06-16-2018, 08:57 PM | #45585 | |
If I was having this problem, I'd just go with ol @Ultramaroon 's suggestion and replace them all with OEM parts. Reminds me of the time that I went to replace the spark plugs and spark plug wires on my old Chevrolet. A one hour job, even with making the wires from scratch ….. right? Somewhere along the line I got the wires crossed up and when I fired that puppy up, big backfires happened. It dawned on me that I didn't know the firing order of that engine. Nope, no maintenance manual, no operators manual, no internet. Now, try to get ahold of someone, with only a 10 party land line phone, on a Sunday, that would know the firing order of stove bolt 6 engine. Trial and error was not an option, since my last two attempts resulted in me trying to blow the muffler off and the carburetor off. Since I was only, 14, none of my friends knew shit about engines. Finally, my uncle had one of his mechanics call me and gave me the firing order. THE END humfrz |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
06-16-2018, 08:58 PM | #45586 |
義理チョコ
In either case, I spend plenty of time jiggling the wheel to allow it to line up in rotation as I hand-tighten the nuts.
I've used antiseize/grease plenty of times but then the torque wrench goes out the window. I'm confident enough in my own skill but I don't suggest others do it.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (06-16-2018) |
06-16-2018, 09:07 PM | #45587 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (06-16-2018) |
06-16-2018, 09:37 PM | #45588 |
Site Moderator
Drives: ichi 86 Project
Maybe you missed it, so I’ll say it again. I’ve busted the ARP extended stud & not OEM studs. I must be VERY strong or that ARP are defect. My guess is on the 2nd one.
06-16-2018, 10:14 PM | #45589 |
義理チョコ
I didn't miss it. You didn't say they were longer than OEM. I'm just saying there isn't anything magical about the ARP studs.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | ichitaka05 (06-16-2018), Spuds (06-16-2018) |
06-16-2018, 10:15 PM | #45590 |
Site Moderator
Not saying they’re magical, but it’s hellova better than OEM ones.
The Following User Says Thank You to ichitaka05 For This Useful Post: | Ultramaroon (06-16-2018) |
06-16-2018, 10:17 PM | #45591 |
義理チョコ
Meh. I bet they're comparable. Any seized fastener will twist off.
06-16-2018, 10:26 PM | #45592 |
Site Moderator
You think so? Might be... idk there’s no solid research to agree or disagree
06-16-2018, 10:29 PM | #45593 |
The Dictater
Drives: '13 Red Scion FRS
A harder/better fastener is not always better. For such a simple device, there's a lot going on. You've got various force vectors, friction, heat cycles, fatigue, particulates, corrosion, etc. Its a bit much for me to explain in more detail and give examples at the moment, unfortunately (at my mom's retirement party lol). The OEM torque specification was calculated and tested on OEM lugs with OEM lugnuts. If you change something of those, it's possible that you have now made that specification incorrect.
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
06-16-2018, 10:32 PM | #45594 | |
The Dictater
06-16-2018, 10:37 PM | #45595 |
Site Moderator
I broke a stud... but I keep working on it, I’ll break ALL of em.
06-16-2018, 10:38 PM | #45596 |
The Dictater
06-16-2018, 10:39 PM | #45597 |
Site Moderator
You make a good point. 89 ft/tq was for OEM studs spec vs ARP stud might have lower or higher tq lvl. I should check on that...
06-16-2018, 10:39 PM | #45598 |
Site Moderator
Simple 24” breaker bar, cuz my electric impact gun can’t in screw it.
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
