Engine Swaps Discussion of engine swaps. |
03-05-2020, 04:02 AM | #1 |
Drives: FRS
Swapping 2016 MT engine into 2013 MT
Just pulled the motor since the one in the 2013 blew. Is the 2016 engine a direct swap into the 2013? Both are MT. Is there anything i need from the 2013 to make it work? I dont need to flash anything to the ECM if im using the old ecm & tranny right?
Not even gonna bother with the 2017+ motors since there a ton of work involved and i just want to get the car running. Then i’ll probably build a engine and slap the turbo back on |
03-06-2020, 02:09 PM | #2 |
Drives: 2013 FR-S Ultramarine
Should be a straight easy swap. No need to flash the ECM. If you can grab the trans with the motor as well, that will make it an even easier swap.
I crashed my FRS at the track, bought a BRZ with a spun bearing. I swapped the motor and trans from my FRS to BRZ and had it running on a Monday evening after work. |
03-06-2020, 06:20 PM | #3 | |
BAE
Drives: Asphalt FRS
The Following User Says Thank You to Decimus For This Useful Post: | Opie (03-10-2020) |
03-06-2020, 06:50 PM | #4 | |
Drives: 2017 Toyota 86
03-06-2020, 08:15 PM | #5 | |
Drives: RX-7 / BRZ
Nope. Just a little work involved if swapping over some parts or removing them if your replacement engine didn't have the same transmission option. Manuals just have a block-off plate.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following 4 Users Say Thank You to Kiske For This Useful Post: |
03-10-2020, 12:19 PM | #6 | |
Drives: '13 BRZ TLM Spec
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
03-11-2020, 01:39 PM | #7 | |
Drives: FRS
P.S. I was also able to get a tune for my flexfuel kit too so didn't have to drain all the E85 from the tank. |
03-12-2020, 01:07 AM | #8 | |
Noob
Drives: FR-S Mammogram
Thought about the '17+ motor, but I've heard it's not worth it for all the hassle.
03-12-2020, 02:05 PM | #9 |
'17+ should be plug and play, but may need a tune or a '17+ ECU to make the 2017 power.
03-13-2020, 07:54 PM | #10 | |
BAE
Drives: Asphalt FRS
I came upon this video, and its very very detailed. Guy uses 2019 engine but swaps over all the 2013 components to make it work. Worth watching if you have the time and need to do the swap. [ame="http://youtu.be/pqxW9UNMBUU"]http://https://youtu.be/pqxW9UNMBUU[/ame] |
The Following User Says Thank You to Decimus For This Useful Post: | EndlessAzure (05-17-2023) |
03-14-2020, 05:14 PM | #11 |
Noob
Unfortunately not plug and play from the various people I've seen do it.
03-14-2020, 05:15 PM | #12 | |
Noob
in case it doesn't show for others. I had to click reply to see the YouTube link.
The Following 2 Users Say Thank You to Jyn For This Useful Post: | Decimus (03-15-2020), Hypnocracy (03-19-2020) |
03-18-2020, 01:23 PM | #13 | |
Drives: FRS
Reason I ask is that I am in the same boat that I have a spun bearing and need a replacement motor. I have a 2013 FRS and am able to locate a 2015 motor (not planning on getting the tranny). Just researching to ensure that this is possible with no issues. |
Similar Threads | ||||
2016 frs engine | Doctordiode | Engine Swaps | 18 | 06-19-2020 12:28 AM |
WTB: (CA) 2013-2016 FRS BRZ Engine | Decimus | Want-To-Buy Requests | 0 | 02-28-2020 01:21 PM |
The most expensive part of engine swapping; software. Why? | AutoNewb | Engine Swaps | 16 | 11-23-2019 04:55 PM |
Engine swapping my first car. | MK42Dragon | Engine Swaps | 23 | 04-01-2018 06:55 AM |
Need help with swapping engine FRS | frsnick | Engine, Exhaust, Transmission | 16 | 05-11-2016 03:09 PM |
