Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-05-2015, 12:46 AM | #1 |
Drives: 2014 BRZ Limited 6M
Noise in the Rear with ST Coilovers
Ever since I've installed a set of used ST coilovers, there has been a very pronounced clunking and thumping noise coming from the rear. I've went the distance to torque every bolt of the suspension, but to no avail...
The last attempt my friend and I did was to tighten the top nut of the rear coilovers by using a socket to hold the shaft in place while using an allen key to tighten. However, no matter how much we tighten, it would not fully tighten. It would get tighter at certain degrees, but then it gets light again. I was wondering if anyone else has this issue. I had Stance Coilovers in the past and they would only clunk below 15 mph. The current noise produced by my set of ST is definitely worst. |
04-05-2015, 07:12 AM | #2 |
Drives: Whiteout FRS
I had a similar issue. However, I just needed to zip the nuts on with an impact gun. Take the nut completely off, lightly hand thread it a turn (So the gun can get some momentum), and zip it on.
Hope this helps! |
04-05-2015, 11:18 AM | #3 |
Torque the lower steut bolt to 90 ft lbs. That's where my noise keeps coming from. I just keep re tightening.
Should probably buy new oem bolts at some point. |
04-05-2015, 11:36 AM | #5 | |
Drives: FRS
04-05-2015, 12:10 PM | #6 |
Yea didn't notice that sentence, take the coilover off and take that nut off and see what's going on
04-07-2015, 11:12 AM | #7 |
Drives: FR-S 10 series
Top nut is most likely your issue, especially if it wasn't tightened correctly (as in using a key to keep the shock from spinning while tightening the top bolt). I had all kinds of noises for a week until I took the time to correctly torque the top bolt.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
05-01-2015, 08:40 PM | #8 | |
Drives:
projekt zeal86 build |
05-01-2015, 10:21 PM | #9 |
Drives: JRSC'd Asphalt FR-S
Use a pass thru wrench and use a 10mm socket to put on top and it'll hold it in place.
Tags |
clank, clunk, coilovers, noise, st coilovers |
Similar Threads | ||||
Noise coming from rear of car | B-R-Z | BRZ First-Gen (2012+) -- General Topics | 9 | 05-30-2017 06:04 AM |
Strange Noise from rear of car while OFF | mike2100 | Issues | Warranty | Recalls / TSB | 23 | 12-17-2014 08:14 PM |
ST coilovers noise | b rawr z | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-24-2014 11:08 AM |
Noise coming from the rear end... | jm1681 | Issues | Warranty | Recalls / TSB | 17 | 03-13-2014 07:30 PM |
rear brake noise | norcal_brz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-19-2013 03:25 PM |
