Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 09-18-2020, 01:43 AM   #43
rixter145
Sleep Chomper
rixter145's Avatar
Wish I knew about this sooner...
I found that out the hard way...today... I literally just started the car, heard some sound... didn't think of it much and then on my 12 min drive to my appointment, i noticed smoke and a trail of oil... FML.
rixter145 is offline   Reply With Quote
Old 09-18-2020, 02:45 AM   #44
solidsnake11
Drives: brz
What year is your engine?
solidsnake11 is offline   Reply With Quote
Old 09-18-2020, 05:13 AM   #45
Finsky
Drives: GT86 2012
Hello,
I just stumbled upon this thread. I got my 2012 GT86 fairly recently, I don't track it but I do rev the engine regularly, would you say I should consider this fix ? What are the chances the rockers would fail, is it that common ?
I'm taking the car to Toyota soon for the valve springs recall so wondering if I should have the rockers replaced at the same time.
Thanks
Finsky is offline   Reply With Quote
Old 09-18-2020, 05:50 AM   #46
rixter145
Sleep Chomper
rixter145's Avatar
I had it rebuilt, 2014 brz engine with lower CR. Literally 5.8k miles and this happened...
The Following User Says Thank You to rixter145 For This Useful Post:
solidsnake11 (09-18-2020)
Old 09-18-2020, 09:07 AM   #47
Danny318
Drives: 2019 BRZ
Are there any “newer” engines that have had this issue ?
Danny318 is offline   Reply With Quote
Old 09-18-2020, 10:36 AM   #48
solidsnake11
Drives: brz
That is the new style rocker arm. For the rocker to jump out it has to have excessive clearance first. When they redesigned the valve train they increased the clearance at which the rocker arm would fly out. I would bet they changed the valve spring rate but I have not confirmed.
Examples of causes: Incorrect lash, valve float, broken valve spring, foreign material on valve seat or bent valve.
The sr20de has this problem over 7400rpms when the valves float. Unfortunately the fa20 also has gravity working against it.
The Following User Says Thank You to solidsnake11 For This Useful Post:
rixter145 (09-18-2020)
Old 09-18-2020, 02:55 PM   #49
rixter145
Sleep Chomper
rixter145's Avatar
Examples of causes: Incorrect lash, valve float, broken valve spring, foriegn material on valve seat or bent valve.
My shop is taking it out today to diagnose what the issue is. I am hoping that it's just the heads and then I can proceed to order the retainer kit... new heads and whatever components got messed.
Old 09-18-2020, 03:25 PM   #50
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Terrible.. broken cast aluminum parts are the ugliest things ever. And comes with a side of heartbreak. Is that a chunk of the cylinder head or the valve cover?
Intent > Content
Old 09-18-2020, 04:10 PM   #51
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hopefully. When mine popped out the rocker pivot came out too and I lost all oil pressure. It threw the rod when I was trying to get it shut off and in a safe spot on the side of the track. Hopefully your rod and mains survived. I did loose two at the same time, likely making it worse.
NoHaveMSG is online now   Reply With Quote
Old 09-19-2020, 01:45 AM   #52
rixter145
Sleep Chomper
rixter145's Avatar
Yeah it's a corner of the exhaust rocker, closest to the front of passenger side.
solidONE (09-22-2020)
Old 09-19-2020, 01:47 AM   #53
rixter145
Sleep Chomper
rixter145's Avatar
Hopefully, shop's gonna take the oil pan off to see if there any metal shavings or where the rocker lash is. Will be sending it back to engine builder for repair and install retainer kit. I hope Australia shipping is quick.
Old 09-19-2020, 01:48 AM   #54
rixter145
Sleep Chomper
rixter145's Avatar
Originally Posted by mstoj View Post
So for those interested, Subaru/Toyota updated the rockers and pivots but the change didn't combat the issue we're seeing in the video (it was mentioned earlier that the change was for the oil). The height of the pivot didn't change, meaning that retaining kit can be used on any model year.
Note, it's important to check valve clearances during installation and swap out the lash adjuster buckets if required. This is unlikely if each lash adjuster bucket is returned to the original valve.
FYI, the engine in the video was factory sealed.
I have reached out to you by email! Looking forward to getting my hands on a set. Thanks
Old 09-19-2020, 11:11 AM   #55
Danny318
Drives: 2019 BRZ
Can they be installed with engine still in car?
Old 09-19-2020, 11:40 AM   #56
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
No.
kevaughan is offline   Reply With Quote
Trans retainer cover Jcas Engine, Exhaust, Transmission 0 04-29-2019 04:24 PM
WTB: spare wheel retainer screw Pat Want-To-Buy Requests 4 04-06-2016 12:57 PM
Pop-Screw Retainer Size? FR-S Matt Scion FR-S / Toyota 86 GT86 General Forum 2 01-20-2013 10:48 AM
big black plastic retainer poormans_LFA Subaru BRZ General Forum 66 02-11-2012 02:33 AM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
