Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-17-2017, 11:15 PM | #15 |
Drives: 2013 BRZ DGM
Clearly something is missing here. Most stock FA20 can see a roughly 20% increase in power through ecu mapping and header. An increase in displacement with all the supporting they are doing, should also see an minimum increase in as 20% as well. Engines aren't just a simple mathematics equation (they're many, many equations), but it's reasonable to assume that you would see 240hp with the displacement increase alone and be able to 20% more with all the supporting mods and tuning. It would odd to think that this car makes less than 280-290hp. It's possible that they're comparing 200bhp to 243whp.
01-18-2017, 12:46 AM | #16 | |
Drives: ADM Toyota 86 GT
Could be that it makes all the additional torque down low so it doesn't bump up the peak power? Sent from my HUAWEI RIO-L02 using Tapatalk |
01-18-2017, 08:34 AM | #17 |
Mid range torque is needed in the FA20, Increase the torque, that would be very welcome.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
01-18-2017, 08:56 AM | #18 |
Drives: 2014 GT86
This is jdm NA car. It's supposed to be high-rev-ed. While it's simpler to daily drive with more torque more down, i find in some ways more enjoyment/involvement feel due this need of high-reving & rowing through gears to keep in powerband vs relaxed driving in one gear and lazy accelerator use only for change of pace. Imho it would be more fun to make this car more high revving vs adding more torque down low. Even in cases if later one would make car faster then former
The Following 2 Users Say Thank You to churchx For This Useful Post: | Anthony (01-19-2017), Scrappydoo (06-11-2017) |
01-18-2017, 09:46 AM | #19 |
Drives: Whiteout FRS
2.0 >2.4 NA by Monster Sport
According to the sign they had at TAS17, the price of this engine package, believe it or not, is 1,950,000 yen, which converted to USD is around 17211 USD. Attached is the picture of it I took when I was there. Feel free to correct me if I'm wrong.
The Following User Says Thank You to Bach415 For This Useful Post: | stevesnj (01-19-2017) |
01-18-2017, 10:03 AM | #20 | |
Looking at the list of supporting modifications, 243 hp at the crank would be disappointing even without the bump in displacement. |
01-18-2017, 10:23 AM | #21 |
Drives: 2023 BRZ
Again, we don't know all of the details with this engine, but if things are what they seem to be at first blush, this looks to be a pretty spendy proposition given the engine output.
It seems to me like this is just more confirmation of why the Jackson or Edlebrock superchargers are the way to go with this engine. I can't imagine paying more money for a Subaru flat four than a Porsche flat six. The normally aspirated Porsche engines are SO much nicer to drive than the FA20, too. |
01-18-2017, 11:54 AM | #22 |
Drives: Subaru BRZ Limited
I wonder what cams they used? I recall on LS builds the bigger bore engines need a more aggressive cam to move the power band up. (Very different engines I realize)
243 PS is what you might expect with the stock 2 cat exhaust and a stock-like tune. But they looked to be running Catless EL headers with a custom tune. Very disappointing. Sent from my iPhone using Tapatalk |
01-18-2017, 01:27 PM | #23 |
Good points all. I would like the power for the track days powering out of the corners. But for $17,000 I don't need it that bad.
01-18-2017, 01:33 PM | #24 |
Drives: 2015 Subaru BRZ WRB
Stock header, but after market intake and cat back exhaust + e85 will get that same power lol.
01-18-2017, 02:29 PM | #25 |
Drives: 13 frs red
Another jdm money toilet imo.
01-18-2017, 05:21 PM | #26 |
Drives: Stock
Just checked out there web site and there's another video of a dyno with just an intake. Before it is 187ps to the wheels and after intake it is 195ps to the wheels. I think the 2.4 stated is to the wheels. So 243ps to the wheels witch makes since. So converted 239whp
01-18-2017, 07:51 PM | #27 |
Señor Member
2l @ 200hp bored and stroked to 2.4l @ 240hp... Why are people disappointed? There are losses they would have to overcome. Increasing the stroke would make for a pretty crappy rod ratio and increasing the bore will negatively effect the quench built in to the combustion chamber....
1974 TA22 Celica
2013 86 GT |
The Following User Says Thank You to Turdinator For This Useful Post: | celek (01-24-2017) |
01-18-2017, 09:06 PM | #28 | |
As stated above, that engine appeared to be running a catless header and has a custom tune, so you would expect bigger gains even taking into account the losses from increased capacity. You wouldn't quite get the 120hp/litre in the ACE example, but still... And then there was all the porting/polishing work that seems to have been for naught? |
Similar Threads | ||||
Monster-sport pedals | adprokid | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 01-07-2016 08:26 AM |
Monster Beats by Dre PRO, Monster Inspiration headphones | Sgt.Beardface | Miscellaneous | 4 | 09-08-2013 07:05 AM |
MONSTER SPORT Toyota Super 86 | ichitaka05 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 27 | 04-29-2013 08:07 AM |
Monster's Sport Super Toyota 86 Pike's Peak | Ryeong86 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 04-25-2013 12:57 PM |
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers | Diego@lutzperformance | Brakes, Suspension, Chassis | 1 | 10-04-2012 01:43 PM |
