Old 05-18-2020, 01:18 AM   #1
solidsnake11
Drives: brz
Ecutek why will it not pull timing (launch control)
C
solidsnake11 is offline   Reply With Quote
Old 05-18-2020, 03:29 AM   #2
tomm.brz
Drives: brz 2017 hksv2
did you modify ignition timinf minimum values (it s 2 table)
put them to -20 to set that as the lower limit
solidsnake11 (05-18-2020)
Old 05-18-2020, 11:04 AM   #3
tomm.brz
You could be totally one that could mod a laptop like de-lidding the CPU to overclock it
I bet that s why you broke it :PP
I'll post you a screenshot of the 2 tables
Old 05-20-2020, 11:50 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Unless the data poll of the ECU is at the moment you hit minimum timing, you won't capture it. Also, there are global minimum timing settings and without looking through the docs I can't remember whether the value is subtracted from load derived timing values or an absolute.
.: Stealth 86 :.
Kodename 47 DJ:
solidsnake11 (05-23-2020)
Old 05-20-2020, 12:55 PM   #5
tomm.brz
the 2 tables of minimum timing are absolute minimum values allowed to be reached as final timings
setting them at - 20 (one is already there, the other is not), you will reach that if the global timing retard is set to go so late
FFS despite the name is a oem table
these 2, i bet your FFS map is less retarded
Old 05-23-2020, 01:13 AM   #6
tomm.brz
I usually set up a softy automatic antilag based on boost target, for example i set it up on a different map so you have the choice of not using it
when you floor the pedal at low rpm, and the boost target is after higher than threshold, it activates, and it disactivates when boost is enough for you
With custom maps you have many different option if your brain thinks about how to use all those inputs, if you have patience i show you a config that I did to a guy and it works and you can personalize it rather quickly
If you want a rolling antilag on command and not automatic that build potentially endless boost sacrifiyng whole torque during spool, you could set a custom button (either on the ecutek app , Custom Inputs, and you press it on the phone or android radio.... or you hook up a physical button to a free ecu input to trigger it) that when you press it, you simply retard badly ignition retard
Very simple mod, fuel will still flow (flames lol) and you basically engage a temporary limiter with this and boost will start to build
and when you release it, you 'll have torque back with the built boost
if you want to avoid flames maybe you could also trigger together a fuel cut within 20rpm or 50 of the actual rpm in the moment of activation similar to what ecutek launch control does, you recreate it on demand at any moment basically
Old 05-23-2020, 01:23 AM   #7
tomm.brz
that s very soft for a big turbo with low comp maybe, feel free to modify thresholds and the retard ramp
i used K L M custom maps, it got cut in the screenshot
i don t remember your model year car, if you are using US tune, i ll suggest you to force flash an euro tune like ZA1JK00G if you have a restyling car
I had the worst time figuring out the tuning with turbo and flex on a US tune when Racerom is applied
Port injection compensation against boost were all over the place and when i scaled the maf/speed density, it said 400g/s of air entered the engine with crazy Engine Load values
while euro tunes are super stable, bugless and easier to tune because nothing is messed up
Old 05-23-2020, 03:25 AM   #8
tomm.brz
then be creative use another value as activation for the first custom map to trigger it :P
the activation channel for the middle custom map should stay "manifokd absolute pressure" though
if your tune is working good anyway you can keep it a01c, i personally would copypaste everything to a01G or a02G (a01g is best one for romraider and a02G best for ecutek) and force flash it (if you need how i ll tell you private, steve asked me not to write it public because it can be dangerous)
Old 10-20-2022, 09:27 PM   #9
Nagol41
Drives: 2015 BRZ
I Have a very similar problem. I sent you a PM
Nagol41 is offline   Reply With Quote
EcuTek Launch Control Parameters Eazy-V Software Tuning 11 12-11-2017 04:13 AM
EcuTek Launch Control not working Eazy-V Software Tuning 12 06-11-2017 09:31 PM
Ecutek launch control puma Software Tuning 6 06-29-2015 04:55 PM
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
ECUTek Launch Control in Automatic 01s0uljah Software Tuning 2 08-12-2013 08:45 PM
