Tracking / Autocross / HPDE / Drifting What these cars were built for! |
12-23-2022, 10:29 PM | #1 |
Drives: 2018 BRZ
Camber and Alignment recommendation
Looking to get a more autox/track alignment on my 18 ts. Currently on factory suspension with factory 7.5 wheels with 225s mps4s.
Any recommendations ? Based on a setup I had on my S550 mustang when I used to compete in FS, I think I want to max out as much camber in the front with camber bolts and zero toe all around. Before I start throwing aftermarket suspension parts, I want to get some serious seat time so I’m starting with an alignment. |
12-24-2022, 01:19 AM | #2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
With SPC camber bolts (81305) in the lower hole and factory crash bolts in the upper whole you can gain about -2.5 in front. The lower bolts are the same as factory crash bolts, so you just move them to the upper hole after installing the SPC bolts. There are also Pedders tophats if you want even more.
An adjustable lca in the rear is the most common/easiest option for rear camber |
12-24-2022, 09:42 AM | #3 | |
Drives: 2018 BRZ
How much rear camber do you recommend since I’m on factory suspension ? Wasn’t sure if I could get away with stock lca or if I should just go with the adjustable one now Do you have recommendation on the toe specs ? |
12-24-2022, 04:38 PM | #4 | |
I personally run 0-toe front and rear. |
12-24-2022, 04:48 PM | #5 | |
Drives: 2018 BRZ
How do you like the zero toe all around ? Does the rear get twitchy for DD or at higher speeds ? |
12-24-2022, 06:05 PM | #6 | |
Im not super experienced but I would max the front using the two bolts and go around .5 less in the rear. So roughly -2.5 F/ -2 R. Zero toe is fine for most. Definitely start at that and adjust if needed. |
12-26-2022, 07:50 AM | #7 |
Drives: '23 BRZ
Agree w zero toe all around, maximized front camber for sure. You might try Peddars offset top mounts for a bit more. Personally I wouldn’t bother with adj. rear control arms. Rear camber is not your issue…. Also stock has a bit of rear camber already and you gain outside camber with roll. And if you ultimately get coilovers and lower the car you’ll probably end up with trackworthy rear camber with stock arms anyway. I’m at -2.8deg rear camber with stock arms at -1.5” lower than stock.
12-26-2022, 05:19 PM | #8 | |
12-26-2022, 05:30 PM | #9 | |
Drives: 2018 BRZ
I autoxed mostly a few years back in a few cars: -07 wrx (STX) -13 focus st (GS) -17 s550 GT (FS) I used to do about 3-4 track days a year (the tracks I’ve tracked in so far:AMP, RA, Roebling, and TGP) Took a few years of hiatus and now trying to get back in autox/track. I’m not a pro by any means. Just a regular car guy wanting to do race car things haha I’m not sure what you mean by preferences lol. |
12-26-2022, 05:57 PM | #10 | |
12-26-2022, 06:14 PM | #11 | |
Drives: 2018 BRZ
On the focus st, the car rotated beautifully with lift over oversteer and I just controlled the slide with the gas. The over rotation was a bit violent on the wrx (maybe due to the awd). On the mustang, it was honestly pretty gradual when over rotation happened as long as I was careful with the throttle but I wouldn’t say I ever got “comfortable” with the over rotation. Not sure if this helps. I wouldn’t want a twitchy rear but a willing(?) rear for autox/track application. I autoxed with the 86 and the front end pushed in technical section and when the rear did come around, it felt snappy. I don’t think I would want to add more bar (maybe even get a smaller rear bar like most STX specced 86s) |
12-26-2022, 06:16 PM | #12 | |
This will set you up for learning, and ultimately more driver mod, rather than an AutoX setup that is only good for AutoX and nothing else. |
The Following User Says Thank You to CSG Mike For This Useful Post: | strat61caster (12-27-2022) |
12-26-2022, 07:04 PM | #13 |
Drives: 2017 BRZ PP, 2004 WRX
My 2017 is setup for DS, so this includes the OEM camber bolts (Subaru/Toyota part number) with mostly everything else stock. I was able to get -1.1 degrees camber up front. Rear camber is set at about -1.4 each side (non-adjustable from the factory).
If it wasn't stuck in SCCA's street class rules, I'd at least want aftermarket camber bolts up front in place of the OEM camber bolts they allow and increase camber from -1.1 to ~2.5 if possible. That's about what you'll get out of aftermarket bolts. Other than that, if you're just getting start in some track driving, I'd leave it at that personally. Lots of learning to be done there and the front camber helps not obliterate the outside of the front tires on the track.
The Following User Says Thank You to cmiovino For This Useful Post: | ZDan (12-27-2022) |
Similar Threads | ||||
Alignment Recommendation | ZZT86 | AUSTRALIA | 6 | 04-19-2016 07:07 AM |
Camber/alignment for Eibach Prokit and when should I get alignment? | Meanderchap | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-01-2016 03:44 AM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
Does toe affect camber in the rear? More camber on one side after alignment | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-30-2014 09:37 AM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
