Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-21-2020, 01:35 AM | #29 | |
Drives: 87 Supra, 13 FRS, 05 FXT
Do not buy this one. I had it on my car and it failed. It worked great the first 100mi or so but it started to get crunchy and also started squealing. The idea is great, and I really wished that it worked but in the end go with OEM. |
The Following User Says Thank You to thatfilipinoguy For This Useful Post: | NoHaveMSG (10-21-2020) |
10-21-2020, 08:41 AM | #30 | |
10-21-2020, 07:39 PM | #31 |
Drives: 2015 BRZ Limited
At how many miles are people having TOB issues?
Bone stock
10-21-2020, 08:04 PM | #32 |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
10-21-2020, 08:37 PM | #33 |
Drives: '13 BRZ Limited
10-22-2020, 09:01 AM | #34 | |
Drives: 2016 Scion FRS Release Series 2#439
10-22-2020, 11:54 AM | #35 |
Drives: 2023 BRZ
The Sachs unit is most definitely not similar to OEM.
The Following User Says Thank You to Pat For This Useful Post: | Tcoat (11-25-2020) |
11-24-2020, 07:38 AM | #36 |
11-24-2020, 08:40 AM | #37 |
Identifying as a Member
Drives: 2013 FRS LS1
95,000mi
I'd say that's a good life for a tob. Replaced it with another exedy. 10k miles in no issues.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
The Following User Says Thank You to Tomm For This Useful Post: | holeeray (11-24-2020) |
11-25-2020, 05:42 AM | #38 | |
Best replacement TOB
Sorry for the slow reply. I’d have to check to be sure but I’d say about 28k miles. I still haven’t replaced it but it’s making all kinds of noise now. I’ve been too lazy to deal with it. But yes it was the new part number with the white dot. |
The Following User Says Thank You to ermax For This Useful Post: | Tcoat (11-25-2020) |
11-25-2020, 06:15 AM | #39 |
In the FRS my first one lasted about 40,000 miles. The second about 100,000.
If going OEM just make sure you get the most recent part number. There are at least 4 different versions of OEM floating around out there. Even the white dot one has been replaced with one with no dot. It is a crap shoot really.
01-20-2021, 08:16 PM | #40 |
Drives: 2013 Raven FR-S
The 2nd TOB on my FRS is about to go out. This one has around 55k miles on it now. As I remember the original one had a little more than that. Has there been any consensus on exactly which part number lasts the longest? Doing this every 50k miles or so is ridiculous.
01-21-2021, 04:21 PM | #41 |
Drives: 2015 Scion FRS - Raven
If you are changing your throw out bearing I would also recommend to change the transmission input shaft housing. I've seen it where the bearing is new but because of the heat the plastic part in the center of the bearing can catch on the outer cylinder of the housing even when greased up. I believe part is about $100 through the dealer.
The Following User Says Thank You to TRAKRAVN For This Useful Post: | smg1138 (01-22-2021) |
01-21-2021, 04:23 PM | #42 |
My case was a "new" bearing, I'm not sure if it was updated or not with the forged clutch fork. and the solution was changing the transmission input housing.
Similar Threads | ||||
Hip replacement and the BRZ | g e | BRZ First-Gen (2012+) -- General Topics | 10 | 07-06-2018 06:12 AM |
Replacement Key | 86 South Africa | AFRICA | 7 | 09-19-2016 03:58 PM |
Replacement fun? | Mooseknuckle44 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-01-2014 11:46 AM |
TPSM replacement | nabil_frs | CANADA | 4 | 04-27-2013 11:58 AM |
TPSM replacement | nabil_frs | Issues | Warranty | Recalls / TSB | 2 | 04-26-2013 09:57 PM |
