10-30-2022, 05:18 PM | #23997 | |
Drives: 2014 BRZ
Amazing Sent from my iPhone using Tapatalk |
10-30-2022, 10:58 PM | #23998 |
Drives: 17 Asphalt 86
We had a cruise day with our local club as a season closer before winter. 9 car group was perfect and the route was 150+km of lovely back roads and twisties.
https://i.imgur.com/QIDWEw7.jpg |
The Following 5 Users Say Thank You to RToyo86 For This Useful Post: | Busybee (10-30-2022), NoHaveMSG (10-30-2022), norcalpb (11-01-2022), soundman98 (11-04-2022), Ultramaroon (10-30-2022) |
11-04-2022, 01:55 AM | #23999 | |
Drives: 2013 Whiteout FR-S
No problems so far and the induction noise isn’t as pronounced. I probably got used to the sound. I haven’t serviced it yet since I’ve only driven it around 2000 miles since I put it on, but yes I will have to take off the bumper to clean it unfortunately. I did notice on my OFT that my intake temps are around the same as stock, but I love the room that it gives the engine bay and how it cleans it up! |
11-05-2022, 10:00 PM | #24000 |
Had my car in at local FT86 shop for custom fabbing for a 2.5" OP. Finalizing fitment for production. Did a bit of data logging with my tuner.
Then changed my trans and diff fluid. |
The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
11-07-2022, 10:31 PM | #24001 |
Drives: Halo
Upgraded Cooling System
Previously, -->https://www.ft86club.com/forums/show...65#post3546165
It's day 2 working on the cooling system my2016. Straight forward install but it wasn't easy on the body. pulling the hoses was quite the battle. Installed a Mishimoto radiator/fanshroud/thermostat/hoses/clamps, HPS heater core hoses, and an OEM GR86 oil cooler with some Verus caps. Hopefully I can finish this project tomorrow. Just gotta recheck the connections before I fill it up with Subaru coolant then reinstall the airbox, support brace, and the bumper. -Cheers
The Following User Says Thank You to orz For This Useful Post: | bcj (11-08-2022) |
11-08-2022, 08:55 AM | #24002 | |
Drives: 2013 frs base
11-08-2022, 07:28 PM | #24003 |
Drives: 2013 FR-S, 2023 BRZ
got a new intake, love the way it sounds now
2013 Whiteout FRS 6MT with a JRSC RS Pulley @ 500ish WHP
2023 Ignition Red BRZ 6MT awaiting boost |
The Following 6 Users Say Thank You to arxm For This Useful Post: | Busybee (11-08-2022), DarkPira7e (11-08-2022), Kaotic Lazagna (11-11-2022), pope (11-09-2022), RToyo86 (11-08-2022), soundman98 (11-08-2022) |
11-08-2022, 08:41 PM | #24004 |
Rust bucket enthusiast
That's a mighty fine intake. Congrats!
11-08-2022, 08:43 PM | #24005 |
thank ya, thank ya, finally after 6 years of having this car and telling all my friends "im gonna boost it in a couple months" i finally did it
The Following 2 Users Say Thank You to arxm For This Useful Post: | DarkPira7e (11-08-2022), soundman98 (11-08-2022) |
11-10-2022, 08:45 AM | #24006 |
Verus front wheel deflectors
Back in July, I installed Verus deflectors. My car is lowered 1" and I guess I should have anticipated how often I would find speed bumps, uneven driveways, or large wooly caterpillars that would hit the deflectors.
I may replace the outboard portion with some ABS so that it will bend and spring back into place. |
11-10-2022, 11:22 AM | #24007 |
Barred
Drives: My18 wrxsti My19 brzts
ABS is more of a rigid plastic.
Wait until my Flex capacitor hits 88
The Following User Says Thank You to gen3v8 For This Useful Post: | blsfrs (11-10-2022) |
11-10-2022, 11:27 AM | #24008 | |
Drives: Crapcan
And is not UV stable and will get brittle in the sun.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (11-10-2022), Ultramaroon (11-11-2022) |
11-10-2022, 02:43 PM | #24009 |
Drives: '13 FRS - STX
One oil leak from new shortblock after 1k miles. Hopefully it’s not the rear main, best case some oil that was spilled on redoing the timing, medium case it’s the upper oil pan, doesn’t look like the lower pan, autox this weekend.
The Following User Says Thank You to strat61caster For This Useful Post: | Ultramaroon (11-11-2022) |
11-10-2022, 04:22 PM | #24010 |
Drives: GR Corolla
Did a quick wipe down of the engine bay since I have to wait for Autozone to diagnose my battery (that I'm sure is bad since it's an AGM type that won't charge past 12.45 volts).
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
