Software Tuning Discuss all software tuning topics. |
09-19-2019, 03:34 AM | #197 |
Drives: Scion FRS 10 series
Yes copy the table from 6000 row on advanced max a table, log and adjust
06-12-2020, 06:48 PM | #198 |
Drives: 2017 Toyota 86 Asphalt AT
Hey, any thoughts on my situation:
Have 2017 86 AT, installed billet blocks with the OFT tune that is edited based on Shiv's directions. 1000km later had coolant explode over engine bay and overheating occur. Blue coolant had turned green. Took to shop and they're suspecting a blown head gasket and want to tear apart the engine. Pressure test show a leak once engine warms up. The said they checked the water pump and radiator which are fine. What else could be the cause before this large repair. Thank you. |
06-13-2020, 04:32 AM | #199 |
Drives: brz 2017 hksv2
Shit happens
Difficult to say it was the tune since I have hard time thinking some knocks on NA can destroy this engine since the knock control unless it was knocking like crazy and you didn t check with logs So not much else to say |
06-13-2020, 04:50 AM | #200 | |
Drives: FT86
When those power blocks installed you needed to remove intake manifold and their is some coolant lines going to throttle body, maybe those got dislodged or damaged ?. Unuual that blue coolant could turn green, unless Green coolant used to top up, mixing coolant types is not recomended If oil was in coolant it generally turns into sludgy mess. |
06-14-2020, 07:28 PM | #201 |
Thanks for the help everyone
08-01-2020, 09:58 PM | #202 |
Hey Shiv, I just intalled the power blocks on my FR-S and now the car seems to be dying at idle. I have to give it gas upon turning the key to keep the car to even turn on. Do you know what might be the issue?
08-01-2020, 10:39 PM | #203 |
Drives: 2013 frs red
Check your installation first. Vacuum leaks via pinched o rings or the vacuum tube that connects to back of manifold would be my first concern
08-28-2020, 11:19 AM | #204 | |
03-11-2022, 08:44 AM | #205 |
Drives: Pearl White 2014
Apologies for the Necro but I was wondering if there is still no suggested changes for E85 when running the BPBs?
Im runing the Stage 2+ E85 tune: Stg-2-Plus-E85-v4.03-LC-FSS-ZA1JB00C. |
03-11-2022, 12:20 PM | #206 |
Drives: JRSC BRZ SOLD
They don't work well together. 949Racing tried it with Delicious tuning and they just are not compatible.
03-11-2022, 03:22 PM | #207 | |
"Not compatible". How do you mean? I'm running E85 with them (and the tune I listed) and have been for a while with no issues. Or do you mean there is just nothing to really gain by adjusting the tune? |
03-11-2022, 03:39 PM | #208 |
Oh sorry, yes nothing to be gained. Delicious tuning tried to get them to work with each other but they lose too much VE after 6500 where E85 really shines. Also I have seen a couple cases where E85 eats at the O-rings supplied by Crawford causing leaks.
12-25-2022, 12:58 PM | #209 |
Drives: 2013 FRS
Is it necessary to edit the OFT tune?
If I install the Billet Power Blocks, do I necessarily need to edit the OFT tune? Or will the engine run well without editing the OFT tunes?
12-28-2022, 09:21 AM | #210 | |
Drives: 2013 FRS
Update
Hopefully this helps someone. It appears from the dyno graphs that editing the files will only make a few hp difference at 7000rpm. I don’t trust myself editing the file in Romraider, so I’m going to leave it alone. |
Similar Threads | ||||
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks | Shiv@Openflash | Engine, Exhaust, Transmission | 129 | 11-24-2017 07:58 PM |
Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
Crawford Billet power blocks | Triumphrider | Engine, Exhaust, Transmission | 0 | 08-01-2014 01:39 AM |
FS: One set of barely used Crawford Billet Power Blocks | Robert@Openflash | Engine, Exhaust, Bolt-Ons | 1 | 06-07-2014 04:13 PM |
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 11:18 AM |
