 PM
Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) TM Photos, Videos, Wallpapers, Gallery Forum 26 04-30-2014 03:31 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 Photos, Videos, Wallpapers, Gallery Forum 6 11-11-2012 11:29 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
