Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 07-23-2014, 12:20 AM   #421
DSOmegaX
DSOmegaX's Avatar
Originally Posted by cslntuee View Post
Yes, I also think that the front spring is different between the ts and the
standard one.
However, I am not sure why DsomegaX got the STI ts dampers combo with the standard STI spring.
http://www.ft86club.com/forums/showp...&postcount=892
I am not sure which back Showa damper you refer.
The new one looks red body for me.
http://www.showa-tuning.com/evolution.html
I heard that STI ts damper also made by Showa and curious those
two are same or not.
Thanks.
The dampers are showa. The springs are different, which I have. Its sold as a set
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
cslntuee (07-23-2014)
Old 07-23-2014, 03:24 AM   #422
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
standard one.
Thanks.
Black as in the ones that come with the car stock.
The tS damper is silver and design is based on the Showa evolution line. It's not red because why would STI simply take something off the shelf, leave it the way it is in appearance and sell it to you (that would go against their marketing of proprietary tuning).
I'm curious as to the difference in handling between stock 2013/2014 and 2015. I wonder if they've made the car more tamed (like late model SW20 and AP2). "Improved handling" should really be "different / revised handling", they obviously can't write "improved handling for street use" because then the racecar ricers like me would think that's weak sauce.
Also, If they follow a similar formula as to the AW11 MR2, then we will probably see an engine option by 2016 that would shift the powerband towards the mid range to be more street friendly (like 4AGZE supercharged vs 4AGE n/a).
I'm still glad Subaru & Toyota decided to give us the same JDM FA20 engine globally to save on development cost.
If they did a FA25 or supercharged FA20 with a lower redline as the only choice for North America, then armchair forum junkies would shit on it for not having a stronger top-end like JDM (EJ20 vs EJ25 on the WRX STI).
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Old 07-23-2014, 08:23 AM   #423
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Originally Posted by iLuveKetchup View Post
I hope they have a real white color not beige like SWP.
IMO SWP looks a lot better than CWP but I guess it depends what type of white you are going for. The CWP is a lot more pure white but I like the hue to the SWP due to the property of satin paint.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 07-23-2014, 08:30 PM   #424
Boxer486
Drives: small
Originally Posted by Toca View Post
The Crystal White Pearl is a tad bit beige with some sparkle...however it isn't creamy like SWP.
Not sure if SWP is the same as Whiteout. If it is, SWP might as well be yellow if you think CWP is beige.
Boxer486 is offline   Reply With Quote
Old 07-24-2014, 05:49 AM   #425
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here are the latest details about the suspension. It is for the GT86, but these changes should be same in all versions:
86 upgraded
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
cslntuee (07-24-2014), krayzie (07-24-2014)
Old 07-24-2014, 09:59 AM   #426
cslntuee
Drives: Subaru BRZ Limited
86 upgraded
It looks like the change related to the suspension is more than the list
as below. (Bolt& Shock Absorber)
http://www.ft86club.com/forums/showp...9&postcount=48
It also wrote "New suspension mounts, and using lower-friction oil, oil seals and guide bushings, have decreased body roll and increased handling stability" in the article.
Any idea what part number for those which potentially we also can
upgrade by ourselves without buying 2015 model?
Thanks.
cslntuee is offline   Reply With Quote
Old 07-24-2014, 01:44 PM   #427
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Since 2015s are on their way to the showrooms, how much less should I expect to pay for a 2014 leftover?
iLuveKetchup is offline   Reply With Quote
Old 07-24-2014, 02:31 PM   #428
BirgeyT1
too soon jr
BirgeyT1's Avatar
Drives: 2014 Sterling Silver BRZ Limited
I got mine 2 months ago here in Dallas and it was $1800 off of sticker (2014 limited) and then they took off a little more so it ended up around $26,500.
T1 Race Development
ID Injector Dynamics
BirgeyT1 is offline   Reply With Quote
The Following User Says Thank You to BirgeyT1 For This Useful Post:
iLuveKetchup (07-24-2014)
Old 07-24-2014, 02:50 PM   #429
emutcfut
Drives: 2013 Argento
Pretty sure this is referring to the internals of the new rear dampers.
emutcfut is offline   Reply With Quote
The Following User Says Thank You to emutcfut For This Useful Post:
cslntuee (07-25-2014)
Old 07-24-2014, 02:54 PM   #430
srizzors25
Daedalus Moto
srizzors25's Avatar
I picked up a limited here in CO on Monday that had been sitting in their showroom for about 3 months for $26,000 ++
The Following User Says Thank You to srizzors25 For This Useful Post:
Old 07-24-2014, 03:10 PM   #431
iLuveKetchup
Drives: EFF JAY
Thanks guys! There's a 14 SSM Limited at a local dealer. If I get $26k, I'll take it.
Old 08-07-2014, 01:51 AM   #432
marvey
Drives: 2015 Subaru BRZ Series.Blue
I've taken both the 2013/2014 and 2015 near and over the limits and I can definitely confirm the 2015 has more level cornering. The 2015 susp. is definitely better at keeping the tire contact patch to the road. Something very easy to feel given how easily it was to slip in the 2013/2014 with the stock tires. Also 2015 seems to have slightly better turn in, and easier to throttle oversteer, which is something I really like. A quick lane change at speed manuever is much more settled than the old susp - better rebound characteristics. And everything is still more comfy than a Cayman when running over bump. Cayman is like boom boom smack smack, although the super nice fluffy Porsche seats help absorb the impacts.
Bottom line is that if I had gone with a 2013/2014, I definitely would have switched the suspension - almost but just not quite there. Whereas with the 2015, I am totally happy with the susp. as a street and maybe occasional track car. It's an incremental improvement, but it's just really dialed in. And I did not feel that way with the 2013/2014.
The possible bad part is that the 2015 susp. is so dialed in that I don't want to change anything like lower it. But lowering is kinda dumb and a PIA around where I live and work.
marvey is offline   Reply With Quote
The Following 3 Users Say Thank You to marvey For This Useful Post:
Bristecom (09-01-2014), krayzie (08-07-2014), Sport-Tech (08-08-2014)
Old 08-07-2014, 06:42 AM   #433
krayzie
Drive From Home
krayzie's Avatar
If you read up on the marketing description on the chassis and suspension parts from the STI Performance catalog (flexible tower bar, flexible draw stiffener, lowered springs, pillowball arms for the rear suspension), the purpose of all those parts together is to pretty much achieve exactly what you described on the stock 2015. Saved you $2000 bucks right there.
Old 08-07-2014, 11:25 AM   #434
EZx2
Drives:
Got mine today, still on adrenaline ;-]
Let 'him' drink some 98 oct.
EZx2 is offline   Reply With Quote
BRZ/FRS vs 2015 WRX Djratrap FR-S / BRZ vs.... 185 09-14-2015 11:47 PM
2015 86/BRZ vs 2015 Eclipse botbs FR-S / BRZ vs.... 55 04-16-2014 04:07 AM
TW 200 in STX for 2015? JRP Tracking / Autocross / HPDE / Drifting 10 03-19-2014 05:04 PM
2015 AT dtrop BRZ First-Gen (2012+) -- General Topics 5 02-27-2014 10:14 AM
2015 Subaru WRX STI vividracing Other Vehicles & General Automotive Discussions 112 02-11-2014 09:48 PM
