Software Tuning Discuss all software tuning topics. |
05-05-2022, 01:15 AM | #29 |
義理チョコ
This is one of the most interesting solves in a while. Just last weekend, my wife re-told the story of how her dad would call her out for resting her foot on the clutch.
10/10 thread.
05-05-2022, 02:14 AM | #30 |
Drives: brz 2017 hksv2
good steve finds always a way, he s the best
i got confused by the fact his. log didn t have all the normal values logged by default by ecutek, but now we know it s kind of easier to spot from the afr target he gets too steve we love. you |
The Following 3 Users Say Thank You to tomm.brz For This Useful Post: |
05-05-2022, 02:36 AM | #31 | |
義理チョコ
I was thinking that it would be interesting to log everything while playing with the switch, but it already makes perfect sense in hindsight.
05-05-2022, 02:43 AM | #32 |
yes when you log clutch switch (it s not default value) it shows immediately as clutch switch value would jump to 1 when it starts the bog
05-05-2022, 11:14 AM | #33 |
Drives: Crapcan
Yeah, that was a good one
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (05-05-2022) |
06-05-2022, 09:57 PM | #34 |
Drives: 2013 frs base
Finally putting this one to bed. PTuning sent me an update which turned off ffs and P0420. I can drive my car with my foot touching (but not riding, since I don't want to piss off @ultramoon's father in law)) the clutch before I shift. What a joy.
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (06-05-2022) |
06-07-2022, 06:50 AM | #35 | |
Drives: FT86
the standard ecutek FFS setup is quite harsh as it actually hold the rpm 200 rpm above the rpm clutch was pressed. for smooth shifts you want to have the rpm hold between 200 less to 1200 rpm less than when clutch pressed ( depending on the rpm of shift, i calculated this of the average gear ratio change and this produces very smooth shifts like an auto actually smoother than you can do yourself. |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | blsfrs (06-07-2022), Ultramaroon (06-07-2022) |
06-07-2022, 08:29 AM | #36 |
On the dyno, it actually looks fairly smooth.
06-07-2022, 11:28 AM | #37 |
義理チョコ
That's terrible! Why even bother having the feature?
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (06-07-2022) |
06-07-2022, 06:23 PM | #38 |
that' s terrible for the clutch and transmission. but allows for the quickest shift, as it "pushes" the car forward as you change gears
Wouldn t use it anyway. i put the rpm lower always like steve said |
The Following User Says Thank You to tomm.brz For This Useful Post: | blsfrs (06-08-2022) |
06-07-2022, 08:29 PM | #39 |
Pressure fried
Drives: '15 ultramarine
I have had the same problem with my car. Sudden cut of between 5 and 7k rpm about 5 times now. I went out driving today and tested the cruise. It took an unbelievably baby push on the clutch to turn it off. I usually run my car with the tune that includes racerom features. I like the auto blip.
So I tried to replicate the cutoff. Couldn't do it. Now going to run the tune without racerom and see if it happens again. |
The Following User Says Thank You to Sapphireho For This Useful Post: | blsfrs (06-08-2022) |
Similar Threads | ||||
car bogging when coming to stop | Qball1754 | Engine, Exhaust, Transmission | 10 | 06-06-2019 11:39 AM |
Engine bogging down | FRiSson | Issues | Warranty | Recalls / TSB | 6 | 08-14-2015 08:07 PM |
Vortech FR-S Bogging RPM AND STALL | ScionFR-S | Forced Induction | 9 | 07-24-2015 05:52 PM |
random bogging/stalling - no cel though | edsbreezy | Issues | Warranty | Recalls / TSB | 5 | 04-22-2014 09:58 PM |
Transmission Dry Sound & Bogging | jjkerr626 | Engine, Exhaust, Transmission | 3 | 06-11-2013 12:10 AM |
