Member's Car Journals Car journals by our members. |
08-16-2015, 04:42 AM | #1 |
Drives: Honda Civic Type-R FK2
Mindsuckers 2013 Asphalt GT86
Thought i should share whats going on here over the pond and maybe exchange some ideas for future plans
Short backstory Used to own this Miata for 5 years but got really fed up taking care of all the small problems a 25 year old car involve so decided to put it out for sale to spoil my daily instead. Here's some pics what it looked like when i sold it. And now onto this Current list of mods Exterior/interior TRD shiftknob TRD starter button Black trim pieces STI Gurney flap Beatsonic sharkfin antenna Handling/brakes/Wheels KW V3 coilovers Whiteline front camber bolts Whiteline front swaybar Whiteline adjustable front endlinks SPC rear LCA Rays TE37SL 18x9.5 +45 Rays lugnuts Michelin pilot sport cup 2 265/35 R18 Engine/drivetrain Stock for the moment Audio/multimedia Toyota touch & go headunit (won't mess with this area to much) So, picked up this 2013 Toyota GT86 at the dealership to replace my Nissan Juke as a daily. Didn't have any bigger plans for it at the time since most money went into the Miata but got a Beatsonic sharkfin antenna to replace and a cusco gear knob from 86worx (Max from Rev9) together with the Garage vary panel i bought for the Miata during their groupbuy. That was enough for the first year of ownership until the Miata was sold to fund some future plans. Last edited by Mindsucker; 08-16-2015 at 03:07 PM. |
The Following User Says Thank You to Mindsucker For This Useful Post: | swarb (08-16-2015) |
08-16-2015, 04:43 AM | #2 |
So during winter 2014-2015 i decided it was time to let the Miata find a new home so fixed some minor issues it had and put it out for sale once spring arrived.
Also got some small stuff from Japanparts since i was a little short of money at the time. Started with a STI gurney flap, TRD shift knob and some Rays lug nuts. Then it was time to get rid of all of the silver plastic trim pieces in the interior and replace them with the black versions from some of the JDM models. . Also installed the gurney flap Then it was time to move over to the handling so started with some SPC rear Control arms and Whiteline camber bolts for the front. Took out the Miata from winter storage on April 4 and on April 6 it was sold to it's lucky new owner. Now it was time to get some new wheels to the GT86! |
08-16-2015, 04:44 AM | #3 |
There is way to many choices out there but finally decided to go with Rays TE37SL in pressed graphite grey in 18x9.5 +45.
Such a gorgeus wheel! Actually kept these in my livingroom a couple of months until i bought some meaty rubber for them. Got a really "good" deal on some Michelin Pilot Sports cup2 tires in 265/35 R18 Unfortuneatly they hit the front spring perch so had to keep them of the car until i installed coilovers. So put an order on these KW V3 Since i don't have access to any garage i decided to wait with the install until i went on vacation so got a TRD Start button to replace the OEM one in the meantime. |
08-16-2015, 04:44 AM | #4 |
Now it was finally time to get everything installed!
Started with the rears which was pretty straight forward. Here's the first result once it was dropped to the ground Then i moved over to the front's and they didn't go as straight forward as i thought. At first the swaybar endlinks bolts was rusted out badly because some previous winter driving so had to cut them of. This also gaved me a reason to put an order on a beefier swaybar from whiteline complete with adjustable endlinks. Then i had some serious trouble to move over the OEM tophats to the KW's. The oem strut use's a 17mm nut and i barely managed to fit a spanner to get them of. The KW's howeve, used a 19mm nut and i didn't have any tools at all that was slim enough to get down in the tophat. On top of that i also needed a 10mm socket to keep the from moving. Managed to borrow some tools next day, a slim 19mm socket and a really small 10mm socket. Used a vise grip to the 19mm socket to tighten down the nut and the coilovers was finally ready to get on the car. Raised the rear by 20mm to match the front and dropped it to the ground. Now it was time slap on the wheels and the result is far beyond my expectations! Fitment is spot on and it really handles like a dream! Can't understand why Toyota only have some skinny ass 215/45 tires from factory. |
08-16-2015, 04:56 AM | #5 |
Since i had to get new endlinks and i was planning to get whiteline swaybars next year i decided to put an order on the front bar to get the car running again.
Mounted the new swaybar a couple of days ago after work. No pics though since time flew by and i'm lazy. Also a couple new pics to get a better view of the wheels. Excuse the dirty car, was planning to wash it to but time ran away -_- Have some clunking sound since the swaybar was installed so will take a closer look into that today and see if i can find the issue. |
08-16-2015, 05:21 AM | #6 |
Beautiful. Nice, simple, and clean.
The Following User Says Thank You to swarb For This Useful Post: | Mindsucker (08-16-2015) |
08-16-2015, 06:05 AM | #7 |
Drives: GT86
Looking really nice man!
For the clunking, check the clearance between the links from shock to sway bar, I originally left my original links in when i switched suspension with a decent drop, and the different setup was giving the end links enough reach to clip the arms. Check the edge of the links / arm for any signs of contact, reducing my links length by 2cm resolved it for me. |
08-16-2015, 06:24 AM | #8 |
Thanks!
Crawled under the car this morning and there is plenty of clearance between the swaybar/endlink and the LCA. Going to get it up on a lift so I can get a better view from underneath to see whats going on. |
08-16-2015, 08:34 AM | #9 |
Drives: '13 SWP GT86
Nice to see the English version of your thread aswell You know I like it though
IG @squareddesign
http://www.squareddesign.se |
08-16-2015, 02:37 PM | #10 |
FR-S Driver (MT)
Drives: 2013 Whiteout FR-S
looks good, love the wheels
The Following User Says Thank You to EXCellR8 For This Useful Post: | Mindsucker (08-16-2015) |
08-17-2015, 04:56 PM | #11 |
08-17-2015, 05:01 PM | #12 |
I will, I will, soon
IG @squareddesign
08-17-2015, 08:09 PM | #13 |
Drives: GT86
Those PSC2 are ACE. But isn't it a bit too much in 265? Unless you're planning on adding some boost...
08-18-2015, 10:08 AM | #14 |
Yeah they're a bit oversized considering the power. Love how it handles though and even if there isn't a high priority right now there might be some boost in the future.
Similar Threads | ||||
Don's (93cc) 2013 Asphalt 6MT FRS | 93cc | Member's Car Journals | 10 | 02-16-2017 10:41 AM |
GT86 Tracktool - update Interior/Exterior | icebär | Member's Car Journals | 54 | 07-14-2016 05:42 PM |
Maik's new asphalt grey GT86 | Maik L | Member's Car Journals | 34 | 03-24-2015 04:33 PM |
FS/L: 2013 Asphalt fr-s in NJ | skills | Cars for Sale/Trade | 19 | 03-23-2015 02:42 PM |
New 2013 Fr-s Asphalt | peter_woodbridge_toyota | CANADA | 1 | 07-25-2012 04:28 PM |
