Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-20-2019, 07:26 PM | #1 |
Torque App not reading Oil temp properly
Hi Guys,
Having a issue where I can get the oil temp but it seems to drop off after 30 seconds or so and doesn't come back unless I restart the torque app. I triple checked the config for oil temp and all but I'm not sure why its dropping off. Everything else is reading perfectly. Ive checked the forums for the settings and it looks all correct but I cant figure out why it would read fine and then drop off. Any ideas? Or is it possible the OBD2 dongle I have is faulty? Using a ELM327 Mini |
01-08-2021, 10:40 AM | #2 |
Drives: 2013 Toyota 86
I have the same issue. I assume its the readers . I used one and it does not read oil temps at all but reads everything else . I tried a new reader , it works fine but has the same issue as yours . I will try another reader and see of that works. I guess due the these readers being clones , they either work or dont. Its a luck of the draw.
01-08-2021, 07:33 PM | #3 | |
Drives: 19' Toyota 86 TRD
It could be the app or the reader. I have had better luck using this one over torque: https://play.google.com/store/apps/d...hl=en_US&gl=US |
01-08-2021, 09:20 PM | #4 |
6/22/12-2/6/24
My OBD2 scanner itself doesnt work for oil temp too*. I'm assuming its the cheaply made unit's fault.
Someone mentioned in the "official torque app" thread that uninstalled, reinstalling, and inputting the oil temp immediately got it to work - who knows, give it a shot
01-09-2021, 02:34 AM | #5 |
Drives: 86 GT
Is your ELM327 version a 1.5, or 2.0? 1.5 apparently had better compatibility, you can also use this app to check.
https://play.google.com/store/apps/d...m327identifier |
The Following User Says Thank You to Compelica For This Useful Post: | Bonburner (01-09-2021) |
01-09-2021, 09:04 AM | #6 |
I'm using Car Scanner app with this OBDII reader (https://www.instagram.com/p/Bo1UAmXjKwB/) and have no problems reading oil temps on both my Impreza and BRZ.
01-15-2021, 02:03 AM | #7 | |
I am currently using the Vgate OBD reader works perfectly now for both the Fuel and Oil Temp pids . See pics bellow , the Vgate i am currently using is the older firmware 1.5 and the Orange reader has the newer 2.0 firmware . so maybe that was the issue . Last edited by 86GP; 01-15-2021 at 04:44 AM. |
01-15-2021, 05:37 AM | #8 |
Drives: 2020 toyota 86
its a shame these cars do not come with a better gauge package..
01-15-2021, 07:03 AM | #9 |
Rust bucket enthusiast
Subaru "fixed" it with the BRZ. You get oil and coolant temp on the dash. I say " fixed" because I think the implementation is kind of ugly
Similar Threads | ||||
Oil temp reading via OBDLINK? | ysu | Engine, Exhaust, Transmission | 21 | 12-14-2019 05:34 PM |
Oil galley temp reading low | Tomita San | Engine, Exhaust, Transmission | 19 | 03-14-2017 05:22 PM |
Fuel gauge not reading properly | FR-S Hot Lava | Issues | Warranty | Recalls / TSB | 27 | 10-29-2014 10:33 AM |
Torque app with oil temp | aaronsadventures | Electronics | Audio | NAV | Infotainment | 0 | 09-08-2014 09:14 AM |
The Case of The Missing Oil Temp Reading | Fastbrew | Electronics | Audio | NAV | Infotainment | 3 | 08-06-2014 11:25 AM |
