01-25-2015, 06:11 PM | #169 | |
just do a couple of revisions like @JB86'd did and you should be fine. I would copy his changes from the IAT compensation table though to make compensation cut in a bit earlier. you will probably have to put up with the occasional bit of correction of 0.7 or less on occasions. the only other thing would be to smooth the entry and exits in your changes to base_timing_B like on JB86'd example Last edited by steve99; 01-25-2015 at 11:08 PM. |
The Following User Says Thank You to steve99 For This Useful Post: | JB86'd (01-25-2015) |
01-28-2015, 08:13 PM | #170 |
Drives: 14 Ultramarine FR-S
Here's a new log! Still using my first revision.
http://datazap.me/u/phantobe/2nd-3rd...=0&data=1-4-14 Lowest I seen my IAM drop is .88. Looks like I can fine tune it a bit more. What do yah think? :S @steve99
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
01-28-2015, 09:08 PM | #171 | |
yes looks like another 0.7 or so pulled from 5000-7000 loads 1 to 1.4, then have a look round the 1500 to 3000 area for any knock correction once the IAM gets back to 1 |
01-29-2015, 08:00 PM | #172 |
Did a 2nd gear pull today and noticed some positive FLKC values (IAM was approx .94), does this indicate that I should add timing to these locations & perhaps I pulled too timing?
01-29-2015, 10:48 PM | #173 | |
i would not add any timing till your iam is 1 and yur seeing no knock events . read lnk below on "flashing reset learning" and try the vishnu reset trick to bump your iam to 1 then check for knock again |
01-30-2015, 02:14 AM | #174 |
any worry on these track logs at mrls? http://www.datazap.me/u/xero404/mrls...4?log=0&data=2
tried to use the new alerts but i'm pretty new to this tuning thing and didn't know what things to look out for. i did notice that oil temp wasn't one of the options for the alerts. |
02-01-2015, 04:44 PM | #175 |
Drives: Asphalt Scion FR-S
Running the 2.063 Stage 2 EL E85 map, all I did to it was Adjust Fuel Cut up to 7800 so that i dont have to shift to 3rd for 60 now...my AFR at WOT seems... off
http://datazap.me/u/itsjustdavep/new...c?log=0&data=1 |
02-02-2015, 07:12 PM | #176 | |
02-02-2015, 07:59 PM | #177 | |
But from this log it looks like you're running too aggressive of a tune, you're pulling a lot of timing you can see this from all the negative FLKC values. Oddly enough your IAM isn't dropping below 0.96. What octane/tune are you running and what mods do you have? I would recommend doing a few 2nd gear or 3rd gear pulls at WOT, you don't need to log for an hr. Just do a few quick pulls at WOT (rev from 2k RPM to redline-ish) & the graph will be much easier to read/analyze.
The Following User Says Thank You to Phantobe For This Useful Post: | xero404 (02-02-2015) |
02-02-2015, 08:06 PM | #178 |
Senior Misanthrope
Any comments or concerns on this? It's a second gear WOT pull. Stock w/ drop-in, running 2.063 stage 2 EL E85 map. No residual petrol left in tank; been running on this tune w/ E85 for several hundred miles.
http://www.datazap.me/u/kch/2nd-wot-...ta=1-8-9-11-12 I'm brand new to data logging and tuning, so bear with me. I'm concerned because I never see my IAM change from 0(?). Also concerned that my KC Learned gets up to 6 at 5k rpm WOT. |
02-02-2015, 08:14 PM | #179 | |
http://www.ft86club.com/forums/showthread.php?t=75315 Looks like something is wrong with your template or something, IAM should be 1.0 (if you're knock free). Also you should be logging FLKC & Knock Correction.
The Following User Says Thank You to Phantobe For This Useful Post: | kch (02-02-2015) |
02-02-2015, 08:23 PM | #180 | |
Data Logs! Post them here.
Engine Mods include Tomei UEL headers, Crawford BPBs and an Apexi Drop In Filter. I am currently running the beta 91 BPB beta tunes on chevron 91 octane. The logs i posted were for my entire session at Laguna Seca to see how the tunes will do in a harsh conditions being run on the track, thus the long time of them. I'll have to do a couple 2nd gear WOT logs soon and post them up. Last edited by xero404; 02-02-2015 at 09:03 PM. |
02-02-2015, 08:27 PM | #181 | |
Senior Misanthrope
02-02-2015, 08:38 PM | #182 | |
However it depends what you want to do, there is plenty of information on this forum to customize the tune yourself. But if you don't want to invest the time, Shiv is the way to go. I assume the BPB tunes have a tune that account for catless headers (not sure dont have BPB)?
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
