04-04-2021, 03:34 PM | #22961 |
Drives: 2020 BRZ tS
I'd rather wear out my Brakes (cheap) than any associated Clutch/Trans parts (expensive).
The Following User Says Thank You to LancePower For This Useful Post: | DarkPira7e (04-04-2021) |
04-04-2021, 03:37 PM | #22962 | |
Howdy
Drives: 2020 BRZ PP
The idea is you let the engine rev-down AND brake.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
The Following User Says Thank You to BrahmaBull1990 For This Useful Post: | theneptune86 (04-06-2021) |
04-04-2021, 03:54 PM | #22963 |
Drives: GR Corolla
The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | theneptune86 (04-06-2021) |
04-04-2021, 09:36 PM | #22964 |
Howdy
Drives: 2020 BRZ PP
Just picked up this book, too, today.
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post: | JD001 (04-05-2021), soundman98 (04-04-2021) |
04-04-2021, 10:12 PM | #22965 |
Drives: Subaru BRZ
It's not a sequential box so no need to go through all the gears. I often do 3-1 shifts on at the end of short straights into hairpins.
Sent from my SM-G973F using Tapatalk |
The Following User Says Thank You to Purist For This Useful Post: | BrahmaBull1990 (04-04-2021) |
04-04-2021, 10:45 PM | #22966 |
Rust bucket enthusiast
I share this sentiment. If I'm coming to a stop sign, I'm doing so in neutral. No reason to engine brake if you're coming to a complete stop. As above, I'd rather put heat and friction wear on the system designed for that exact purpose
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
The Following User Says Thank You to DarkPira7e For This Useful Post: | LancePower (04-05-2021) |
04-04-2021, 11:08 PM | #22967 | |
Howdy
Drives: 2020 BRZ PP
“Engine braking occurs when a driver takes their foot off the throttle. The throttle valve closes, a vacuum forms and the engine slows the car down. This is the same case in a manual transmission. It’s often been rumored that engine braking is bad for your car, but it can actually prove beneficial, as Fenske explains in the video.”
04-04-2021, 11:24 PM | #22968 |
I didn't say that it does not have a place. Just that I don't downshift for the sole purpose of bringing the car to a stop
The Following User Says Thank You to DarkPira7e For This Useful Post: | BrahmaBull1990 (04-04-2021) |
04-05-2021, 11:22 AM | #22969 | |
Drives: 2017 Toyota 86 (860 SE)
I'd skip the intake, FWIW. Not much to be had over just doing a tube and a drop in for far less cash. Might just be a midwest/high salt area thing, but Toyota's clearcoat on their wheels just doesn't last. I've had two sets on my Tacoma start bubbling after a few seasons, and just noticed the stock wheels on my 86 are starting to bubble around the center caps. |
04-05-2021, 04:36 PM | #22970 |
[jay-kuh-meh-low]
Drives: 2016 FRS RS2.0 #293
Put on some XP10 pads in preparation for my first track day and they’re loud as hell. I sound like a school bus coming to a stop.
IG: @appamatic
The Following User Says Thank You to jkamelo For This Useful Post: | BrahmaBull1990 (04-05-2021) |
04-05-2021, 05:09 PM | #22971 | |
2013 Series 10 FRS #553
04-05-2021, 07:08 PM | #22972 |
theddevilinme
Drives: 2013 Scion FRS [H8R]
Got a sweet re-usable/washable air filter in the mail today from ProTuningLab ($25!)
This weekend is gonna be fun putting on the drive belt, removing stock air intake/filter, and adding the drop in filter + Perrin inlet tube! Also gonna paint up the alternator and water pump plastic covers with VHT Metallic Copper. Maybe I'll do the battery tiedown too and re-install it. I havent had it on the last year as it's rusted and ugly. Almost the same color anyways haha Going to the local Subaru dealer to pick up some other items tomorrow. Fender garnish clips, 2gal Super Coolant, Left Cowl cover, and a bumper cover spacer panel for the front Probably a good idea to ask for some clips to install them back with before I leave...
We're all just living to die - might as well enjoy the ride!
04-05-2021, 11:06 PM | #22973 |
Drives: 0
Installed some TE37SL 17x8.5 +45 w/ 235 PS4 A/S.
The Following 4 Users Say Thank You to mark_sanders For This Useful Post: |
04-06-2021, 03:47 AM | #22974 |
Drives: 2015 FR-S
My windshield took a nasty hit today. Cracks that will definitely run.
I can't catch a fuckin break. |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
