Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-25-2020, 12:49 AM | #29 |
Drives: Q5 + BRZ + M796
What alignment would be ideal for my driving style (daily and canyons and hooning)? Like I know I can’t adjust much as is, but say I could adjust anything then what is the ideal setup for me? Like back to factory specs would be good? How much camber is ideal? Obviously no camber is needed to go straight down the road, and shouldn’t there be some dynamic camber under cornering suspension compression, right? Would a basic alignment place know the stock specs, or do I need to supply that or my wishes? Just looking to be prepared.
07-25-2020, 01:47 AM | #30 |
Drives: 2013 FR-S Series 10
Find a place that accepts custom alignments, a lot of places just want to put it on the rack and make sure the numbers are green and make the quick buck.
With lowering you should be able to get -2 degrees front with camber bolts easily enough. Lower control arms in the rear is recommended for adjusting rear camber. I'd say -2F -1.5R is a good starting point but honestly if you can tell a huge difference on the street between -2 degrees and -1 degrees you are probably gonna get your car impounded at some point. I prefer zero toe but a teeny bit of toe in helps stability
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following 2 Users Say Thank You to Decep For This Useful Post: | Irace86.2.0 (07-25-2020), Yoshoobaroo (07-25-2020) |
07-25-2020, 08:52 AM | #31 | ||
TRACKBREAD
This should be pretty good for a ~1” lowered car. Toe is the most important here, you want 0 up front ideally. The steering in this car is precise enough that it won’t be unstable at speed. Camber and Caster will be what it is most likely, it’s not adjustable on this car. They can adjust the front a tiny bit by shifting the strut mounts in the bolt holes, but they likely won’t. Quote:
That’s good! Pressure should be okay then! We do have to keep in mind than the range of acceptable tire pressure is pretty wide. |
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
07-25-2020, 02:20 PM | #32 |
Drives: Subaru BRZ
Another thing to check is the condition of your shocks. If they're knackered then you can experience some strange wear patterns on the tyre.
07-29-2020, 08:58 PM | #33 |
UPDATE: I took the car in for the alignment. Here are the results. I am ordering some Michelin Pilot 4S, so I have them ready. I think the toe is part of the problem, but because the left front is so good and the right front is so bad, and the toe seems to be both bad, I can only conclude that perhaps it is just the driving style.
I was explaining to the technician how the left rear kicks out to the left under heavy throttle like 99% of the time, and how I thought it does it less with traction control on, which leads me to believe it is the VSC, and he said that could be the case. I asked how I could have such bad wear on one and good wear on the other, and the technician says in the US we make more right hand turns, which makes sense like I am much more likely to make a power slide on right hand turns from a stop (for fun) than during wider and longer left hand turns. Maybe that could explain some of it. I don't know.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Thefalls (08-01-2020) |
07-30-2020, 01:59 AM | #34 |
Drives: 2017 86 860 Special Edition
Looks like Toe was all your issues, that plus slightly over inflated tire pressures. 35/38 cold pressures can easily become over-inflation after 15-20mins of highway driving. Old tires are also very sensitive to bad toe/camber and will start wearing unevenly.
I'm still shocked people make suspension changes and think it's ok to drive without an alignment. |
The Following 3 Users Say Thank You to RayRay88 For This Useful Post: |
07-30-2020, 09:39 AM | #35 |
The "before" was not good.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Irace86.2.0 (07-30-2020) |
07-30-2020, 12:50 PM | #36 | |
07-30-2020, 04:13 PM | #37 | |
The "chassis to hub/ground height" is irrelevant and not a constant or tangible measurement. Makes sense, most people, like yourself, don't understand how suspensions work. This is why I think there should be more disclaimers everywhere in instruction manuals and DIY's. if you make any change to your suspension geometry you should get an alignment. Best err on the side of caution rather than destroy your tires. $100 is good insurance when spending $500-$800 on tires, not to mention better handling. |
The Following User Says Thank You to RayRay88 For This Useful Post: | Jdmjunkie (07-30-2020) |
07-30-2020, 05:40 PM | #38 | |
07-30-2020, 06:22 PM | #39 | |
Drives: '14
Even though you have very little camber, wear from toe out + neg camber is going to compound. -0.9 deg * half the total toe out is going to cause way more inside edge wear than -0.4 deg * half the total toe out. You might notice some outside edge wear now that your toe is zeroed, but high tire pressures could hide it. Watch it and think about camber bolts if you notice any appearing. |
The Following 2 Users Say Thank You to itschris For This Useful Post: | Irace86.2.0 (07-30-2020), RayRay88 (07-30-2020) |
07-30-2020, 08:27 PM | #40 | |
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | RayRay88 (07-30-2020) |
08-01-2020, 12:28 PM | #41 | |
Drives: Corolla GT
The Following User Says Thank You to Thefalls For This Useful Post: | Irace86.2.0 (08-01-2020) |
Similar Threads | ||||
How does my tire wear look? | R_E_L | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-08-2018 07:34 AM |
tire wear | oppiee | Tracking / Autocross / HPDE / Drifting | 9 | 08-29-2017 12:55 PM |
Tire Wear? | Flo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-10-2017 03:19 PM |
Uneven Tire Wear | tofurun | Tracking / Autocross / HPDE / Drifting | 2 | 11-22-2016 11:45 PM |
Uneven wear with AP Racing Sprint BBK | ATL BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 57 | 09-05-2016 10:55 AM |
