Old 03-01-2022, 12:13 PM   #1
Lemming
Drives: 2022 GR86 - Halo White
Lightweight battery options for daily driver
Anyone change out their stock battery for something lighter yet? What battery and mounting solutions have you come up with?
I slightly scrape on my driveway and am fixing this by getting taller tires and reducing battery weight. Hopefully this will be enough to stop it from happening.
Lemming is offline   Reply With Quote
Old 03-01-2022, 12:22 PM   #2
p1l0t
p1l0t's Avatar
Not sure if it will help with scraping but I replaced my battery with an anti-gravity LiFePo4 and saved like 30 lbs.
Old 03-01-2022, 12:37 PM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Say sike right now....
spcmafia is offline   Reply With Quote
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
Jdmjunkie (03-01-2022), soundman98 (03-01-2022)
Old 03-01-2022, 01:12 PM   #4
Lemming
I'm serious lol. It's a poorly designed neighborhood easement that I have no control over fixing.
Old 03-01-2022, 01:30 PM   #5
spcmafia
spcmafia's Avatar
The cheapest and best solution would be getting curve ramps like BRIDJIT or just make a quick trip to your Lowe's / H.D and get a wood plank.
soundman98 (03-01-2022), StE92ve (03-01-2022)
Old 03-01-2022, 01:49 PM   #6
alex87f
Meow
alex87f's Avatar
Drives: GT86
The cheapest and best solution would be getting curve ramps like BRIDJIT or just make a quick trip to your Lowe's / H.D and get a wooden plank.
This, or just try a different angle of approach. The gen 1s are cars that scrape surprisingly little for their right height. It's likely true for gen. 2s, if you're scraping then most other non-SUV drivers are too, there's probably a way :-)
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Old 03-01-2022, 02:09 PM   #7
Lemming
Alright good idea. I ordered some rubber curve ramps and will talk to the neighbors about bolting it into the concrete so nobody else walks off with them. Hopefully the city doesn't have an issue with it.
I still plan on getting a lighter battery as I have another vehicle needing a battery replacement that I'm tossing the OEM battery into. Since it's a warm climate here I'm thinking the Deka ETX-30L may be enough.
When I originally tried that it worked okayish without a passenger, but an occupant was enough to make it scrape a bit. Neighbor's porsche scrapes too as did my prior infiniti. An old friend's challenger didn't scrape, but the car got stuck going over the hump in the middle. It's a terrible easement.
Old 03-01-2022, 02:10 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Step 1-Measure ride height.
Step 2-Remove battery and spike on ground, preferably concrete or asphalt.
Step 3-Measure ride height.
Step 4-Realize difference is negligible.
The Following 10 Users Say Thank You to NoHaveMSG For This Useful Post:
alex87f (03-01-2022), Jdmjunkie (03-01-2022), Ohio Enthusiast (03-01-2022), p1l0t (03-01-2022), soundman98 (03-01-2022), Spankopotomous (03-02-2022), Spuds (03-01-2022), timurrrr (03-01-2022), Wally86 (03-01-2022), x808drifter (03-02-2022)
Old 03-01-2022, 02:35 PM   #9
LRNAD90
Drives: X5 35d, D90
Not only will the lightweight battery make no difference in your ride height, today's vehicles have heavy electrical loads. Not sure I see the value in reduced battery capacity (as is likely going to be the case with a 'lightweight battery') for street use. Guessing there are many, many better ways to spend your money..
LRNAD90 is online now   Reply With Quote
Old 03-01-2022, 03:09 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS
I’ve had an odyssey pc680 for 3+ years now, cheaper and almost 15# lighter then stock iirc. Stock lasted a little over five years, this looks like it’ll get me too 4 no problem. No trickle charger or anything, has sat for a week and fired up no problem. Caveat my car has only rarely been below freezing temps overnight.
I used the Japanese tie downs, $30-$40 and waiting a month for shipping, if you’re crafty you could probably do it easier and better fitting, it sill looks like I have the “wrong” size battery but it’s held firmly in place.
https://www.ft86club.com/forums/show....php?p=2746249
And per above your ride height change will be hundredths of an inch at best taking 10-20# off the front.
ineedyourdiddly
NoHaveMSG (03-01-2022)
Old 03-01-2022, 03:23 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am running the PC680 as well. They are tough batteries. I am at about 4 years on mine too.
strat61caster (03-01-2022)
Old 03-01-2022, 03:46 PM   #12
p1l0t
p1l0t's Avatar
The anti-gravity battery is standard group 35 size and actually 1500 cold-cranking amps MUCH better than stock. Weighs like 20lbs less than stock too. It's also smartchip controlled. The only downside is the $800 pricetag absolutely better in all other performance measures.
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
Jdmjunkie (03-01-2022), Pat (03-02-2022)
Old 03-01-2022, 07:18 PM   #13
soundman98
Kustom Fitmenter
soundman98's Avatar
i know only weirdo's do this, anymore, but...
have you tried backing into your driveway?
my rear bumper never scrapes. my front bumper does, but only at high approach speeds when i'm showing off to the neighbor kids..
Old 03-01-2022, 09:22 PM   #14
Lemming
Good idea. This would certainly work since I only scrape coming in. If the rubber ramps don't pan out I'll likely do this.
Best battery for daily driver ScionFR-S Issues | Warranty | Recalls / TSB 132 01-27-2022 10:40 AM
SOLD: SEWI Shorai Lithium Battery and PTUNING Billet lightweight battery tray timepoor Audio/Visual, Electronics, Infotainment, NAV 4 10-06-2021 11:40 PM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
MAW lightweight battery kit. Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-24-2016 07:57 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
