Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-11-2021, 04:52 PM | #1 |
Silicone intake hose suggestions
Red manifold engines have different airbox and hose: the airbox sits half centimeter to the right, and the hose has "Larger intake boot bend radius (optimized intake air channel); the bend radius has been increased to allow for smoother flow of intake air and reduce air flow resistance."
Now, can you suggest a specific silicone pipe with the same shape and dimension of the new type, that can possibly retain the resonator and removes the sound generator? Thank you! |
02-11-2021, 05:14 PM | #2 |
Drives: Bone stock
Ebay and call it a day.
Sent from my SM-N960U using Tapatalk |
02-11-2021, 05:55 PM | #3 |
Drives: 2016 Scion FR-S
Perrin makes a 17+ intake hose.
02-11-2021, 06:00 PM | #4 |
02-11-2021, 07:11 PM | #5 |
Drives: 2017 Toyota 86 (860 SE)
Yep. I installed the Perrin and it's quite nice. Take care you align it properly to maximize the clearance from the drive belt, but it really looks good.
02-11-2021, 08:09 PM | #6 |
Drives: 2018 BRZ
The Perrin intake deletes both the sound tube and the resonator. I know there are some silicone intakes that allow for both and come with plugs you can use. Don't remember which ones now, though...
02-12-2021, 12:54 AM | #7 |
As I said, I'm looking for a hose with the same shape as stock one. Perrin is completely different...
02-12-2021, 02:14 AM | #8 | |
https://www.mishimoto.com/toyota-86-...hose-2017.html
2022 BRZ Build 2013 FR-S Build |
02-12-2021, 04:11 AM | #9 |
Drives: 2014 GT86
From what i recall, such wish to retain resonator has valid reasoning. Wasn't there mishimoto testing, that showed, that removing resonator alongside sound tube reduced power?
The Following User Says Thank You to churchx For This Useful Post: | JIM THEO (02-12-2021) |
02-12-2021, 07:26 AM | #10 |
We are talking Perrin intake hose not cold air intake. I believe it is exactly what you asked for. Keeps airbox and resonator, deletes sound tube, same shape, not sure on diameter in the bend but it does not have the accordion portion so less turbulence in the bend.
02-12-2021, 08:25 AM | #11 | |
Drives: 2018 BRZ
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Grady (02-12-2021) |
02-12-2021, 09:12 AM | #12 | |
Drives: 2K19 GT86
https://86speed.com/torque-solution-...ipe-frs-brz-86 |
02-12-2021, 09:27 AM | #13 |
Pulled mine off and trashed it right after I purchased the car, forgot about that little one on the bottom, thought he was talking about the one fwd of the filter.
The Following User Says Thank You to Grady For This Useful Post: | Ohio Enthusiast (02-12-2021) |
02-12-2021, 12:25 PM | #14 |
Here's the visual difference. I found it to be a preferable improvement on all fronts, personally.
Similar Threads | ||||
NEW HPS post-MAF Silicone Intake Hose W/ Hardware | Laz84 | Engine, Exhaust, Bolt-Ons | 7 | 07-15-2018 10:55 AM |
Silicone Air Intake Hose $40.00 !!!! | Depo Racing | Engine, Exhaust, Bolt-Ons | 163 | 08-23-2016 02:08 PM |
Perrin Cold Air Intake and Silicone Inlet Hose | digital_assassin | Engine, Exhaust, Bolt-Ons | 5 | 10-31-2013 11:54 AM |
WTB Perrin Silicone Intake Hose (Black) | 2013GTRNate | Engine, Exhaust, Bolt-Ons | 0 | 09-26-2013 12:33 AM |
Perrin silicone intake hose, sound gen del. | Teknian_Culprate13 | Engine, Exhaust, Bolt-Ons | 11 | 08-24-2013 09:05 PM |
