Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-02-2020, 03:04 PM | #1 |
Drives: Red
2013 FR-S with CEL, code is P0016. What should I do?
This code has been on for about 2-3 weeks, car runs completely fine though. Code reads “Crank/Cam Position Correlation – Bank 1 Sensor A” The CEL light is on along with the traction light.
As far as what I’ve done so far, I changed the Oil control valve on as well as the camshaft position sensor. I also changed the oil for both the engine and the transmission, although I don’t think this really matters. However, the code stays the same. My car is one of the earlier models that needs the recall for the valve spring but I haven’t done it because of the “horror” stories online from people blowing up their engines after the recall fix, but I also don’t think this affects the code either. Also since my car is one of the earlier models, the ECU is still running on the older version A00C instead of the updated B01C. I am completely lost at what I should do. I’ve read that people recommend shimming the camshaft sensor but I haven’t done that yet since I’m not very much a mechanic myself. I just wanted to know what I should do. I could start by shimming the sensors. If that doesn’t work, I could update to the new ECU version. If none of these work I may have to resort to changing the cam sprocket but I’ve heard it’s a hefty price and since I’m out of warranty, I want to avoid this as much as possible. |
The Following User Says Thank You to 7onasL For This Useful Post: | humfrz (07-02-2020) |
07-02-2020, 04:24 PM | #2 |
Hi ya, 7onasL and welcome to ye ol forum -
Have you tried to disconnect the battery for a spell to see if the code goes away .... and doesn't return? Yep, ol humfrz has a simple solution to everything ..... and it doesn't usually work - |
07-02-2020, 05:48 PM | #3 | |
Drives: Red
Yea I’ve reset the battery every time I switched or changed out the camshaft position sensor and oil control valve but the code keeps persisting. |
07-02-2020, 06:23 PM | #4 |
[insert cool phrase here]
Drives: BRZ Premium
Sucks to hear that.
If you don't want to pay dealership prices, take it to any good independent shop. One that knows their way around Subaru's. Ask for a quote nothing else. Then go from there. If you are worried about the recall, it's not that bad now. Poor FRS dudes got the shaft because Toyota mechanics where working on Subaru engines. The problem has now been fixed, Subaru sent more detailed information to Toyota mechanics so that problem has been fixed. I got my recall work done last year, zero problems engine wise runs good and strong like the first time I bought it. Then again I have a brz so Subaru did the work. Back to the original topic, chances are you might just need a new sensor and a re flash. But that's my guess.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
07-02-2020, 10:00 PM | #5 |
I think* there are 5 total sensors. 4 camsensors and one crank sensor. If you already tried the new sensor in all four spots than maybe buy a crankshaft and try replacing that? (Or test it with a multimeter if you can find a good youTube video on it) I don't know what a crank sensor is supposed to read. The cam sensors you can just check against each other or the new one to find the bad guy with the oHms readout. Or you can move it to a different cylinder and see if the code changes to a different bank. I just did this on my Fiancée's imprezza a few months ago. It was tedious but I did get it after a few tries.
Sent from my SM-G975U using Tapatalk |
07-02-2020, 10:20 PM | #6 | |
Drives: Red
07-02-2020, 10:24 PM | #7 | |
Drives: Red
The Following User Says Thank You to 7onasL For This Useful Post: | p1l0t (07-02-2020) |
Similar Threads | ||||
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
Help with disable a code P0016 on a OFT | Aace | Software Tuning | 9 | 03-06-2019 07:56 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
P0016 question. | Simmons | Issues | Warranty | Recalls / TSB | 5 | 04-11-2018 03:22 PM |
2013 Scion FRS throwing P1262 Code Questions. | TunaNoCrust1984 | Issues | Warranty | Recalls / TSB | 2 | 04-12-2017 04:49 PM |
