Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-18-2016, 02:52 PM | #30 | |
Drives: '23 BRZ Limited
On my adjustable setups (motorcycle and car), I start with the adjusters in the middle, spend some time getting comfortable, then analyze what the car is doing that I want to correct from there. |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | dp1 (05-18-2016) |
05-19-2016, 08:23 AM | #31 |
Ken will die. We'll be at Buttonwillow on 5/28.
The Following User Says Thank You to Apex-Apex For This Useful Post: | CSG Mike (05-19-2016) |
05-25-2016, 02:02 PM | #33 |
driving smoother faster
Drives: Sold
05-25-2016, 03:11 PM | #34 | |
His latest lap time is 6 seconds faster than his best on the Ohlins, on a 100 second lap. He's also on the same 9k/11k that we got for you, which did have a bit of a learning curve from the understeery biased Ohlins. |
The Following User Says Thank You to CSG Mike For This Useful Post: | dp1 (05-25-2016) |
05-25-2016, 03:23 PM | #35 | |
Drives: Sold
05-26-2016, 12:30 AM | #37 |
Drives: WRB JR BRZED
The Following 3 Users Say Thank You to enivid For This Useful Post: |
06-03-2016, 02:22 PM | #38 |
Drives: Sold
Need feedback on JRZ RS Double vs JRZ RS1 vs Tein SRC
Recommended settings for JRZ RS double adjustable dampers, out of 14 clicks for compression and 24 clicks for rebound.
These settings from JRZ USA are the starting points for 9k (~500lb) front and 11k (~600lb) rear springs, so ask your vendor or JRZ USA how to go about fine tuning from here on. I bought these through CSG and they gave me recommendations for initial settings (not the same as below) and instructions on how to adjust from baselines based on observed behavior. First go full clockwise to full soft, then go counterclockwise to the first groove/click - the starting/0 point - then stiffen by going further counterclockwise for a specified number of clicks. Stop at the count of the last groove/click. In other words, C6 below means it refers to the compression knob and once you get to full clockwise/soft, go counterclockwise and stop at the 7th groove/click (fist click is 0 then 6 more from there). - Street Front C6/R8 - Street Rear C4/R5 - Track Front C8/R12 - Track Rear C7/R8 Please post your settings when you've dialed them in to your liking, and note spring rates if different and sway rates if not stock. Thanks Last edited by dp1; 06-04-2016 at 01:54 PM. |
06-10-2016, 01:03 PM | #39 |
Drives: Sold
Anyone knows height of the front vs rear springs on JRZ RS double adjustables? Just the main springs without helper springs. Is it 6" front and 4" rear? @CSG Mike?
06-10-2016, 01:30 PM | #40 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | dp1 (06-10-2016) |
06-10-2016, 02:10 PM | #41 | |
Drives: Sold
06-17-2016, 11:34 PM | #42 |
Drives: Sold
I don't know how much to attribute to the most recent suspension reinforcements vs new JRZ RS vs increasingly feeling more comfortable driving closer to the limit but I'm 4 seconds faster at NJMP Thunderbolt than last year and the mild oversteer with proposed initial JRZ USA track settings is very easy to control. Will try different adjustments. I am easily leaving few more seconds on the table 8). Not cheap but worth every penny.
The Following 4 Users Say Thank You to dp1 For This Useful Post: | BatStig (06-18-2016), CSG Mike (06-18-2016), FastWhite (06-24-2016), Racecomp Engineering (06-19-2016) |
Similar Threads | ||||
Double oil cooler | kcam86 | Tracking / Autocross / HPDE / Drifting | 16 | 05-20-2016 09:46 PM |
ABS feedback?? | calidus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 03-17-2015 06:39 PM |
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
sorry double post | LS13 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 08-29-2012 02:42 PM |
Double U T F...is this for real? | Hawk77FT | AUSTRALIA | 20 | 07-14-2012 05:21 PM |
