Tracking / Autocross / HPDE / Drifting What these cars were built for! |
04-05-2014, 05:17 PM | #1 |
Drives: 2013 Hot Lava FR-S
Next Upgrade?
Hi Everyone,
I run about 10 events per season, plus a couple of HPDE. I daily drive the car in warm weather only. I have fun when I AutoX and want to be competitive, but I'm not going to nationals... Currently, I have: 17x9 Rota DPT with Direzza Z2 245/45-17 What is my next upgrade? I do have the budget (barely) for KW Variant 3 but if there are other things I can/should do first, I'd certainly entertain it. (Bars, bushings, etc) That would certainly erase the remaining mod budget for this season. If there is also a more economical coilover which is close to the KW3 all the better. Thanks, -Jim |
04-05-2014, 07:21 PM | #2 |
Just drive it
Drives: 13' FR-S
Choice of your spring + koni dampers?
The Following User Says Thank You to frslee For This Useful Post: | Pokeguyjai (04-06-2014) |
04-05-2014, 07:27 PM | #3 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I've been reading nothing but great things about Fortune Auto 500/510
But, be advised, like Mike said... It could be a case of 'the Story of the Frog in the Well' ...but, great praise nonetheless and affordable. I'd really love to hear more opinions/experiences about FA coilovers on this track/autox-focused board particularly (vs the suspension board, which is a heavy mix of dd/comfort-focus interest). |
The Following User Says Thank You to fooddude For This Useful Post: | Pokeguyjai (04-06-2014) |
04-07-2014, 12:32 PM | #4 |
Frog in the well
Well, so long as I don't LOSE performance over stock. I've known people who have certainly fallen into that well. I'm a function over form guy.
04-07-2014, 01:01 PM | #5 | |
In other words, maximize current setup rather than buying random parts thinking it'll make you go faster. |
The Following 2 Users Say Thank You to CSG David For This Useful Post: | forwallblakmail (04-07-2014), retrosmiths (04-07-2014) |
04-07-2014, 01:08 PM | #6 |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Don't underestimate the stock suspension.
Nick K.
NASA ST5/TT5 #130 Southeast Region |
The Following User Says Thank You to forwallblakmail For This Useful Post: | fooddude (04-07-2014) |
04-07-2014, 02:46 PM | #7 | |
Aside from camber plates how does one get more camber out of this car? I'll admit I liked the suggestion regarding the Fortune Auto 500's because it seemed to fit the bill and allows me to add camber. I should have mentioned that I did swap the fluid out for Super Blue and do have a set of Ferodo DS2500 Pads which I used on for the HPDE lapping. Thanks, -Jim |
04-07-2014, 03:52 PM | #8 | |
Drives: 2022 BRZ Limited
The Following User Says Thank You to glamcem For This Useful Post: | fooddude (04-07-2014) |
04-07-2014, 03:55 PM | #9 |
@glamcem: Nice!! I look forward to your write-up ...especially since I am considering which rates to go with - f/r, 8/8, 8/9, 9/9, 10/10 or 10/11 ...9/9 sounds like a great all-rounder and in-between
04-07-2014, 04:19 PM | #10 | |
Drives: 2014 FR-S
-Mike
#24 CS/CSR |
04-07-2014, 04:19 PM | #11 | |
Drives: Scion FR-S Whiteout
So, I already got camber bolts + rear LCA's, with -1.25F/-1.5R camber. Should I get camber plates instead and push my settings to -2.5-ish on the stock suspension, or get coils which might also do that AND also lower my COG?
2013 Scion FR-S
04-07-2014, 04:20 PM | #12 | |
04-07-2014, 04:25 PM | #13 | |
The Following User Says Thank You to CSG David For This Useful Post: | retrosmiths (04-07-2014) |
Similar Threads | ||||
Need to upgrade the oil pan for the FRS/BRZ? | Hanakuso | Engine, Exhaust, Transmission | 5 | 12-28-2014 12:54 PM |
MT Upgrade | Tansey86 | Forced Induction | 14 | 09-19-2013 07:13 AM |
HU upgrade | briang0901 | Electronics | Audio | NAV | Infotainment | 15 | 11-05-2012 11:17 AM |
FR-S HID Upgrade? | frsinpa | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 06-18-2012 08:43 AM |
What will be the first upgrade you buy for your FR-S / BRZ? | HitTheGas | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 02-26-2012 07:30 PM |
