Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-11-2021, 01:59 PM | #29 | |
Fuel pickup is on the driver side. |
The Following User Says Thank You to CSG Mike For This Useful Post: | ZDan (05-11-2021) |
05-11-2021, 05:42 PM | #30 |
Barred
Drives: My18 wrxsti My19 brzts
I also get the the loss of power ,with exhaust backfiring, after a double left hander that links(Fish Hook). 6k rpm in 3rd on semis with less than a 1/2 tank or 3/4+ RHD. Must be fuel as I have not revved past 7.6k and it only happens when you nail the section.
Wait until my Flex capacitor hits 88
05-12-2021, 05:42 AM | #31 |
Drives: 2020 toyota 86
Can someone school me, isn't our rev limiter set well below 9k?
05-12-2021, 06:13 AM | #32 |
Barred
One Scenario.. 4th gear 7.5k rpm and shift into 5th, but you hit 3rd gear by accident. Mechanical over rev! 9k rpm give or take
The Following User Says Thank You to gen3v8 For This Useful Post: | RToyo86 (05-12-2021) |
05-12-2021, 10:14 AM | #33 |
Drives: 2018 Subaru BRZ Limited with PP
Not an issue with auto, but with a manual, you have full control over the gears and revs. An extreme example, but the ECU can't stop you from shifting into 1st gear going 60 mph. The rev limiter is only controlled under acceleration, not through gear changes, as this is purely mechanical.
07-22-2021, 05:58 PM | #34 |
Drives: BRZZZ
07-22-2021, 06:42 PM | #35 | |
2013 Series 10 FRS #553
07-29-2021, 06:24 PM | #36 |
Drives: 2013 Scion FRS
Speaking of fuel starvation - whats the fix here? Aftermarket fuel pump?
07-29-2021, 07:13 PM | #37 |
07-30-2021, 06:42 PM | #38 |
07-30-2021, 07:50 PM | #39 |
07-30-2021, 11:50 PM | #40 |
07-31-2021, 12:29 AM | #41 |
Similar Threads | ||||
Possible overrev on the track; does ECU store max lifetime RPM reached? | SmoothIsSlow | Engine, Exhaust, Transmission | 21 | 07-22-2021 06:04 PM |
Need help about the mechanical coverage! | hoangjm | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 04-11-2019 02:51 AM |
frs oversteer in brz mechanical? | swpbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-18-2014 09:48 PM |
Overall mechanical satisfaction? | Tman08 | Issues | Warranty | Recalls / TSB | 15 | 08-26-2013 05:28 PM |
