Forced Induction Turbo, Supercharger, Methanol, Nitrous |
08-28-2018, 05:13 PM | #1 |
Drives: 2013 Brz
Can you help me?
I currently own a stock 2013 Subaru BRZ. My goal is make 550hp+ using a turbocharger. I am quite new to this type of stuff however I do have some background knowledge. If you could please help me by listing the needed parts and tools required to meet my goal, it would be very much appreciated. |
08-28-2018, 05:21 PM | #2 |
Drives: '15 frs turbo
Basics: turbo kit, built engine, clutch/flywheel, fuel pump and lines, tune.
Extras: drive shaft, brakes, suspension, oil cooler, catch can or aos, trans depending on how it’s driven, wheels/tires Something more helpful than all of that though, you can search and find this info all over the site. I feel like this topic has been talked about at least a million and a half times. There is tons of great info if you search, and you’ll probably find an answer to all of your questions. All in though you’re looking at a 20k+ budget easy imo Sent from my iPhone using Tapatalk |
08-28-2018, 05:24 PM | #3 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
A spare engine is something I'd have laying around if I planned to hit those number. Good luck!
08-28-2018, 05:27 PM | #4 |
Drives: 2013 Brz
Thank You!
08-28-2018, 05:30 PM | #5 |
+one on the spare engine
08-28-2018, 06:10 PM | #6 | |
Big turbo. Built transmission. Driveshaft Axles Tires (to put the power down). 550+hp, realistically, will take 15k+ |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Leonardo (08-28-2018), x808drifter (08-29-2018) |
08-28-2018, 06:36 PM | #7 | |
Country Boy 4 Life
^ These guys know what they are talking about. How did you arrive at "550hp" as your goal? Will you be racing your car?
I LIKE TIRES! |
08-28-2018, 06:43 PM | #8 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
being "new at this" and wanting 3 times the stock HP with FI don't seem like a good mix unless OP has a bunch of money laying around to pay someone else to do it in which case why didn't he just call a local shop?
08-28-2018, 10:11 PM | #9 | |
Drives: Toyota GTS 86
100% agree with the rest of the list. Add a clutch.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger. |
08-28-2018, 11:35 PM | #10 |
Drives: 2013 frs
Im around that power and I’ve spent around 10k but I did build my engine myself and did all the work myself except the boring/machining process.
Turbo kit Fuel system/e85 Built engine Good clutch/clutch fork Catch can Prayers that your trans doesn’t pop The axles/shafts/tires are up to you if you wanna put the power down or enjoy breaking/spinning tires Sent from my iPhone using Tapatalk |
