Old 11-26-2013, 03:57 AM   #99
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Amir Ghadiri View Post
The clutch mod wouldn't affect these problems. My clutch damage was caused by the transmission grind, moreover by the clutch bouncing off the flywheel when the transmission grinds mid shift. This is what caused the spring failure, causing the clutch to self destruct (for lack of a better word). The picture I posted didn't show it well, but one of the 4 springs in the clutch assembly failed and caused this pressure plate to come apart. This is also what caused the discoloration. For what it's worth, my car did not have the clutch mod.
That makes no sense.
The clutch would have been fully disengaged with big clearance from the flywheel, surely?
sierra is offline   Reply With Quote
Old 11-26-2013, 05:14 AM   #100
Poodles
Drives: 2015 Series.Blue
Not quite. When a transmission is out of synchronization, it will cause clutch chatter. Clutch chatter, in short terms, is the clutch bouncing on and off the flywheel, repeatedly grabbing and releasing it until the clutch finally engages. Clutch chatter causes springs to fail, which in turn causes clutches to detonate.
It's crazy to think that all of this could be caused by a prematurely worn synchroid, but chances are it was.
This would only be true if the clutch disk wasn't floating on the splines, which it does. If it didn't float, that could the issue.
You either have clearance or you don't in the system, nothing the transmission does is going to affect the clutch in this way.
The Following User Says Thank You to Poodles For This Useful Post:
andrew20195 (11-26-2013)
Old 11-26-2013, 01:44 PM   #101
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Holy hell, that's not good. Not a very welcome update.
DoomsdayJesus is offline   Reply With Quote
Old 11-26-2013, 02:42 PM   #102
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Originally Posted by charged86 View Post
This is fucking stupid. My fourth always grinds above 4500 regardless of throttle position. My have my tranny rebuilt to fix the faulty syncro. Then I will ejaculate all over the old one and mail that to Subaru of America
this made my day.
sprintertrueno86 is offline   Reply With Quote
Old 04-19-2014, 04:17 AM   #103
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by infinite012 View Post
From your Porsche/Aisin link:
I'd like to see what kind of fluid Aisin is putting into the Porsche 911 transmissions.
I'm pretty sure it is GL-5.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 04-19-2014, 04:21 AM   #104
zdr93523
zdr93523's Avatar
Originally Posted by Gen View Post
Mine grinds into 4th unless I am VERY slow and deliberate with my shift (I have to wait for the engine to fall 2-3k RPM). Clutch pedal is at stock height and I'm on the stock clutch. However, I'd be curious as well.
Mine is the same.
www.makesmodels.com
www.camautomag.com
Old 04-29-2014, 01:15 AM   #105
zdr93523
zdr93523's Avatar
Update: Subaru is replacing my transmission next week when it comes in. It only took me taking the service manager for a ride, a quick call to the SOA rep by him, and in 30 minutes my transmission was on order. We are going to fill the new one with Motul 300.
Sent from my LG-D800 using Tapatalk
www.makesmodels.com
www.camautomag.com
5th Gear "Mini-Grind" BRianZ Issues | Warranty | Recalls / TSB 63 07-18-2015 05:12 AM
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 12:08 AM
New "Drive Clean" on wheel repair and fitment SkAsphalt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-10-2013 05:59 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
16" Subaru Steelies $39.99ea limited to 4 sets Stav Canada Classifieds 5 01-03-2013 11:15 PM
