RR Racing
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 08-12-2019, 04:33 PM   #1
BRZ FTW
Drives: 2017 Subaru BRZ
help... think i blew a strut or shock
I hit a big bump in the highway where they paved new section next to the old. The tarmac was offset probably 6" or so and I hit it at 70mph. I bent three rims as a result. So I replaced the three rims but I'm getting quite a bit more nvh in the cabin/seat/everything than I did before.
Whats the best way to tell if a blew one of my struts or shocks? I have the '17 PP Sachs with roughly 19k miles on them.
Is there anything else I should check?
BRZ FTW is offline   Reply With Quote
Old 08-12-2019, 04:50 PM   #2
tehShirt
tehShirt's Avatar
Drives: 2017 BRZ PP
Did you have the alignment checked? How about any of the other suspension components? That was a considerable hit to cause that much damage to the wheels.
tehShirt is offline   Reply With Quote
The Following 2 Users Say Thank You to tehShirt For This Useful Post:
BRZ FTW (08-13-2019), i8ur911 (08-12-2019)
Old 08-12-2019, 09:12 PM   #3
soundman98
threadwrecker
soundman98's Avatar
Drives: '14 brz limited
if you're still getting vibrations, i would check the axles for all the wheels
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
Old 08-12-2019, 09:48 PM   #4
BRZ FTW
Had an alignment done. Pretty sure that made it worse. I think they went really aggressive with the toe and now its super twitchy at highway speeds. Of course their printer wasn't working so I don't know what the final numbers where. Thinking about taking it to a speed shop to check it out and dial it in once more.
Old 08-12-2019, 09:49 PM   #5
BRZ FTW
Anything in particular I should check on the axels?
Old 08-12-2019, 10:33 PM   #6
He who dealt it
At that speed, and with three bent wheels, I'd go over ALL of it with great care. Peened wheel bearings may take a while before they start to growl. Or they may already be the source of the NVH.
Ultramaroon is online now   Reply With Quote
BRZ FTW (08-13-2019), soundman98 (08-12-2019), Tristor (08-13-2019)
Old 08-12-2019, 10:37 PM   #7
soundman98
threadwrecker
soundman98's Avatar
specifically for bent axles. i would put it on a lift and spin the wheels, checking them for run out--it ought to be zero.
hidplanet build log
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
BRZ FTW (08-13-2019), Tristor (08-13-2019), Ultramaroon (08-12-2019)
Old 08-12-2019, 11:33 PM   #8
He who dealt it
The axles, or as the service manual refers to them, axle hubs, are replaceable assemblies. They also house the wheel bearings.
BRZ FTW (08-13-2019), soundman98 (08-13-2019), Tristor (08-13-2019)
Old 08-13-2019, 12:07 AM   #9
Tristor
Tristor's Avatar
Only way to really be sure is wheels off on a lift. If you blew them, they're likely leaking oil. Realistically though, you probably damaged a lot more than the three wheels in your suspension in the process, and not just possibly the struts. I hit a bad spot on the road on a roadtrip earlier this year and bent the OEM toe arm on the passenger rear.
You're in San Antonio just like I am, so you can go to Turner's DIY and get on a lift for $20/hr with access to air tools. If you want my assistance just send me a PM and I will work it into my schedule to come help you out. I always try to help out any local owners (I've done plenty of exhaust and suspension upgrades .
Also, out of curiosity where did you hit this spot so I know to avoid it
Tristor is offline   Reply With Quote
The Following 4 Users Say Thank You to Tristor For This Useful Post:
BRZ FTW (08-13-2019), Phuviano (08-13-2019), Racecomp Engineering (08-13-2019), Ultramaroon (08-13-2019)
Old 08-13-2019, 03:46 PM   #10
BRZ FTW
Thanks all!
I'm taking it to Soul Speed in Austin this Friday to get a proper alignment and once over on the suspension. Hopefully nothing needs replacing.
The Following User Says Thank You to BRZ FTW For This Useful Post:
Old 08-13-2019, 05:19 PM   #11
Tristor
Tristor's Avatar
Thanks all!
That's a great place to take it, Jaime does a good job and Soulspeed is well acquainted with all the intricacies of suspension work. That's who I had do my initial coilover install + corner weighting.
That said, going all the way to Austin is a bit of a drive. Like I said, if you want we can probably find out everything wrong with it on a lift at Turner's DIY, and you can learn how to fix it yourself.
The Following 3 Users Say Thank You to Tristor For This Useful Post:
DaBoBo21 (08-17-2019), KDad2 (08-17-2019), Ultramaroon (08-13-2019)
Old 08-13-2019, 10:42 PM   #12
soundman98
threadwrecker
soundman98's Avatar
if it don't drive right, i'm only hoping you find all the components that need to be replaced in the first shot.
hidplanet build log
Tristor (08-15-2019)
Old 08-15-2019, 10:11 PM   #13
Decep
Drives: 2013 FR-S Series 10
post your alignment numbers?
The Following User Says Thank You to Decep For This Useful Post:
BRZ FTW (08-17-2019)
Old 08-16-2019, 09:28 PM   #14
Tristor
Tristor's Avatar
Thanks all!
So what’s the verdict Spanky? Was yours the yellow BRZ they had on Instagram?
Any other damage or just an alignment?
The Following User Says Thank You to Tristor For This Useful Post:
Blown Shock / Strut Club - Original,OEM units exE36M3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-29-2015 05:54 AM
FS factory strut/shock/mount JMoore412 Brakes, Suspension, Chassis 0 06-23-2014 02:41 PM
Rebuilding strut/shock dampers to be firmer than spring rates? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-16-2014 12:23 AM
shock/strut replacement sinigang_guy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-19-2013 09:15 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
