Old 05-28-2021, 04:08 PM   #15
dedpedal
Drives: Nissan 370z, Toyota GT86
lack of updates, but out of the many, here's some pics of the completed subframe
any rust sanded down, shaved off extra tabs, & painted with Steel-it.
Super Pro bushings installed
dedpedal is offline   Reply With Quote
The Following User Says Thank You to dedpedal For This Useful Post:
Thefalls (05-28-2021)
Old 06-03-2021, 11:15 AM   #16
dedpedal
Really just some superficial updates right now (alot of data collection been going on recently so not much movement in the garage)
I did pick up my wheels though
18x10.5+22, 5x114 (yes 5x114)
set of 9.5s are on order, about 10 weeks out...
Old 06-07-2021, 12:26 PM   #17
dedpedal
I won't be doing a full rebuild with this motor because the point is to get it running so I can enjoy it while driving. Major seals will be replaced though while its in this accessible state. Figured why not clean it up a bit too? So i got into each runner / port and did some grime clean up, It'll do.
Replaced the corroded studs on the intake side.
I then installed my OMD San Diego VVT cancellation plugs (been waiting to get to this part!) These aren't just simple plugs though! These are notched to allow more oil pressure and flow for the cams. Something that should give a peace of mind when I rev the engine to 8k. Plus the subtle weight reduction is always a plus.
Got to love when your spare parts work out, I have a bunch of these VQ exhaust studs from spare motors that I have.
As of right now engine cleaning is done -aside from the valve cover, but that's on hold untill we can setup the timing
The Following 2 Users Say Thank You to dedpedal For This Useful Post:
Irace86.2.0 (06-27-2021), Stonehorsw (06-09-2021)
Old 06-09-2021, 11:48 AM   #18
dedpedal
Shout out to Tommy Roberts for spending some time with me and gathering all the parts from Parts Shop Max as I request
You'll see a hint here of what's to come in the future too!
I was able to make a full set of coilovers to my spec with the new parts and my spares.
The struts have just about 20-25mm more stroke than the typical coilover that's out there for the platform.
I paired the front with a bearing spring mount and custom camber plates
Daily driving 6kg front and 4kg rear feels amazing. But with more aggressive driving it's quite soft. So as of right now I'll be using 8kg front and 6kg rear, both at 178mm spring height.
Old 06-12-2021, 02:11 AM   #19
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
nice build, see ya around sd
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
The Following User Says Thank You to EdBoy For This Useful Post:
dedpedal (06-14-2021)
Old 06-14-2021, 10:58 AM   #20
dedpedal
Got the subframe swapped on a sunday afternoon
5x114.3 wheel hubs
Part Shop Max diff risers
Custom coilovers
Unfortunately my Altezza Cusco LSD isn't going to work as I just found out that the Altezza comes with smaller stub axles, thus not working for my GT86. With that said I have a full Altezza pumpkin with a cusco RS LSD with stub axles for sale haha (i'll verify final gear tomorrow)
I am glad though, that I got to take off the old subframe. It gave me the opportunity to address the rust that I wasn't even aware about. Luckily it's only on the bolt side, not the chassis.
Old 06-14-2021, 10:06 PM   #21
DiscoQuinn
DiscoQuinn's Avatar
Drives: 2017 BRZ
Originally Posted by dedpedal View Post
Woah???? different splines, or??? What makes them different. This is interesting to me.
DiscoQuinn is offline   Reply With Quote
Old 06-15-2021, 02:54 PM   #22
dedpedal
Altezza with beams comes with smaller splines (diff itself is less than the "normal" 200mm diff for IS300)
Altezza diff can be swapped into IS300 if you transfer the stub axles with it.
Old 06-16-2021, 02:54 PM   #23
dedpedal
first test drive after all the rear end work
Old 06-17-2021, 09:00 AM   #24
dedpedal
Stopped by OMD and got my throttle body and fuel rail modified, I also picked up my injectors!
Berserker (06-17-2021)
Old 06-17-2021, 10:30 AM   #25
Berserker
Great job on everything so far!! This thing is a beaut
Berserker is offline   Reply With Quote
The Following User Says Thank You to Berserker For This Useful Post:
dedpedal (06-17-2021)
Old 06-21-2021, 12:01 PM   #26
dedpedal
Just some appreciation shots of progress and well made OMD TB adapter, couldnt help myself!
Search this Thread:
Advanced Search
Flipedge - Kouki GT86 Build Flipedge Member's Car Journals 1 12-10-2018 02:12 PM
AJ's Turbocharged GT86 Build ASHRAF Member's Car Journals 16 05-29-2017 05:15 PM
ck-GT86's Build ck-GT86 Member's Car Journals 37 07-14-2016 11:40 AM
fully build turbo fr-s/gt86/brz Baramzisyan Want-To-Buy Requests 15 03-22-2014 03:26 PM
NST GT86 MTM build Asurendra AUSTRALIA 25 01-03-2013 05:58 AM
