Old 09-13-2017, 12:52 PM   #925
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Originally Posted by Amputechture View Post
Do it! Even if you want to stay at or near your current boost levels, I have a 'wastegate' map that has the target set to my wastegate spring level, it lowers the boost threshold by about 300 rpm. They are so affordable, no reason not to. I'd recommend against the Grimspeed EBCS, the barbs on them are tiny. Switched to an Infamous Performance EBCS and the difference can be seen logging manifold pressure. Nothing dramatic, but every bit helps when you are fighting to keep your transient up.
Thanks for the recommendation! Looks like Infamous Performance no longer offer that EBCS and Delicious are the only one who carry it now. I was looking at the Delicious one anyways and I'll probably go with that.
Old 09-13-2017, 07:43 PM   #926
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
any differences between PTuning and the Delicious Tuning one? They literally look exactly the same:
https://www.delicioustuning.com/node/367
http://www.ptuning.com/subdir/itemde...&ModelDesc=FRS
I guess the only difference I see here are the mouting points. Otherwise they are the same thing?
pgranberg11 is offline   Reply With Quote
Old 09-13-2017, 08:28 PM   #927
Amputechture
Drives: 2014 BRZ
Probably not. They are all "Mac Valves"...in fact check this out;
http://howertonengineering.com/product/mac-valve/
The difference between Grimspeed and the Mac types (Infamous/Delicious/P-Tuning/Even AEM has an identical one) is that the barbed fittings on the Grimspeed are really small. Just that fraction of a centimeter in inner diameter, those couple little kunt hairs of open space for air to flow makes all the difference.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
pgranberg11 (09-14-2017)
Old 09-14-2017, 08:38 AM   #928
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Wow. $35 dollars?? That's way cheaper than the others. Why wouldn't someone want to just buy this one then... at the end of the day it just seems like you're paying for the name if they work the same.
EDIT: now that I realize, it probably comes un-terminated and doesn't come plug-n-play. Probably would explain the price bump. Seems like polarity doesn't even matter either and a lot of other people are doing this on other forums:
[ame="https://www.youtube.com/watch?v=7Xq3TSfo61I"]DIY ELECTRONIC BOOST CONTROL SOLENOID! - YouTube[/ame]
Old 10-02-2017, 07:54 PM   #929
choiboie
Drives: 2013 Fr-S UltraMarine
do I bolt down overpipe then downpipe then turbo down to manifold? Or back wards. Dp seems to be touching cam angle sensor a little too much.
choiboie is offline   Reply With Quote
Old 10-02-2017, 09:16 PM   #930
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
I have the same problem but I wrapped it in reflective tape to mitigate the heat.
Rybot is offline   Reply With Quote
The Following User Says Thank You to Rybot For This Useful Post:
choiboie (10-03-2017)
Old 10-03-2017, 09:45 AM   #931
Amputechture
Drives: 2014 BRZ
My angle sensor touches too, pretty sure everyone's does. I did the same as Rybot mentioned, threw some DEI foil around her.
choiboie (10-04-2017)
Old 10-06-2017, 04:44 PM   #932
choiboie
so 30 miles and it melted the sensor everything still fine but I guess I’ll have to address this
Old 10-07-2017, 11:54 AM   #933
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
maybe loosen all the exhaust bolts (downpipe/turbo/recirc tube if you have one) and move some stuff around to see if you can get an inch or so of space?
The Following User Says Thank You to pgranberg11 For This Useful Post:
choiboie (10-07-2017)
Old 10-07-2017, 08:00 PM   #934
coxxoc
I used one of the MAC valves on my Rx7 for a many years without issues. If I remember correctly, they were exactly the same thing AEM and Haltech were selling at the time without the name brand sticker and mark-up.
coxxoc is offline   Reply With Quote
Old 10-24-2017, 08:04 PM   #935
TwoChicksOneSTI
Drives: 2015 Subaru BRZ Series.Blue (WRB)
What injectors and fuel pump are people running with this kit? It's going on my DD for the forseeable future so I don't really think I need anything above 700cc. PTuning recommended 850cc. I was looking at the Deatschwerks ones but people in the FB group were against them. Has anyone run them in the 86 platform?
Originally Posted by bestwheelbase View Post
One time, at a dyno day, I saw an aftermarket stem cap fly off and nail a girl square in the forehead.
TwoChicksOneSTI is offline   Reply With Quote
Old 10-24-2017, 08:09 PM   #936
Bookies
Drives: 2013 FRS
I run Bosch 750cc injectors and they have been great so far. Imo you don't need to replace the fuel pump. I've had no issues so far with the stock one and I hear people pushing a lot more power than me doing just fine with it as well.
Bookies is offline   Reply With Quote
The Following User Says Thank You to Bookies For This Useful Post:
TwoChicksOneSTI (10-25-2017)
Old 10-25-2017, 01:05 AM   #937
Rybot
Rybot's Avatar
I've heard absolutely great things from James @HRITuning about the injector dynamics 1000 injectors. Apparently they are THE thing to use when tuning with ECUTek.
I haven't heard the best things about DW injectors, but I've never used them, so grain of salt, etc, etc.
I have a fully stock fuel setup (minus tuning, of course), and all is well. Has been for over a year now.
Old 10-25-2017, 05:13 PM   #938
TwoChicksOneSTI
Thanks guys!
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
