Old 06-09-2013, 04:45 PM   #1
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
My First Subaru (Black BRZ)
Here is my Subaru BRZ as currently setup today:
I've started fairly early on the modding for this car, only 1500 miles on the odometer.
Here was my car as I first got it:
And without the wet weather:
My BRZ Limited came from the dealership with 18x8.5" enkei raijin front and 18x9.5" Enkei Raijin rear wheels wrapped in Kumho Ecsta LE Sport rubber. Here is the stance of the wheels before doing any suspension upgrades:
I quickly upgraded to RCE Yellow springs on the factory struts:
I did the install myself, it only took about two hours to do the front and rear with one person helping. I also purchased the com-c top mounts, but have yet to install them. I will most likely get it done next weekend when my SPC rear control arms are in.
Here is the car after the install. I also installed crash bolts and had it aligned. My rear camber is slightly off, but will soon be fixed by the new control arms. These pictures are only a few days after the initial install.
Here you can see the camber after the crash bolts and RCE Yellow springs:
I recently purchased and installed a Beatsonic Sharkfin. I think it is a very attractive upgrade over the stock RC car antenna.
Future plans involve installing my Whiteline Com-C Top Mounts:
I've also purchased, but have yet to install the Whiteline Positive Traction and Positive Shift bushing kits. I will possibly get those installed this weekend as well. My original plans were to use the KCA326 adjustable camber bushings, but nobody in my area was willing to install them for a reasonable price, if they would even attempt the install. I am going to use the SPC 67660 rear lower control arms for my rear camber adjustments. These seem like the best option after the KCA326 bushings. Here is a link to the control arms: http://www.spcperformance.com/index....tion&pid=67660
I also forgot to add that I've added a K&N drop in filter. Hasn't made much of a difference, although there may be some at the upper end. The sound is better however, so I'll take it.
Will update journal once done with the next upgrades!
console_cowboy is offline   Reply With Quote
Old 06-09-2013, 07:41 PM   #2
infinite012
Drives: 13 DGM BRZ Ltd
Damn those Raijins look great in staggered fitment on your car.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
console_cowboy (06-09-2013)
Old 07-07-2013, 05:31 PM   #3
console_cowboy
Just installed my new SPC rear control arms. I purchased the new style 67660 SPC arms. They just seemed more solid, and I think its a better design for the BRZ. Getting it aligned tomorrow, gonna go with -1.5 deg in the rear. So far, they seem stiffer than stock, but I haven't tested it at all. Very easy install with me and a buddy.
Old 07-08-2013, 10:41 AM   #4
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Love the 9.5" rears! Nice mods! Very similar to what I'm running!
The Following User Says Thank You to ATL BRZ For This Useful Post:
console_cowboy (07-09-2013)
Old 07-09-2013, 05:06 PM   #5
console_cowboy
Got the car aligned today. -1.0 deg camber in the front and -1.2 deg camber in the rear. Toe set in .09 in the rear and set to 0 in the front. Got a nail in one tire, so I am waiting on a replacement (nail was too close to the sidewall to feel good about patching). Seems to be handling much better than it ever has after the alignment.
Old 08-10-2013, 10:23 PM   #6
console_cowboy
Finally installed the whiteline com-c top hats. Having a slight pop up front on the first turn of the day or so. I also discovered a rub from the large wheels in the rear. It only happens on high G turns, but it appears to rub against the bracket guarding the brake line. May have to dial out some toe or slightly reshape the guard. Not sure if anyone has had any issues with this.
Here's the freshly detailed engine bay:
Here is a picture of the whiteline top hats installed:
I also took picture of the additional front camber I can run. Final alignment specs were -1.3 up front, with 0 toe and +6 caster, and -1.2 rear with slight toe in.
Old 08-12-2013, 08:43 PM   #7
Turbowned
Turbowned's Avatar
I'm honestly shocked that anyone at the dealership would have good enough taste to pick out those wheels and in the proper size/offset; good stuff!!
The Following User Says Thank You to Turbowned For This Useful Post:
console_cowboy (08-12-2013)
Old 08-12-2013, 08:51 PM   #8
dxero
Drives: 13 BRZ Sport Tech WRB
Looks great! Exactly the rims I was planning to get. What's the off set for wheels? Also did you know if they adjusted the camber when you first got the car?
dxero is offline   Reply With Quote
Old 08-12-2013, 10:40 PM   #9
console_cowboy
The offset on these wheels is +45, although I would probably get a slightly different offset in the rear. +45 with 18x9.5" wide wheels requires a little bit more work in terms of fitting against the ebrake line shields in the rear. The dealership did not adjust camber before I got it, I did that with the whiteline com-c top hats, crash bolts, and rear control arms. Getting a performance alignment should be anyone's first step with this car.
The Following User Says Thank You to console_cowboy For This Useful Post:
ATL BRZ (08-13-2013)
Old 06-22-2015, 09:22 PM   #10
wsites
Drives: 08 STI|15 BRZ|95 L Coupe
Hey man, love the build! But I'm curious are those 235/40/18s front and 255/35/18s in the rear? Also did they rub at the stock ride height? Sorry that I'm full of questions, but I want to buy the same set of rims and I'm trying to decide which tire size would work best on stock suspension.
Originally Posted by cantholdanymore View Post
People wants moar pawar
Kit provides moar pawar
Kit needs engine build to support moar pawar.
People call it fault
wsites is offline   Reply With Quote
FS: Subaru BRZ Premium - Crystal Black - 6AT - Beaverton Oregon Doug&Julie Cars for Sale/Trade 2 05-09-2014 07:19 PM
FS Black Subaru Emblem BNIP david13713 Exterior Parts (Aero, Lighting, Etc.) 9 05-03-2013 01:00 PM
Black Subaru Badge Heero Cosmetic Modification (Interior/Exterior/Lighting) 32 02-04-2013 01:02 PM
There is a black limited auto at Fairfield Subaru CA DrDuquette Southern California 2 07-27-2012 01:42 AM
bad black subaru fixed up bryansbestwax Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-27-2012 12:26 AM
