Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
08-15-2015, 02:45 AM | #15 | |
Drives: '13 Black Toyota 86 (AT)
Is there a way to check for the ECU version myself somehow? I might be able to get hold of an OBD2 scanner would that tell me the version? This car hasnt had any ECU updates since it was bought new in 2013. Btw whilst on this matter, just curious if anyone knows what else does the B01D update improve on other than the improved injections? |
08-15-2015, 02:57 AM | #16 | |
I am thinking I should run some injector cleaner every now and again to maintain cleanliness. Looking at the amount of carbon buildup on the old ones in quite scary considering my low mileage and the fact that I dont do a lot of spirited driving (hmmm maybe that's why!) |
08-15-2015, 03:09 AM | #17 | |
義理チョコ
I don't think there's anything you can do or should be concerned about. We're not seeing a trend of DI failures. Perhaps it was just the luck of the draw. With any manufactured system there will always be a statistically measurable failure rate.
08-15-2015, 05:08 AM | #18 | |
The Following User Says Thank You to mo420 For This Useful Post: | Ultramaroon (08-15-2015) |
08-15-2015, 03:25 PM | #19 | |
義理チョコ
08-15-2015, 06:55 PM | #20 |
Drives: 2014 Pearl White BRZ
Here are my injectors pulled at 21K miles - Replaced with FIC 880s.
Ran on Chevron Supreme 92 octane for that 21K. This is how they looked when pulled - no cleaning. |
08-15-2015, 07:05 PM | #21 |
義理チョコ
Those are <cough> manifold injectors.
08-15-2015, 07:13 PM | #22 |
lol - still pretty damned clean
So - his pic is of the low pressure injectors? (blue in diagram below) Mine are the high pressure system injectors - right? (red in diagram below) Or do I have it bass-ackwards.... Last edited by Fastbrew; 08-15-2015 at 07:25 PM. |
The Following User Says Thank You to Fastbrew For This Useful Post: | Ultramaroon (08-15-2015) |
08-15-2015, 07:17 PM | #23 |
義理チョコ
I would hope so. If they weren't, you'd have much bigger fish to fry.
edit: Haha... yeah. the manifold injectors are the low-pressure ones. The DI injectors are the high-pressure ones. They have to be because they spray fuel into the combustion chamber at maximum compression and must be able to withstand the hostile environment inside there - just like diesel engine injectors.
08-15-2015, 08:38 PM | #24 | |
Most obd scanners will read the ecu calibration id for manuals in middle east region 2013 probably will have ZA1JA01J if so thats probably all you need although their is a ZA1JA02J rom out for your region if your car is 700J 900J or A00J then it definitly needs an update for the transient ignition retard this caused heaps of knock on high rpm gear changes especially on poor quality fuels. their are no performance benifits with later roms just di seal fix and idle stability fixs usa guys on usa93 fuel is about the best pump petrol on the planet so they dont have as much issues. see the tactrix link below it has those rom attached at end of post, dealer wont flash those though :-) |
07-29-2017, 07:35 PM | #25 |
Drives: Toyota 86
Hello,
I think I have same problem (see the following video) [ame="https://www.youtube.com/watch?v=3AU035Pvkp0"]86 problem - YouTube[/ame] did you solve the problem totally !? can you advice me ? Regards |
Tags |
bogging, ecu, hesitation, slow accelaration, stumble |
Similar Threads | ||||
Engine bogging down | FRiSson | Issues | Warranty | Recalls / TSB | 6 | 08-14-2015 08:07 PM |
Engine Hesitation for 1-2 seconds. | phoenixrage | Issues | Warranty | Recalls / TSB | 9 | 07-14-2015 05:18 AM |
M/T and idling over speed bumps - jerking | mstoochn | Issues | Warranty | Recalls / TSB | 7 | 04-29-2015 04:45 PM |
RPM hesitation on WOT? | Yamajee | Issues | Warranty | Recalls / TSB | 8 | 01-10-2015 12:43 PM |
Engine stumble around 2.5k rpm in cold weather | Eyesacky | Issues | Warranty | Recalls / TSB | 2 | 11-02-2013 04:50 PM |
