Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
09-25-2019, 11:05 PM | #15 | |
Drives: 2017 Toyota 86
I could maybe markup the wiring schematic for you, but I think it would span a few pages. |
09-25-2019, 11:26 PM | #16 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
Very interesting. If my idea proves undoable I would certainly consider doing it your way to get the effect I want. How much did the parts cost?
Work Hard. Play Hard.
2016 Oceanic |
09-25-2019, 11:40 PM | #17 |
ProCrastinationConsultant
i've been writing this out for a while now, and while i understand what you're doing, and how it works.. i see now that it should work.
but it's extremely inefficient and is going to take a bunch of wire, and a ton of time to get everything connected to those points, many of which are very much not exposed, and will take a lot of time to get to. here is a much simpler solution that hits all the same points, and uses the existing ignition 2 circuit that already powers the turn signal, but requires hacking up a flasher module, and running only 1 pair of external wires to interrupt the marker light power. and i would recommend using these to interrupt the marker light, which would make this modification 100% reversible if used in the right sequence. https://www.amazon.com/Glarks-Discon...7&s=hi&sr=1-27 you could also use those same connectors at the flasher module, which would make this easily reversible throughout with only 3 physical connections to be connected/disconnected. edit: forgot to add-- using 2 small relay's like this, you should be able to fit it into the flasher relay can without making 'warts' on it, which would make for a compact and easy to use assembly. of course, as long as your soldering skills are up to it. https://www.goldmine-elec-products.c...?number=G23833
09-26-2019, 12:32 AM | #18 |
My soldering skills are garbage. I don't solder anything.
Most of my electrical connections are done with solid (not split) metal tube butt connectors with a sealing heat shrink. Spades and whatnot where needed, like when connecting to relay. Everything is hardwired unless a component is meant to be removed. In the event of removal of this lighting stuff, I would simply repair the harness. The image you sent appears to have all the relay pins connect to all the same circuits as mine, with an exception where you have specified a switched power source. However, comparing your and my wiring diagrams it's evident I showed I would be running more wires than I actually would be. My intention was to make most connections near the flasher assembly. There will only be 4 wires running through the bulkhead(to/from each side marker). The rest will be done at/near flasher assembly. I'm not too concerned with the amount of time it takes. I can't imagine wiring in a couple relays will be too time consuming. I have the benefit of the lift in my shop to aid in getting under the car for the marker light circuit access.
2016 Oceanic |
The Following User Says Thank You to ActionMaxon For This Useful Post: | soundman98 (09-26-2019) |
09-26-2019, 12:59 AM | #19 |
Yes, its the same circuit. My original misunderstanding was in the switched ground layout. Being a HV electrician and having a majority of my automotive wiring dealing with switched positives, the original diagram threw me some.
09-26-2019, 12:08 PM | #20 |
Well this is good news. I will have to report back with how long everything takes and whatnot.
2016 Oceanic |
09-26-2019, 02:27 PM | #21 |
Country Boy 4 Life
Soldering is WAY easier with flux. It helps the solder "flow" evenly. I always use flux.
via Imgflip Meme Generator
I LIKE TIRES! |
09-26-2019, 03:53 PM | #22 |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Your solution looks like it'll work just fine, but like other have stated it's a bit overdone. This is most effectively done with a logic board.
Think of it this way: You're trying to do the exact same thing that trailer light adapters do. Cut into a solid signal when a turn signal is provided, and return to that signal once the turn is deactivated. So, why not use one of those trailer adapters that have the logic circuit built-in already? Hook the 'brake' input up to the running light source, 'turn' inputs to the turn signal sources. Grounds to grounds as usual, and viola, running lights that switch to turns when used. Just like a trailer's brake lights. Edit: Like this, just hook your running lights to the 'stop' input https://www.zoro.com/buyers-products...03/i/G9111459/ |
The Following 3 Users Say Thank You to sharpsicle For This Useful Post: |
09-26-2019, 04:27 PM | #23 | |
This would also keep everything in the engine bay and prevent me from having to dig into interior electronics. I think I might just do it this way. Thanks for the suggestion!
2016 Oceanic |
09-26-2019, 08:37 PM | #24 |
I honestly don't remember. It wasn't optimized layout wise, so I spent twice I should have on enclosure and potting materials. My guess is about $100.
06-07-2020, 01:13 PM | #25 |
Drives: a yellow BRZ
I want my (JDM clear) side markers to function like they do outside of North America - just as turn signals. Alternatively, it would be cool to have switch back LEDs and have the side markers work as parking lights when parking lights/low beams are on and work as turn signal when turn signal/hazards lights are activated but this would be a lot more complicated as I imagine.
As OP mentioned, one critical feature was missing in the original thread - the side markers blink in sync with the turn signal. Is there a simple DIY to make this happen? Can I just cut the + wire and tap it into the turn signal in the head light? I think that's what I did for my JDM side markers for my RSX way back in the day. Last edited by SubieDoo; 06-08-2020 at 01:46 AM. |
06-15-2020, 05:19 PM | #26 |
Someone was kind enough to post a video showing how the side markers work outside North America:
. It appears that the side markers function ONLY as turn signals. I own a 2017 USDM BRZ. To convert my side markers to be only turn signals and have them blink IN-SYNC with the front and rear turn signals (goal is to have them work the same as the JDM side markers), can I just do the following:
Also, since my 2017 BRZ has LED front turn signal, does that mean I can run 194 LED bulbs in my side markers and they won't hyper flash? Or will I still need to run incandescent bulbs to prevent hyperflashing? I'd really appreciation some guidance or confirmation of my steps before cutting any wires in my car. Thanks guys! Last edited by SubieDoo; 06-15-2020 at 05:33 PM. |
06-15-2020, 06:24 PM | #27 | |
06-16-2020, 12:06 AM | #28 | |
Drives: BRZ limited
That’s very smart! Has anyone used it for this purpose? Any DIY for newbies? Would love to do it. Thanks Sent from my iPhone using Tapatalk |
Similar Threads | ||||
2015 OEM Headlights, turn signals, side markers, reverse light, & Valenti tail lights | Vinsanity091 | Exterior Parts (Aero, Lighting, Etc.) | 4 | 06-11-2017 05:56 PM |
WTB switchback turn signals. And smoked side markers | Stevenuhh | Want-To-Buy Requests | 0 | 02-08-2016 12:37 PM |
TapFlasher Problems: Turn Signals Stay Lit, Side Markers Don't Blink | bobsacamenoh | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-13-2014 10:17 AM |
how to make FR-S front turn signals stay off when not in use | Pavel | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-07-2013 06:29 PM |
