Old 10-02-2015, 12:42 PM   #15
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Vented hood, wrap your headers, make side vents, proper skid plate (beatrush makes one now) ummmm remove the crash bar if you want more flow (I would not do this but its an option) What intake do you have?
Grimmspeed
Toyota86.ir is offline   Reply With Quote
Old 10-02-2015, 12:56 PM   #16
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Toyota86.ir View Post
Grimmspeed
That one looks fine for AIT's, well atleast as good as it can really get haha.
Old 10-02-2015, 01:04 PM   #17
Toyota86.ir
Mike tuned the car , after maf scale LTFT is 0.
I guess cooling will help but some days the car will not give you 100% impression.
Old 10-02-2015, 07:51 PM   #18
steve99
If your ltft is always 0 then i think your tuner has made car run in closed loop all the time and disabled ltft, you usually see ltft vary a couple of percent with temperature.
High under hood temp on NA cars are only realy an issue at very low speeds and stoped once your moving iat comes down quickly.
If much easier to make radiator fans run at low speeds ,table change in tune, to cool engine bay than messing with insulating intake and venting. although an easy vent is unclipping the plastic piece on the underside of the hood on the RHS of car above the overpipe.
oil coolers even the oem type are a good investment in hot climates if you drive hard as is a 5w30 or 10w30 oil depending on climate.
IAT temps higher than about 90F will start to pull timing ,but depends on tune
you need to look at FLKC fine learning knock control as well as iam to see if timing being pulled due knock.
for other compensations like iat and oil temp coolant temp you would need to look at tune tables .
Old 10-03-2015, 02:36 AM   #19
Toyota86.ir
the LTFT is not zero all the time and it vary between -1.8 to 1.8 in various condition.
i think starting fan at lower temp is better idea than vented hood for NA.
the iam all the time with E85 is 1.0
The Following 2 Users Say Thank You to Toyota86.ir For This Useful Post:
steve99 (10-03-2015), Xero-Limit (10-27-2015)
Old 10-23-2015, 01:33 PM   #20
Toyota86.ir
Ideal gas laws and stoichiometry.
I think you are right
Old 03-15-2016, 04:54 PM   #21
Toyota86.ir
Now i am sure the stoich is the key.
I like to know how ecutek calculate E85 stoich?
Air to fuel ratio is ratio of air mass(gr) to fuel mass(gr) and we know ethanol density is 789gr/litre but gasoline density vary in range 710-770 gr/litre.
I like to know ecutek gasoline density number?
Old 03-15-2016, 06:40 PM   #22
steve99
I dont think ecuteck does any thing fancy
The 02 sensor in car measures 02 and measures this in lamda.
The ECU then converts this to petrol AFR numbers
so lamda 1 is 14.7 AFR
when you run E85 nothing changes the 02 still measures amount of oxygen in exhaust gas and ecu still cinverts it to petrol aft so stoic for petrol and e85 is still lamda =1
the ecu still assumes your on petrol so it converts it to petrol afr of 14.7. But you on E85 so the actual amount of fuel to achieve lamda 1 on e85 is 9.76.
It likely ecu does everthing in lamda and then just converts\scales to petrol afr
here is conversion table
http://honda-tech.com/forced-inducti...chart-3014051/
Old 03-15-2016, 06:50 PM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
You could change the parameter from AFR to lambda.
You could create a custom map to output the E85 AFR....
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-15-2016, 07:33 PM   #24
steve99
if he has racerom extension :-)
Old 03-15-2016, 08:55 PM   #25
FRS Justin
Drives: 2013 Asphalt FRS
Things to consider that affect power.
1 Gas quality, even if the pump says E85 it could be E60
2 HUMIDITY!!!! High Humidity will kill the power... These little 4bangers hate it..
3 Heat will knock some power off....
4 After market parts. Even if you already tuned it and then you add something it will throw off the tune....
5 And lastly lack of maintenance.... Dirty air filter, bad fuel,ect.
Good luck!! Happy hunting!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 03-17-2016, 11:10 AM   #26
Toyota86.ir
Air fuel is ratio of air mass to fuel mass .
In E85 85/15 is ratio of ethanol volume to gasoline volume and volume ratio differ from mass ratio.
For E85 calculation we need to know the density of gasoline.
I do not know ecutek use what number for gasoline density.
Old 03-17-2016, 11:12 AM   #27
Toyota86.ir
I do not tune myself and i just like to know e85 calculation in ecutek
Old 03-17-2016, 03:21 PM   #28
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
I love it around sep/oct when the temp up here drops. I swear it feels like a good 20-30hp gain. I feel for you guys in Cali who see high temps nearly all year long.
No wonder so many of you go FI
headlikeahole is offline   Reply With Quote
DIY Mini Bar/secret compartment? VakaGT Scion FR-S / Toyota 86 GT86 General Forum 11 01-28-2015 06:16 AM
Secret Weapon-R Intake?? scionfr_s Engine, Exhaust, Transmission 38 11-01-2014 01:35 PM
This has been a secret for far too long TheChopShop Other Vehicles & General Automotive Discussions 4 10-05-2012 01:50 AM
Top Secret / HKS Parts underway R0ME0 Engine, Exhaust, Transmission 37 05-25-2012 09:03 AM
