Old 03-26-2015, 01:43 PM   #29
FRSEVO
Drives: Ultramarine FRS
What kit did you use that included the 2 OHM resisters
Instagram @nmgrizzlybear
Buschur built Evo VIII - SOLD
Ultramarine FRS
FRSEVO is offline   Reply With Quote
Old 03-26-2015, 11:30 PM   #30
kylefrs
kylefrs's Avatar
Drives: Scion FRS
Works bell short hub
kylefrs is offline   Reply With Quote
Old 04-13-2015, 02:08 AM   #31
jaime3
jaime3's Avatar
Drives: Scion FR-S
Originally Posted by outlaw121 View Post
Anyone have problems putting a grip royal wheel with a works bell hub and nrg quick release on? I can't get anything to line up right do I need a adapter? Do I rotate the hub over a few teeth? If I do that the clock spring is off and abs and traction lights stay on
how did you fix the slip and abs light problem. having the same thing with the works bell hub and nrg quick release
jaime3 is offline   Reply With Quote
Old 04-13-2015, 09:02 AM   #32
outlaw121
outlaw121's Avatar
Drives: 2013 scion frs blue
Buddy of mine at Toyota had to reset the position of the clock spring off center by a turn everything works fine
outlaw121 is offline   Reply With Quote
The Following User Says Thank You to outlaw121 For This Useful Post:
jaime3 (04-13-2015)
Old 04-13-2015, 01:51 PM   #33
jaime3
jaime3's Avatar
Drives: Scion FR-S
So if I go to Toyota, they will do this for me.? I thought it's illegal for dealerships/car shops to work on aftermarket steering wheels?
Old 04-13-2015, 03:29 PM   #34
outlaw121
outlaw121's Avatar
They won't do it for you we did it after work
Old 04-13-2015, 03:38 PM   #35
jaime3
jaime3's Avatar
Drives: Scion FR-S
Do you think you can ask your friend how to know when the clockspring is properly positioned right? I've been trying to figure this out for months. I've tried different resistors, I've ask friends to help, still no fix yet
Old 04-13-2015, 03:40 PM   #36
outlaw121
outlaw121's Avatar
What kinda wheel are you running?
Old 04-13-2015, 03:42 PM   #37
jaime3
jaime3's Avatar
Drives: Scion FR-S
Just an nrg. With works bell
Old 04-13-2015, 03:42 PM   #38
jaime3
jaime3's Avatar
Drives: Scion FR-S
Nrg with works bell hub
Old 04-13-2015, 04:32 PM   #39
outlaw121
outlaw121's Avatar
Clock spring should turn 2 and a half turns each way don't try to spin it past that to hard you will snap the flat wire inside there should be a clear window on the front face of it that should show a orange gear that lets you know it's at top dead center as for the nrg hub I believe you can just set it on without having to spin it around or anything
Old 04-13-2015, 04:34 PM   #40
outlaw121
outlaw121's Avatar
Not using a quick release?
Old 04-13-2015, 05:34 PM   #41
jaime3
jaime3's Avatar
Drives: Scion FR-S
Sorry, I meant to put nrg wheel and quick release with works bell hub.
So if it's centered, it needs to be 2 1/2 turns each way? I noticed there's a clear window with the orange part in there. That should be on what side once I turned it center ?
Old 04-13-2015, 05:46 PM   #42
outlaw121
outlaw121's Avatar
On the left if I recall.. I believe the nrg quick release should then just bolt on and your wheel should be straight and light should go off make sure your 2 ohm resisters are both in on the air bag plugs
Aftermarket steering wheel.. _F-R-S_ Cosmetic Modification (Interior/Exterior/Lighting) 164 04-20-2018 05:29 PM
How do you keep cruise control with aftermarket steering wheel??? kylefrs Cosmetic Modification (Interior/Exterior/Lighting) 32 04-06-2016 05:58 AM
Prova Steering Wheel Install RallySport Direct DIY (Do-It-Yourself) Guides 38 08-05-2014 12:42 PM
How do you keep cruise control after installing a aftermarket hub and steering wheel? Timtamtt Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2013 07:17 AM
Aftermarket steering wheel HELP! Juurian Cosmetic Modification (Interior/Exterior/Lighting) 0 06-03-2013 11:47 PM
