Software Tuning Discuss all software tuning topics. |
06-18-2021, 01:45 PM | #1 |
Drives: 2015 Blue BRZ
Is there OFT tune for Stg 2+with Grimmspeed & 94 Octane?
Hello, I got this 2015 Blue BRZ. It seems to have come with some sort of tablet.
The other day I downloaded the latest software for the Open Flash Tablet, and upgraded the tablet's firmware. I backed up any image files that came on the tablet, and downloaded the latest ones (although the versions seems to be the same as already on the tablet, I think 4.03). I then reflashed the car to Stage 2 Plus (nonE85), so the 3rd one in the list. It all worked great. I have a ticket in with the Open Flash company, but while waiting to hear back, perhaps you can clarify some things I am confused about. 1) I read about a Stage 1 Grimmspeed tune. Is there a Grimmspeed tune for Stage 2 Plus? I understand the MAF mappings are quite similar to stock, so it may not make much difference, but I would like to make maximal use out of every last tweak I can, even if I only gain 1 horsepower! 2) The prior owne ran 91 octane gas. Locally I cannot get E85 however I can get 94 octane. I have read that that the stock Stage 2 tune is for 91, but I have also heard about a Stage 2 tune for 93? If so, where can I download it? The prior owner told me that after flashing the standard tune, the car "learns" your mods and driving style and takes advantage of them.. and I get that. I read somewhere that the software will sense your better octane levels and adapt accordingly. That is great to know, but if there happens to be a similar tune available that is already written for 93 octane, that might be an even better place to start from, no? 3) I am considering replacing the stock overpipe (OP) and front pipe (FP) with an aftermarket one, such as the JDL UQFP with 1 hi flo cat and 1 resonator (2.5" version), or the HKS dual resonated FP. The owner told me if I did that, I would eliminate the restriction of both the stock cat and the smaller diameter of the stock OP and FP. That is great. Except.. would the OFT Stage 2 Plus tune be able to sense that also, and adapt, so that I would gain more horsepower? Or would the difference be so minimal that my $700 invested wouldn't be worth it? Last edited by BoxerRumble; 07-27-2021 at 11:14 PM. |
06-18-2021, 01:53 PM | #2 |
Drives: 2018 Subaru BRZ
1) I believe the Stage 2+ would have to get a custom tune done it since OFT tunes do not naturally support CAI/SRIs. OFT is not the greatest when it comes to respond to tickets, so good luck.
2) Per the Knowledge Base and How to from OFT Stage 2+ Hardware Requirements:
So there's a gray area of what OFT considers premium fuel, but I would run 94 since 91 is the bare minimum for these engines. Remember that OFT tunes are generic and not costumed. 3) Refer to info posted on 2. Again, OFT tunes are generic, the only increase in power, in a more noticeable way would be going EcuTek for each custom performance part of your vehicle. Not saying that OFT is bad, I have it, but you don't extract every possible HP from the supported mods each stage allows. Below for their parameters on each stage. https://support.openflashtablet.com/...e-requirements
06-18-2021, 01:59 PM | #3 |
Also, what the last owner probably was trying to say when he mention that the car "learns" your mods, is that after flashing, there's a dead pedal feeling for the first 45 miles or so, maybe less. The car has to learn the new A/F ratio, etc. So it "learns" it because of it's electronic throttle. That way you don't have a deadzone on the gas pedal. Could've been him just up-selling the car.
06-18-2021, 02:08 PM | #4 |
Drives: 17 Asphalt 86
The stage 2 tune is designed for good American 93.
Our gas is crap compared to American 93. You most definitely want to run 94 to get the most out ot the tune. Monitor your IAM while driving. Even on 94 I doubt you'll hit 1. I managed .98 IAM in the dead of winter with 25f intake temps. |
06-18-2021, 06:06 PM | #5 |
Drives: Subaru BRZ 2016
I have had a similar experience to that of RToyo86 with Petro 94. I had to pull quite a bit of timing to Stage 2+ for ensuring that the IAM remained 1 at all times. Also, if you want to start calibrating MAF and timing yourself for your particular setup, I suggest you pick a fuel and stick to it.
06-18-2021, 08:04 PM | #6 |
Drives: 2017 Toyota 86
Check out wayneroms.com
Sent from my SM-G930V using Tapatalk |
The Following User Says Thank You to Daily86 For This Useful Post: | JohnH (01-13-2024) |
06-19-2021, 01:17 AM | #7 |
Drives: FT86
Husky 94 seems good as well from doing a few tune for Canada cars.
can do custom tune on oft if needed |
03-08-2023, 04:24 AM | #8 |
Drives: 2014 86 GTS
Update?
Did you ever get any updates regarding the tune?
Tags |
93 octane, 94 octane, grimmspeed, oft openflash, tune |
Similar Threads | ||||
selectable tune for octane. | Jaden | Software Tuning | 4 | 01-27-2018 03:01 AM |
OFH OFT Tune Octane Specific | GVegas | Software Tuning | 2 | 04-18-2017 08:16 PM |
OFT 93 Octane tune... | Tromatic | Software Tuning | 29 | 05-21-2015 01:58 PM |
Best tune for 93 octane? | smg1138 | Software Tuning | 13 | 02-15-2015 09:50 PM |
Octane level and tune | Victor Draken | Software Tuning | 9 | 12-02-2013 01:10 AM |
