Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-11-2020, 02:08 AM | #1 |
LS Swap
So I am planning on doing a 5.3 small block swap into my 2013 Scion FR-S. I am going to be using the Sikky kit for convenience. Sikky has a header setup but they don’t have a Y-pipe. I’m planning on doing a custom exhaust but the less I have to fab the better. CX racing has has a header and Y pipe, will their header/Y pipe setup work with the Sikky kit? I only ask because because Sikky advertises that their kit mounts the engine back further than other kits. You would think it wouldn’t be an issue as long as the Y-pipe clears, it’ll be a custom exhaust anyways so I don’t need to worry about aftermarket exhaust lining up. Does anyone have experience with this? If not can anyone give their opinion on whether I have the right thought process with this?
05-11-2020, 05:00 PM | #2 |
Drives: Q5 + BRZ + M796
People do in the Engine Swaps subforum.
05-12-2020, 07:32 AM | #3 |
The Following User Says Thank You to DeathToocher For This Useful Post: | Irace86.2.0 (05-12-2020) |
Similar Threads | ||||
FRS 4.8 LS swap | kurty85 | Engine Swaps | 207 | 03-03-2023 12:48 PM |
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Ej Swap | koyv90 | Engine Swaps | 50 | 11-14-2013 07:59 PM |
