Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
11-30-2017, 12:58 PM | #43 | |
My VTEC fluid is full
Drives: EFF JAY
03-12-2019, 12:28 PM | #44 |
Drives: 2015 Raven Black FRS
Really wish this guy still made some more of these harnesses Just bought some release series headlights for my base model and could really use them.
03-13-2019, 02:00 AM | #45 |
Drives: Whiteout FRS
Doesn't hurt to buy the 8pin connectors and do some re-pinning :P I thought about re-creating the harness but currently do not have time to do so.
04-23-2020, 05:20 PM | #46 |
Drives: '13 Scion fr-s
Hey guys, just wondering if there's any traction on where to buy a 6- to 8-pin harness to convert my '13 fr-s headlights to 17+ 86 headlights. Please let me know!
Also, would MY17+ BRZ headlights have the same 8-pin configuration? |
04-23-2020, 10:52 PM | #47 | |
Drives: 2016 Toyota 86
I found this place, but they are in Australia and it does not look like they ship to the US. They also would not be straight plug and play for the 2017+ because they require you to splice into the turn indicator wires so the indicators in the headlights will work. The only option might be to buy these 8-pin plugs and do the re-pin yourself. The major downside to this is it will be more difficult to put the stock headlights back on unless you also found the 6-pin plug somewhere and made you own adapter. |
04-23-2020, 11:11 PM | #48 | ||
Wheels for Brains
I just bought a pair of 8-Pin Connector for the vehicle-side off of eBay and swapped the pins over to work with the headlights. They came with extra pins to crimp to your own wires as well https://www.ebay.com/itm/1x-Connecto...72.m2749.l2649 My old 6-pin connectors are just in storage now. If I ever wanted to put them back, I'd just depin the 8-Pin connector and put them back in the right slots For any headlight that has integrated turn signal, you'll have to spice in the signal wire yourself anyway |
04-24-2020, 12:19 PM | #49 | |
04-24-2020, 02:28 PM | #50 | |
Wheels for Brains
You could make a jumper or harness and bring it up, or just splice |
06-23-2020, 05:40 PM | #51 |
Drives: 2015 Scion FR-S Raven Black
Hello, I have RS1.0 headlights on a FRS, purchased the LED86 adapters from Australia, but I get no LED DRL functionality, anyone here familiar with their harness? It does have a loose yellow wire that I thought was only for turn signal functionality on BRZ headlights, but potentially affects the RS1.0 led drls?
06-24-2020, 11:18 AM | #52 | |
Wheels for Brains
If you want DRL, you have to tap into the High Beam power or do the DRL Splice from the DRL resistor power lead. Both involve removing/unplugging the DRL resistor. |
The Following User Says Thank You to EndlessAzure For This Useful Post: | Kaleb765 (06-24-2020) |
06-24-2020, 01:35 PM | #53 | |
Thank you! Sent from my iPhone using Tapatalk |
10-24-2021, 03:25 PM | #55 | |
Drives: 15 FRS
10-28-2021, 09:08 PM | #56 |
Drives: 15 FRS
Similar Threads | ||||
Harness Bar | diirk | Tracking / Autocross / HPDE / Drifting | 38 | 07-21-2017 01:15 PM |
WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 03:32 PM |
wiring harness | so26 | Electronics | Audio | NAV | Infotainment | 5 | 10-30-2013 03:19 AM |
WTB: Subaru BRZ Headlight Harness Parts | enderr | Exterior Parts (Aero, Lighting, Etc.) | 3 | 08-28-2013 05:39 PM |
Lighting Harness | wawro569 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-09-2012 11:28 AM |
