Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-31-2020, 06:36 PM | #1 |
Drives: Drives like a crab.
Do all catless header sound like complete garbage?
Hi everyone,
I recently installed an OFH 2 UEL catless header on my 2013 GT86 and it sounds like crap. I mean, almost like there's a leak. Except there's none! It sounds like my exhaust is made of coke cans. Sounds like a helicopter, almost. Do you see what I mean? Here's what I've done: 1. I installed the header with 3 new gaskets - sounded bad 2. I retorqued everything to be absolutely sure everything was perfectly installed - still sounded bad 3. I unmounted the header, noticed a very very small crack (it's second hand) - rewelded it and rebolted the header after polishing the block, header and overpipe flanges and applied some Holts Firegum on the header to overpipe section - still, no improvement 4. Retorqued everything again after driving just to be sure. Still bad I already had that problem with a gutted stock header but assumed it was the empty cat that was creating some resonance. So, simple question: Do all catless header sound "tiny" like described above? Can't even say it's because of the thinner stainless steel, it does it with a the gutted stock header as well. Thank you for your inputs |
01-31-2020, 06:52 PM | #2 |
Personally I found a catless UEL header to be obnoxiously loud on a NA car with a 2.5" XForce or decated OEM header back exhaust.
So much so I removed the Tomei UEL header within 2 weeks of installing it and replaced it with a decated OEM header. I never found the OEM decated system tinny. And I decated both the hesder and front pipe. I currently have an UEL header with my AVO turbo setup, but the turbo does an excellent job at muffling the noise.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
The Following User Says Thank You to 86MLR For This Useful Post: | HaXx (02-21-2020) |
01-31-2020, 07:04 PM | #3 |
Drives: JRSC BRZ SOLD
I have a catless HKS header, resonated front pipe and resonated Perrin exhaust. I have zero raspiness. I could see the oem exhaust not being able to tone it down.
01-31-2020, 07:26 PM | #4 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I have catless HKS headers and their R-Spec front pipe and find the tone just fine.
01-31-2020, 09:16 PM | #5 |
Drives: 2013 frs red
No drone or raspiness with my ofh. Completley stock from header back
01-31-2020, 09:34 PM | #6 |
Drives: 2017 BRZ w/PP
you have uel they are designed intentionally to sound like trash.
i have ace headers and as of right now stock everything behind the merge and think it sounds fine. i will be pick up a 60s tomorrow so its probably going to sound like shit. ill probably get a custom straight through on the end or something |
01-31-2020, 10:35 PM | #7 |
My catless JDL 4-2-1 EL sounds great with a stock FP with stock resonator removed and a nice vibrant resonator added in place and a mxp SP catback
2013 Series 10 FRS #553
01-31-2020, 10:42 PM | #8 |
Rust bucket enthusiast
Unequal length is literally the sound of poor design. With that said, a catted UEL header gets the lumpiness without the bark
The Following 6 Users Say Thank You to DarkPira7e For This Useful Post: | DylanJZA (02-02-2023), lamawithonel (02-01-2020), mrg666 (02-01-2020), RToyo86 (02-03-2020), TylerLieberman (07-18-2020), Ultramaroon (01-31-2020) |
01-31-2020, 10:48 PM | #9 |
義理チョコ
Nothing says performance like the sound of a dead cylinder.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post: | DarkPira7e (01-31-2020), DylanJZA (02-02-2023), korhun (02-04-2020), lamawithonel (02-01-2020), mrg666 (02-01-2020), PulsarBeeerz (02-01-2020), soundman98 (02-01-2020), Tanstin (07-27-2020), TylerLieberman (07-18-2020) |
02-01-2020, 03:10 AM | #10 |
I don't think the problem is EL/UEL.
It sounds like there's a leak. You see what I mean when I say the "helicopter sound", on throttle? Like pulses are resonating against thin metal. I don't have the problem with a catted stock header. Had the problem with a gutted stock header that had the heat shield removed. Might try putting it back on and see what develops. |
02-01-2020, 07:53 AM | #11 | |
02-01-2020, 08:03 AM | #12 |
Drives: 2014 Subaru BRZ Limited MTblue
I was never happy with the quietness of the stock exhaust. (MY14) Did some reading and decided to keep stock EL header. Although I replaced the CAT with a straight section of stainless and replaced the O2 sensor bungs. It still didn't really sound like a sports car. Next I removed the muffler unit and replaced it with a single pipe to the left exit. I love it! No rasp! Very little cost! ( I intend to replace my muffler delete with a nice one, though.)
Sent from my XT1254 using Tapatalk |
02-01-2020, 11:30 AM | #13 |
02-01-2020, 11:34 AM | #14 | |
Similar Threads | ||||
Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? | l3ooml3al2al3a | Engine, Exhaust, Transmission | 12 | 03-22-2019 10:22 AM |
Sound Clip of Catted UEL Header with Catless Front Pipe | lc300 | Engine, Exhaust, Transmission | 1 | 03-21-2019 05:24 AM |
Catted Front Pipe w/ Catless Header sound difference? | HeresMyMind | Engine, Exhaust, Transmission | 6 | 09-19-2018 09:05 PM |
catless header vs catless frontpipe | steveholt | Engine, Exhaust, Transmission | 30 | 10-10-2017 07:13 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
